Old 04-01-2017, 02:11 PM   #1
Goingcamping's Avatar
2017 16' Sport
Cherry Log , Georgia
Smile Weight Dist Really Needed for 16' Sport?
Good day! I have read and read but need a little help (newbie). I have a brand new 16' Sport - and TV is 2017 Lexus GX 460 (tows 6500 lbs - max tongue weight 500 lbs) Sport is 3500 lbs GVWF - 350 tongue weight (plus 40 lbs propane plus 40 for battery)…so total of about 440 lb) Anyhow, my Lexus has TSC (trailer sway control) but the dealer says I def need weight distribution hitch at $750. I want to be safe, but the more I read here, just don't know what to do! Many thanks for your experience and guidance!
Goingcamping is offline   Reply With Quote
Old 04-01-2017, 02:34 PM   #2
N/A , N/A
This is from GX460's user manual:
● If the gross trailer weight is over 2000 lb. (907 kg), a sway control
device with sufficient capacity is required.
● If the gross trailer weight is over 5000 lb. (2268 kg), a weight distributing
hitch with sufficient capacity is required.
Your trailer weighs less than 5000#. However, GX460 has a very short wheelbase. I personally would not tow this combination without a weight distribution hitch with sway control. If you are new to towing, IMO, you should not take an unnecessary risk. Just get the hitch. My 2 cents worth.
rostam is offline   Reply With Quote
Old 04-01-2017, 02:44 PM   #3
2014 22' FB Sport
2017 28' Flying Cloud
Southwest Ranches , Florida
I believe the Airstream specs on base weights are for an empty trailer, no water, but it does include the battery and full propane tanks. Anyway, i don't think you need sway control if you have 10-15% of the trailer weight on the tongue.
Mergatroyd is offline   Reply With Quote
Old 04-01-2017, 03:18 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Look at the Andersen hitch for that rig.
2004 Excursion 4x4
Old 04-01-2017, 03:38 PM   #5
Chelsea , Maine
I agree. I've had a few Andersen products, they make good stuff. I think their WD hitch would be perfect for this combination.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 04-01-2017, 03:41 PM   #6
Chelsea , Maine
I agree with this too. Your dry tongue weight spec includes batteries and propane. It's on the Airstream website.
2017 FC 27FB
Old 04-01-2017, 03:43 PM   #7
Boxite's Avatar
2008 22' Sport
Find out what amount of wt is on your vehicle front axle, versus what amount is on your rear axle. If the rear axle is less than the front by a couple hundred lbs... measure the height above ground of your front fender at the top of the wheel well... and do the same at the rear wheel well.
Now hook up your trailer and re-measure the wheel well height.
If your front WW height was 30" and the rear was 31" and after the trailer is mounted the front remains at 30" then as long as the trailer is level you should not need WD hitch. (This excersize is designed to determine if front axle weight decreases excessively. If not, you do not need WD.) Drive it and see how it handles.
There's a good chance you do not.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 04-01-2017, 04:30 PM   #8
2016 16' Sport
Miami , Florida
The Anderson hitch is not compatible with most airstream couplers. I have a 2016 sport 16 and I know mine falls into this category.
Shiny16 is offline   Reply With Quote
Old 04-01-2017, 04:54 PM   #9
Long Island , New York
WD hitches also help dampen the undulating motions of the rig on uneven road surfaces at certain speeds, and thus benefit almost all combinations of TV and trailer. The question really could be, therefore, why would you not get a WD hitch?
Old 04-01-2017, 05:05 PM   #10
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Only question: will it increase your safety margin for when **** happens?
What's $750 on a $60,000 trailer if it increases safety and better protects your loved ones?
You want a largest possible safety margin for when things go wrong out on the road - and it will go wrong!
That's what an accident is - by definition - unexpected, and the one with the largest safety margin survives.
