Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 02-04-2014, 08:55 AM   #61
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Originally Posted by Ron Gratz View Post
Can you tell us what WW measurements Andy said to shoot for?
Ron
His recent 300 was about 1/2" - 3/4" down in the front and 1/2" - 1" down in rear.
My current setup is 1/2" down in front, and 1-1/2" down in rear, BUT the rear was around 1/2" higher than stock due to the air shocks. The have to be a little extended in order to work on my car (there was no standard part for this car and it was installed as a custom install.).
So, I think my setup is now very much like Andy's. I'll visit the scale again.
mstephens is offline   Reply With Quote
Old 02-04-2014, 09:02 AM   #62
mstephens's Avatar
I would agree if all of the 2500# on the front axle resulted from the mass of the tow vehicle and the location of its center of gravity.
However, about 25% of that 2500# is not a result of TV mass and CG location.
The 625# which was exerted on the front axle via application of WD is not a result of additional TV mass.
That 625# is a result of torque from the WDH being translated to a downward force on the front axle via leverage.
The extra 625# of tire load means additional lateral tire force, but there is no corresponding TV mass to absorb the effects of the additional force.
This causes the TV to "steer" more than the steering wheel angle is requesting.
There is delicate balance among front axle lateral force, rear axle lateral force, and CG location.
The imposition of a force, without corresponding mass, on the front axle can upset the balance.
Ron
It took me a bit to visualize this. But I think I see the difference. My intuition tells me that when there is no WD, the ball/coupler is sagging a lot. The initial WD easily lifts the back end to the point of about 20" above ground - the height ball started out. But as you try to apply more WD than that, it becomes very hard to raise the ball/coupler above 20" and the force applied begins to be just torque on the front axle. I think that's what is being said.
600 vs. 800 vs. 1200 lb trunnion bars? Doc Foster Hitches, Couplers & Balls 42 02-01-2014 10:00 PM
Weight distribution bars Mrs. Bale Hitches, Couplers & Balls 6 07-19-2011 06:11 AM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
