Old 02-21-2006, 09:05 PM   #15
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Hitch
Hi all,
I have an 1985 Sovereign. It has hitch almost like the Blue Ox. The main differance is that two bars hook up to the hitch that swiwels in the middle. It has 2.5 inch ball. I have been looking in a lot of magazines and the internet to identify it. No luck so far. If anyone has any ideas please let me know at rdworian@comcast.net . This looks like instalation that the dealer would put on. This AS. was first sold Mantica Calf. and I am the second owner. I still have all the original paperwork on the trailer but nothing on the hitch. I could not find find any I.D. on the hitch. Any ideas would be appriciated.
Regards Rusell
RUSSELL is offline   Reply With Quote
Old 02-21-2006, 09:26 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by RUSSELL
Hi all,
Regards Rusell
Russell,
What color is the hitch? Could it be a Hensly Arrow?
Aaron
WBCCI #XXXX AIR #2495
Old 02-22-2006, 01:04 PM   #17
Safair64
Holes are not drilled anyplace, when using a Reese "Dual Cam" sway control. U bolts hold it in place.
However, it's usually wise to install 3 U bolts on each side, so that the bottom plate can "never" loosen, especially with larger trailers.
Drilling 4 holes suggests a friction type sway control, that I don't recommend, because it "must" be somewhat disabled when towing in rain or snow. Also, it never knows when your in a straight line or not. Therefore it exerts as much force getting you into or out of a sway.
Not true with a Reese.
Old 02-22-2006, 11:34 PM   #18
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Thanks Andy,
I almost have this nailed down and ready to purchase.
I like the 3 u-bolts per side tip. Thanks
I know I want the dual cam vs friction.
It looks to me like Reese has two dual cam setups advertised.
One is the standard u-bolt type you're talking about, part #26000.
The other one is called: Reese Dual Cam High Performance Sway Control. Part number is #26002. It states: ďno u-bolts to conflict with bottle racks or...Ē
This one appears to be different and mounts by bolting to frame with 2 bolts each side. That means drilling holes in vintage AS frame.
This HP setup is also listed as part of their "Strait-line hitch kit" which is the #66020 hitch and #26002 dual cam HP sway control as a group. This is the package I was looking at, although, it only sells for about $20 less than standard hitch and standard dual cam.
Is theHigh Performance Sway Control actually any more high performance?
I suppose my main question now is:
How do I install the u-bolt setup and not interfere with my original LP bottle rack and bottles?
Safari64
Safari64 is offline   Reply With Quote
Old 02-23-2006, 12:12 PM   #19
Safari64
Ah, new gadgets.
The new Reese HP sway control, operates the same as the standard sway control.
However, the HP mounts with self tapping screws, but you must drill the 1/2 inch holes.
It would appear that the HP model is more versatile than the standard model, plus it costs a little less.
If you use the standard model, the flat plate can be reversed, which allows an additional way to avoid the gas bottle rack interference.
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 11:21 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1969 Overlander 5 02-08-2003 04:49 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 06:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 04:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