Silver Hawk is offline   Reply With Quote
Old 04-02-2017, 01:19 PM   #11
2017 16' Sport
Parker , Colorado
Husky 32216 Center Line TS with Spring Bars - 400 lb. to 600 lb. Tongue Weight Capaci
I'm using a Husky 32216 Center Line TS with Spring Bars - 400 lb. to 600 lb. Tongue Weight Capacity (2-5/16" Ball) with a 2017 16' Bambi. $298.40 plus free shipping.
n2mp60 is offline   Reply With Quote
Old 04-02-2017, 01:27 PM   #12
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I agree with Mergatroyd. I tow a 21' 5,000 lbs. boat on tandem axle trailer with a 2008 Range Rover HSE without weight distribution and have never experienced any sway or lightness on the steering axle. My rig doesn't squat because of air suspension.
I would try it without WD and see what it drives like at various speeds and conditions. If it feels light on the steering axle compared to without the trailer, or the TV squats at the rear, then yes, you would benefit from WD. JMHO and you must do what feels right and safe for you.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 04-02-2017, 02:14 PM   #13
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Zillions of opinions on this so you have to weigh your own margin of safety. I had a 16 sport and towed it with both a Nissan frontier and a Ram eco diesel 1500. I used WD and sway control and both and it sure towed nice and never a issue. You might go your whole life and never get to the limits where it makes a life saving difference, but of course without it and it happens it's too late.
jtwind is offline   Reply With Quote
Old 04-02-2017, 02:32 PM   #14
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Sounds like you might need a Hensley Cub. Call Hensley and ask them about your towing combination. I don't know if ProPride makes a comparison. The shorter the wheel base the more you need a trapezoid hitch design.
guskmg
Old 04-02-2017, 02:38 PM   #15
2017 16' Sport
Sturgeon Bay , Wisconsin
OK, I'm a newbie. My first question of many, I'm sure. n2mp60 referenced a Husky 32216 unit, that to my unpracticed eye, looks like a replacement for the hitch on the Sport. I'm picking up a 16' Sport in a month. Plan to tow it with a 2017 Toyota 4Runner. Should I be looking at something like this?
alberto52 is offline   Reply With Quote
Old 04-02-2017, 02:48 PM   #16
dalecamp`'s Avatar
Pearland , Texas
You should at least have friction sway control, in addition to what electronic sway control is included with the Lexus.
Believe me, the tail will wag the dog. I don't care what others have said. Seriously consider what others have suggested for safety reasons, WD hitch with sway control.
Dale Camp
Pearland, TX
1982 Avion 34V
2003 Chevy 2500HD Duramax 4X4
dalecamp` is offline   Reply With Quote
Old 04-02-2017, 03:12 PM   #17
2017 19' International
Tallahassee , Florida
My trailering experience pales in comparison to the Airframes senators, so with that caveat ... I have a Sport 16 that I tow without a weight-distributing hitch.
It does have a friction sway control ... an inexpensive addition and not much hassle to use.
I pull it with a 2004 Chevrolet Suburban. It does fine.
WhereStream is offline   Reply With Quote
Old 04-02-2017, 04:23 PM   #18
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Is that why many of us are in this World?
MelGoddard is offline   Reply With Quote
Old 04-02-2017, 04:55 PM   #19
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
"Weight Dist Really Needed for 16' Sport?"
-Probably not needed, but a really good thing to have anyway.
Better ride, weight distributed more evenly and, above all, quite cheap insurance for an expensive trailer. Sway control/elimination is good to have too, whether built in to the WD system or added on afterwards.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-02-2017, 05:44 PM   #20
2014 23' Flying Cloud
Rhinebeck , New York
Agreed and well stated. There is nothing better than the confidence that comes with trailering safely. You could "tow" the 16' AS and would likely get from point A to B. But, my experience is you do the same trip actually enjoying the experience rather than constant "worry" when your "set-up" is as it should be rather than "minimal."
Adam Geuss
2017 16' Airstream Sport/2017 Dodge Durango (5.7 hemi) weight distribution/anti sway hook-up.
2014 23' Airstream International Serenity with 2011 Ford 250 6.7L TV.
Adam Geuss is offline   Reply With Quote
Reese weight dist. hitch instructions...? aircooled4 Hitches, Couplers & Balls 2 06-24-2009 09:39 PM
Looking to buy a weight dist. setup best value? WineStream Hitches, Couplers & Balls 13 03-05-2009 08:27 PM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 01:30 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 09:46 PM
