Old 08-14-2018, 06:44 AM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
WD with 3/4 Ton TV
I have a 1/2t TV and am considering going to 3/4t TV. I currently am using a Blue OX Sway Pro wd hitch. I wound think weight distribution is not as critical with a 3/4t, or is it?
And if I stay with the BO hitch can I use a setting with less bar deflection and still get the sway control?
Thanks!
Old 08-14-2018, 07:28 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have a 3/4 ton and the WD does much to smooth out the ride. Otherwise you can still get porpoising. Mind you some 3/4 ton trucks could be sprung more heavily than others. Look at the trucks GVWR. Ultimately I would like to have a Ram with air suspension or a truck with the full Kelderman air suspension to be able to dial in the ride for different loads.
Also if I take a lot of extra heavy stuff such as fire wood, bikes, grills etc.... I can dial up the WD to keep things leveled out. On long trips I don't take as much stuff as the short local trips where I need more stuff.
I don't have the BO hitch to answer that aspect of your question.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 08-14-2018, 07:37 AM   #3
2014 27' Flying Cloud
Wenatchee , Washington
WD with 3/4 Ton TV
I am no expert in setting up hitches but I use a Blue Ox hitch and I tighten it up enough to keep the trailer from swaying and thatís about all. My Ram 3500 SRW 4x4 pickup is pretty level when we are towing (our FC27FB).
Since the Cummins is so heavy I really donít think itís wise to shift more weight to the front axle. (I also donít see any need to pop any more rivets.)
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 08-14-2018, 08:05 AM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks!
Scales are the best way to answer that question definitively. I have a 3/4T diesel (very heavy front end) and my 27FB lifts about 500# off the steer axle when connected. I feel that. In fact, when I used Chevyís recommended 50% FALR I still had porpoising. Putting all the weight back on the front end helped in my case. Multiple trips to the scales to test and validate helped set a baseline I can adjust based on loads.
You may find it helpful. Good luck!
Old 08-14-2018, 08:55 AM   #5
2018 28' International
Fayetteville , Georgia
I have an F250 diesel. I tow with WD/sway. If I am just pulling the camper home from the storage lot, I don’t put the spring bars on. But it’s only a few miles at 35 mph.
Without WD, my front raises 1/4 inch. WD brings it back to non-towing height.
I do notice less porpoising with WD.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 08-14-2018, 09:46 AM   #6
MWBishop's Avatar
Huntsville , Alabama
I towed 26U with F250 several hundred miles just on the ball.
Add Equalizer to shift weight back to steer.
For my rig it did make a difference - not just for sway control but overall stability (porpoising mostly).
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 08-14-2018, 10:14 AM   #7
1979 30' Argosy
Everton , Arkansas
I have a 2017 chevy 3/4 ton and I can't use the equalizer hitch. My truck handles the weight just fine as did my 2006 chevy 3/4 ton I use to pull my 30 TT with
DEDUBE is offline   Reply With Quote
Old 08-14-2018, 01:02 PM   #8
Anna Maria , Florida
Thanks!
I made that move over a year ago. F 150 ECO to F 250 power stroke with BO, and in my case I ended up using the exact same setting on both.
I tried one link less first but it didn't feel right. I had a 5.5 box with super cab on the 150
and have 6.5 box and super cab on the 250.
franklyfrank is offline   Reply With Quote
Old 08-14-2018, 01:07 PM   #9
One thing you don't have to worry about with the Blue Ox is popping rivets. One of its great features is the ride it provides to the trailer .
Old 08-14-2018, 02:14 PM   #10
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
We tow our 2017 Serenity FB with a 2016 RAM 2500 equipped with automatic rear air leveling in the alternate trailer height setting.
The truck is always level and is a snap to hookup/unhook. We are using an Equalizer WD/Sway system with 1000 pound bars.
Smooth sailing under all conditions (not tried in snow) and with heavy cargo loads. We ordered the auto rear air leveling as a factory build option.
SilverWind is offline   Reply With Quote
Old 08-15-2018, 03:20 PM   #11
Hans627's Avatar
Thanks guys! That was helpful information!
Old 08-15-2018, 05:49 PM   #12
Thatís good to know. We did pop 3-4 rivets in the ceiling adjacent to the door on our 27FB a couple years ago but we had also traversed some relatively rough highways on that trip so maybe we got off easy.
WBCCI #7180
Old 08-15-2018, 08:20 PM   #13
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I have a 2017 chevy (gmc same thing) 3/4 ton and I wouldnít tow my 30í TT without my equalizer attached for WD and anti-sway..... there you go - both ends of the spectrum
wulfraat is offline   Reply With Quote
Old 08-15-2018, 08:24 PM   #14
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I pull our 23D with a 2016 GMC Duramax. I use EZLift and 600lbs bars. Hang three links and 500 lbs put back on the front tires and all level and good to go
Hitch system for 3/4 ton or 1 ton truck (GMC) Crazycanucks Tow Vehicles 31 04-02-2017 07:13 AM
Hitch adjustments when going from 1/2 ton to 3/4 ton Wanna EB Tow Vehicles 8 08-18-2016 06:50 PM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 04:10 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 11:13 PM
