Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-20-2003, 09:38 PM   #1
jack simons's Avatar
Profile:
weight distributing hitches
I have a 26ft 1974 Argosy. I am a nubee. Am thinking about a weight distributing hitch. Is it necessary? I would like some imput from you all.
jack simons is offline   Reply With Quote
Old 10-20-2003, 09:42 PM   #2
Profile:
What are you towing it with?
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 10-20-2003, 09:56 PM   #3
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
We use a weight distributing hitch on our 17 ft trailer, which is under #3000 loaded. Even though it may seem like overkill, once we got it adjusted right we really liked the ride it gave us. It made the trailer feel much more solid and connected. We're also newbies (just started earlier this summer when we got our trailer), so we wanted everything to be as easy and safe as possible right from the get-go.
Stephanie
Our family photo blog
In honor of Alki and her battle with cancer we will be participating in the 2008 American Cancer Society Relay For Life. Please click here if you would like to see her page and donate to the cause: Donate
Stefrobrts is online now   Reply With Quote
Old 10-20-2003, 10:22 PM   #4
Profile:
Intresting thing about the single axle trailes, they can have a tendency to sway. This is expecially evident when your passed by a semi. Weight distro systems will help calm the sway but anti sway systems work better. If your towing with a lightweight vehicle then the weight distro system will help it carry the load better.
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 10-21-2003, 05:59 AM   #5
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
I would
I'd suggest a WD hitch system with that size trailer. While you're at it might as well put on anti sway bars. Reese has two anti sway dual cam hookups that are moderately priced.
Tin Hut is offline   Reply With Quote
Old 10-21-2003, 06:53 AM   #6
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Jack!
Welcome to the Forums and the world of Vintage Argosy ownership. I would recommend the Reese Straight Line hitch that includes the Dual Cam Sway Control system. I have used this system with my '64 Overlander since 1996, and with my '78 Argosy Minuet 6.0 Metre since it was purchased in 2002.
I use this system regardless of whether my tow vehicle is the '99 Suburban with 10,000 pound trailer towing package or the '75 Cadillac with the 6,000 pound trailer towing package. The Overlander weighs in at or very near 6,000 pounds when it is fully loaded for a long vacation (would likely approximate your Argosy 26' in loaded weight) while the Minuet weighs in at just a bit over 3,000 pounds.
I have found this system to be quite effective in my travels that have included nearly all of the states West of the Mississippi River. For best performance of the system, however, setup according to the manufacturer's directions is crucial.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 10-21-2003, 10:33 AM   #7
Profile:
- first I have heard this opinion. - doesn't match my experience, though. also can't see any theoretical reason why one axle would be more likely to sway than two in a trailer.
Load leveling spring bars become a good idea when a combination of tongue weight and ball to rear axle distance add to significantly alter the front to rear axle load ratio in the tow vehicle.
For a new installation needing load leveling, I'd suggest looking at the Equal-i-zer hitch at about $400 as it includes sway control and handles about the same as the dual cam. The DC may be a better choice as an add on to improve handling of a typical Reese or Eaz Lift spring bar system.
Whatever way you go, be sure to use components rated for the loads - not too big nor too small.
Bryan
Leipper is offline   Reply With Quote
Old 10-21-2003, 12:23 PM   #8
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
Just some more input. One of Unit's member's has a Ford Sport-Trac and a new Bambi. They have a Hensley setup and are very pleased.
Dwight is online now   Reply With Quote
Old 10-21-2003, 04:40 PM   #9
Profile:  Dallas , Texas
Load Distribution and Sway
I tow a 34' classic limited with an 03 Excursion 6.0 l diesel. Previously I towed it with a 2000 Yukon. The secret to totally eliminating the sway is the Hensley hitch. Its EXPENSIVE, but it WORKS! I'm not affiliated in any way with Hensley - just a satisfied customer.
linc54 is offline   Reply With Quote
Old 10-21-2003, 05:03 PM   #10
airstreamer01's Avatar
Profile:  Kirkwood , Missouri
My cousin has a 74 Overlander he doesn't use a weight distributing or sway control. He has pulled alot of miles with out any complaint! He drives too fast but never has a complaint. I have a 30' Classic (widebody) Drove to Vermont this summer had terrible time with sway could not get home fast enough to get a Hensley. I think some of the difference is in the wide body & weight.
Jeff
Jeff
2001 30' Excella Classic
WBCCI 4572
airstreamer01 is offline   Reply With Quote
Old 10-21-2003, 05:55 PM   #11
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Sway
It has been my experience that although a number of factors influence sway, the tire configuration/psi/sidewall flex on the tow vehicle seems to be one of the biggest factors.
Towing my '61 Bambi behind my AWD Astro without sway control was an absolute disaster; a white knuckle ride the whole way. Towing a '78 Minuet with the same Astro WITH a Reese Dual-Cam was an entirely different experience. I had cheap two-ply radial tires on the Astro, and it tended to wiggle around without anything attached. It felt more solid with the Minuet and the Reese than driving the Astro by itself.
Towing my 34' with my Excursion with the tires aired to 50-55psi WITH a Reese Dual-Cam sway control is no fun at all; it feels every truck that goes by. However, if I air the tires up to 70psi in the Excursion, it feels rock-solid with no sway and I don't even know I'm being passed by a truck. The difference is pretty interesting.
And of course, I wrote in another thread about the difference in using an extended-length drop bar versus using the Reese Hi-performance drop bar. Again, a whole world of difference.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 10-22-2003, 12:10 AM   #12
qqq
qqq's Avatar
Profile:
No device on my safari & Silverado , no problemo, tows perfect under any circumstances
Hart
qqq is offline   Reply With Quote
Pingbacks are On
Blue Ox Weight Distributing Hitch Bill Price; Hitches 5 02-28-2004 11:18 PM
weight distributing bars/trunnion bars teutonik Hitches 2 12-04-2003 06:58 AM
Weight Distributing Hitch joshua32064 Hitches 1 09-27-2003 07:16 AM
Dry weight variances Moonshot On The Road... 1 09-11-2003 08:06 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
SEO by vBSEO 3.1.0
