Old 05-11-2007, 06:04 AM   #1
2007 25' Safari FB SE
Kennesaw , Georgia
Question W/D hitch: un-hitching and hitching
Hey, random thought as I get used to hitching/un-hitching my Blue Ox weight distribution hitch from my truck.
Is it feasible to simply set the weight of the trailer on the tongue jack, release the pin/clip from the receiver part of the hitch and pull the truck forward, which will leave the hitch head, ball, spring bars, etc. all still connected? To re-hitch, simply back up the truck to the hitch mount (yeah, I know that is not easy to do), and re-connect pin/clip and all is good.
Is this viable or not? If so, is there any undue stress placed on components when they're un-hitched from truck and "hanging" on the trailer?
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 05-11-2007, 06:10 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I've seen people do it, so it can be done.
Old 05-11-2007, 06:59 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
With the spring bars engaged?! Stating ignorance of Blue Ox, if the tow vehicle pulled away I'd think the hitch bar front (part in the receiver) would snap down as soon as it cleared the receiver. Terry, did the tongue jack take a beating? Now... would it be more possible with the spring bars slackened?
And hitching up again ... wait -- already said.
5 meter Langford Nahanni
Old 05-11-2007, 09:36 AM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You would need to release the weight distribution bars first. But anyhow, trying to get the hitch back into the receiver later will take all the fun out of it. One great advantage is in case of fire. Just pull the pin and scoot out of the way.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-11-2007, 02:19 PM   #5
Blaine , Washington
I have a heck of a time manually sliding the hitch into the receiver so that the holes for the pin are perfectly lined up to take the pin. I have to wiggle and curse before it happens. Good luck on trying to back it in and stopping at just the right place.
Relentless is offline   Reply With Quote
Old 05-11-2007, 04:23 PM   #6
Excella CM's Avatar
Venice , California
One thing you can do to make the alignment of the hitch into the receiver easier is to get it into place with the pin in and then drill a 1/4" hole into the hitch bar directly in front of the mouth of the receiver. Install a rollpin into this hole and you will have a positive stop that automatically aligns the hitch. If you use only one TV , you can weld a tab on the hitch bar to do the same thing.
Old 05-11-2007, 07:49 PM   #7
Well Preserved
1993 21' Sovereign
Yes, it was eventful. And I was not around to see them hitch back up. But, it was done, just by "pulling the pin", and driving out from under it.
Hensley To Equal-i-zer Hitch Experiment DreamStream Hitches, Couplers & Balls 71 04-08-2009 09:26 AM
Hitching up with a Hensley GreggH Hitches, Couplers & Balls 7 02-04-2006 07:17 PM
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
