Old 11-14-2010, 09:05 AM   #43
Images: 59
Originally Posted by toastie View Post
On your setup, what head angle did you use?...........toastie
In the study I did, the head angle is not a factor. I inverted the head so the bars were horizontal during the test. That eliminated any cosine errors. The bars were loaded with up to 420 lb of weight, and the deflection was measured directly. I did not use the setup shown in your post.
Old 11-14-2010, 09:14 AM   #44
toastie's Avatar
1955 22' Safari
Great Lake State , .
Markdoane, my question wasn't related to the study, I have the same setup as you have and trying to figure out what head angle I should start with..........toastie
toastie is offline   Reply With Quote
Old 11-14-2010, 10:41 AM   #45
toastie's Avatar
1955 22' Safari
tiger
This is the system that I went with: Strait-Line Weight Distribution w Sway Control - Trunnion Bar - 10,000 lbs GTW, 600 lbs TW
My TV is a 2008 Cheve Trailblazer, gross vehicle weight rating 5,550 lbs, curb weight 4,356 lbs. with max towing capacity is 5400 lbs. The trailer is a 1955 Safari approx weight is 2800 lbs tw approx 300 lbs. The bars are 600lb MAX load, so my 300lb TW is at a sweet spot.
I'm learning how to set it up now and here are a few sites that is helping me in that set up.
RV.Net Open Roads Forum: Towing: Travel Trailer Hitch Set-up Procedure
Google Image Result for http://i23.photobucket.com/albums/b378/JBarca/Hitch%20Setup/Reesetopview-shimed.jpg
toastie
Old 11-14-2010, 12:15 PM   #46
Images: 59
I would start in the middle of the range and adjust accordingly. We have different trailers, tow vehicle, ball height and tongue weight.
I think I am just a tooth or two tilted back.
Old 11-14-2010, 12:22 PM   #47
toastie's Avatar
1955 22' Safari
thanks
Old 11-14-2010, 01:27 PM   #48
SteveH's Avatar
Common Sense , Texas
Originally Posted by r carl View Post
Take it easy Steve, Andy has forgotten more than you and I together know about airstreams.....
About Airsteams, no doubt.
About WD hitches, well not so much....Andy has proven to me he knows a little about one manufacturer's one model of hitch.
Regards,
Steve
Old 11-14-2010, 02:51 PM   #49
toastie's Avatar
1955 22' Safari
I bought my system about 2 weeks ago based on Andy's recommendation, very happy with the purchase, thanks Andy............
toastie
Old 11-14-2010, 02:52 PM   #50
toastie
Your more than welcome.
Old 01-15-2011, 12:35 PM   #51
Past Prez.NEU/Membership
AirHog's Avatar
2005 34' Classic
2015 Interstate Ext. Coach
N Smithfield , Rhode Island
Images: 21
Hello,
I just bought a Curt # 15524 Class V hitch to replace my OEM hitch for my 2004 Yukon Denali. The 7 Pin connection bracket is actually welded to my old hitch. Of course the new hitch has no such item pre attached. I do not have any welding tools- I would appreciate any comments on how do I find a way to have a permanent attachment for the electrical connection.
Many Thanks.
Titu
T & Gail
2015 Airstream Interstate Ext
2005 34'Classic- Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
WBCCI #2905-NEU
AirHog is offline   Reply With Quote
Old 01-15-2011, 01:29 PM   #52
Images: 59
You're kinda stuck cutting the old 7way mounting bezel off with a hacksaw and drill and tap into the new hitch with some 1/4 or 5/16 screws. You might need to fabricate a bracket with some angle iron.
Won't be beautiful but it will work.
Old 01-15-2011, 03:41 PM   #53
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Originally Posted by AirHog View Post
Hello,
Many Thanks.
Titu
I had the same problem when I bought my Curt. I cut the one off the GM hitch and mounted it upside down to the Curt hitch....works just fine.
If it wasn't raining, I would post a photo....
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 01-15-2011, 04:03 PM   #54
AirHog's Avatar
2005 34' Classic
Images: 21
A picture would be very much appreciated, if you get a chance. I am in no rush. 10 degree outside and as cold in the garage.
T & Gail
WBCCI #2905-NEU
Old 01-15-2011, 05:03 PM   #55
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I posted the photos at "My Photos"....
Old 01-15-2011, 06:04 PM   #56
AirHog's Avatar
2005 34' Classic
Images: 21
Looks great. Thank you very much. I will do the same. Best to you my friend.
Titu
T & Gail
WBCCI #2905-NEU
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches, Couplers & Balls 9 05-02-2006 12:35 PM
Which Weight Distribution Hitch to buy? Navigator Hitches, Couplers & Balls 7 11-19-2003 07:56 AM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
