Old 06-13-2009, 04:34 PM   #1
1967 22' Safari
New Paltz , New York
Weight Distribution Bars
I have a Reese round bar WD system and can't seem to get the bars to level with enough tension. I can easily hook up the bars to level, but it doesn't feel like there's any weight being carried. When there's tension, the bars tend to ben upwards and not certain if that's correct. The ball and trailer are pretty level when hitched too. Any suggestion?
1967 22' Safari
1994 Ford F-150 V-8 shortbox
1988 Sea Ray Seville 21CC, V-6
BillM2 is offline   Reply With Quote
Old 06-13-2009, 04:37 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Use your tongue jack to lift up back of truck,then connect bars,after you play with it a few times ,you just need to count links to get it right.Dave
easyride is offline   Reply With Quote
Old 06-13-2009, 04:47 PM   #3
1967 22' Safari
So, I hitch up, raise the tow vehicle up a little, attach the bars with a little or no tension? Then lower the truck....
1967 22' Safari
Old 06-13-2009, 04:52 PM   #4
easyride's Avatar
1977 27' Overlander
Naples , Florida
CORRECT,or you need a long,long pipe.Dave
Old 06-13-2009, 05:00 PM   #5
1967 22' Safari
I've used a bar to lift up and the bars seemed to bend upwards. Is that normal. When I've attached it with the bars level, there doesn't seem to be enough tension lifting up. Will this technique you're suggesting help?
1967 22' Safari
Old 06-13-2009, 05:17 PM   #6
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Sounds to like like your saying the bars need more tension when they are level. To do that you need to angle your ball more. That will make the bars hang down more so there will be more tension on them when level. Loosen the bolts at the hitch and angle the ball some, then re-tighten the bolts. you will have to do this a few times to get the right angle so there enough tension on your bars being level.
LMHO, Bob
RLS is offline   Reply With Quote
weight distribution hickory Tow Vehicles 2 05-13-2009 07:39 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Weight Distribution Bars-Avoiding a mess JaceBeck Hitches, Couplers & Balls 18 11-25-2004 12:29 PM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
