Old 10-22-2015, 12:35 PM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by FreshAir View Post
Hi, Mr, '64 Lincoln, you and I have 'chatted 'before on the FB NorCal group. Love your Lincoln. Now to relate my set-up which may change many opinions. My TVs are a big '71 Buick convertible and '69 Olds Ninety Eight. Both are powerful 455s with the Buick's recent overhaul placing it at 463. Plenty of towing for our '66 Trade Wind. One would argue that's plenty with that including that both cars are heavier than the TW's dry weight of 4100 lbs. However both cars have a long overhang (5 plus feet from rear axle ) plus the need to ratchet the tow ball further out from the rear bumper because the gas filler is located behind the rear license plate. The main purpose of the WDH is the DISTRIBUTE some of the tongue weight from on the rear of the TVs to it's front wheels. The tongue of my Trade Wind hitched directly to the rear of my cars pushes the bumper just inches from the ground. Some are surprised that I use 1000 lb bars. But they 'work for me'.
Neil
Love the Deuce-and-a-quarter and the Nine Eight!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-22-2015, 01:02 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
When selecting weight distribution bars it is important to add whatever gear weight you are putting into the tow vehicle behind its rear axles, to the trailer hitch weight. The weight distribution bars have to lift both.
Otherwise you will not have strong enough bars to restore your tow vehicle's front axle to its unloaded weight (or height), while still retaining good flexibility in the w.d. bars and gentle ride for you and your Airstream.
Wheelbase of the tow vehicle, distance from rear axle to the receiver ball, and tow vehicle suspension stiffness also come into play, but it's harder the know the effect with hitching up and weighing the rig.
So w.d. bar rating simply matched to trailer hitch weight will probably not be strong enough to restore unloaded tow vehicle front axle weight (or height). Too light of a bar rating may also cause a stiffer ride because the bars have little flexibility left in them after hitch and tow vehicle load weight (behind the rear axle) are distributed.
Doug and Cheryl
Old 10-23-2015, 08:03 AM   #17
Tom T
Tom_T's Avatar
Orange , California
Also, if you don't crank in all of the bars' capacity to level the TV (HW + rear gear in TV as Doug says above) - then you're not using all of the bars' capacity anyway. You just have a bit stiffer reaction at bumps, which can give a stiff ride.
It's much better to be over by a margin (i.e.: bigger than you think you need), than so close you may have it over wt. on a particular trip .... like when "Lucy" puts the rocks in your trailer, or the kids have extra gear, etc.
Our Hensley Cub max'es out at 6,000#/600# - so we're at the max., & they do not recco going to any smaller bar - even though our Avion is probably 1/2 - 2/3's of that HW - even counting gear in the TV aft of the rear axle.
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
towing without a weight distribution /sway control srpuywa Towing, Tow Vehicles & Hitches 37 03-11-2013 09:53 AM
Weight distribution hitch and/or sway control chaeha Towing, Tow Vehicles & Hitches 8 11-15-2012 11:11 AM
Weight Distribution & Sway Control, Simple answers please... JimHoek Hitches, Couplers & Balls 52 08-24-2010 10:46 PM
sway control and weight distribution for 22' safari? JeffVH Hitches, Couplers & Balls 12 01-29-2009 05:21 PM
I need sway control AND weight distribution? TBKP's Overlander Hitches, Couplers & Balls 19 07-03-2003 08:54 AM
