Old 11-12-2010, 07:04 PM   #15
SteveH's Avatar
Common Sense , Texas
Originally Posted by Inland RV Center, In View Post
I personally prefer the square bars, because if they take a set, you can invert them. That cannot be done with the round bars.
Late model square bars cannot be inverted because the cam is built into the bar.
Regards,
Steve
Old 11-12-2010, 10:00 PM   #16
2016 30' Classic
Issaquah , Washington
To determine the proper size of the Reese weight distribution bars look on page 28 of the Reese Heavy Duty Towing & Trailering Accessories catalog:
http://www.reeseprod.com/content/dow...ng_Catalog.pdf
PJohnson is offline   Reply With Quote
Old 11-13-2010, 07:28 AM   #17
SteveH's Avatar
Any spring steel, can and often does, take a set.
Square, round, triangular, oval or rectangular, all the same.
Trunion (square) bars are not very flexible, and therefore are more prone to take a "set".
Round bars are more tapered, more flexible, and therefore are very much less prone to take a "set".
Then, if you put 1000 pounds of load on 500 pound trunion bars, they will DEFINATELY take a "set".
Regards,
Steve
Old 11-13-2010, 08:28 AM   #18
Bar flexing
Testing Reese round and square bars, show no difference in the amount of bend, for a given load.
That may be different for other manufacturers.
Bars when overloaded, can take on a set. As an example, instead of the trailer and tow vehicle being level with each other, they form more of a "V" shape, such as boarding a ferry boat.
Facts are facts.
Old 11-13-2010, 10:44 AM   #19
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Hitch bar ratings are dictated not only by the tongue weight, but also by the type of tow vehicle.
What exact tow vehicle will you be using?
Where do we find the formula or chart that tell us how much to adjust the hitch manufacturer's ratings based on what tow vehicle we use?
Ken
Old 11-13-2010, 10:53 AM   #20
SteveH's Avatar
Andy,
If you really had the "experience" you claim, and I mean experience using all types of these hitches and not just selling them, you would know your statement above is not true.
Regards,
Steve
Old 11-13-2010, 10:56 AM   #21
dznf0g's Avatar
Oswego , Illinois
Ya'll are assuming that the alloys are the same in all bars too. I am told by Equal-I-Zer that they are not.
Old 11-13-2010, 12:16 PM   #22
Ken
Experience.
Old 11-13-2010, 12:23 PM   #23
Originally Posted by SteveH View Post
Andy,
My experience is vouched for all over the world, by international and national news media's.
What is your "experience"? Where can one find a publication naming you as an expert?
I know my experience and Airstream knowledge is subminiture.......to some.
Old 11-13-2010, 01:55 PM   #24
Ag&Au's Avatar
Experience.
And how many MODERN tow vehicle/hitch/trailer combinations have you tested in your vast experience that apparently makes you more knowledgeable that the engineers that design these products and set the safe weight limits?
I'm thinking this is the kind of expert we need right now.
Old 11-13-2010, 02:13 PM   #25
SteveH's Avatar
Well, if you would like, I'd more than happy to compare actual hitch in use towing experience with you. I'm talking about actual use of these products, not some insurance accident investigation thing from twenty years ago that does not even include the hitch products on the market today.
How many thousands of miles have you towed your Airstream in the last year, what type hitch did you use, what tow vehicle, how many states did you tow in, on what type roads, do you even own an Airstream?
Regards,
Steve
Old 11-13-2010, 03:42 PM   #26
toastie's Avatar
1955 22' Safari
Great Lake State , .
Trunnion Bar or Round Bar? according to etrailer expert.
Which Weight Distribution Style is Better, Trunnion Bar or Round Bar | etrailer.com
Expert Reply:
You will hear arguments for both, the general consensus around etrailer.com is that trunnion systems are the better design. The bars are very easy to remove and install in the head. Since there is no bend in them, they are considered stronger and more durable. Since the head does not come down and the bars do not stick out of the bottom, there are less ground clearance issues. Some people argue that round bar systems are easier to adjust, but you set the brackets and head once and as long as you are towing the same trailer, you usually do not have to adjust them again.
toastie
toastie is offline   Reply With Quote
Old 11-13-2010, 05:14 PM   #27
SteveH's Avatar
Expert Reply:
toastie
"Since there is no bend in them" = Stiffer than round bars and so rougher riding, as I has stated before.
Regards,
Steve
Old 11-13-2010, 05:51 PM   #28
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I think that they are talking about the 90 degree bend in the round bars. Because there is a bend in the round bars, the author claims that this could a weak point in the design.
Richard
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches, Couplers & Balls 9 05-02-2006 12:35 PM
Which Weight Distribution Hitch to buy? Navigator Hitches, Couplers & Balls 7 11-19-2003 07:56 AM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
