Old 09-01-2014, 02:31 PM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Video PP hitch install?
There's lots of videos on YouTube about hitching to your ProPride but I haven't seen one on installing one - or taking it off to grease the ball and reinstall (a friend who has a Hensley put a zerk on the ball fitting - genius! ).
Anyone got video of this they could point to?
If not - is anyone willing to video the process of dismantling yours and re-installing?
If someone wants to do it on my trailer, I'll film it! :-)
SteveSueMac is online now   Reply With Quote
Old 09-01-2014, 03:44 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Greasing the ball is easy. Simply put a large block of wood or concrete block under the main part of the ProPride head, lower the tongue using the tongue jack, release the coupler lock, raise the tongue, apply grease, lower tongue, re-lock the coupler lock, and raise the tongue to its original position. It's almost as fast doing it as it is typing it.
Old 09-01-2014, 03:48 PM   #3
Well Preserved
1993 21' Sovereign
While not a video, this may help:
https://www.flickr.com/photos/rests/...7618684477177/
Old 09-01-2014, 04:34 PM   #4
1976 31' Sovereign
Oswego , Illinois
All I see is a lot of steel that is heavy and hangs low still uses spring bars, I will stay with my original Reese dual cam hitch it is not new style with threaded adjustment that has been a weak point in my estimation and lots harder to adjust, older style still can be found, no heavy lifting or complexity with Reese hitch
Old 09-01-2014, 05:34 PM   #5
W , New England
Well that does sound easy! Thanks. Thanks to do the link to the pics, but I'm lost :-(
Next person who buys and installs one of these has to do a video, ok?? :-)
Old 09-01-2014, 05:36 PM   #6
W , New England
Super - not sure how that adds any value whatsoever to this thread, but glad you're happy with your hitch. If you ever install a ProPride - perhaps you could video that and post it? :-)
Old 09-01-2014, 05:45 PM   #7
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Hi Steve:
I won't be of any help. But because I also have a PP hitch, how often do you feel we should be greasing the ball?
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-01-2014, 05:53 PM   #8
dznf0g's Avatar
Oswego , Illinois
I find once a year is sufficient on my HAHA...should be the same on a PP. That translates to about 5000 miles. Adjust your schedule accordingly.
-Rich-
Old 09-01-2014, 07:10 PM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If the ball squeels like a just "cut" pig, it needs grease!
Old 09-01-2014, 07:14 PM   #10
Well Preserved
1993 21' Sovereign
On a ProPride or HaHa, the ball doesn't pivot or move much. At most, there will be some rattling and clanking.
Old 09-01-2014, 07:24 PM   #11
W , New England
I don't have any squeal - I just noticed that part of the installation process was to grease the ball. I didn't install it - my dealer did. At some point, I'd really love to learn how to do it....
Old 09-01-2014, 09:27 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
As mentioned above, lower tongue onto a support like wood block. Release the hitch. Raise the tongue of trailer. The PP should detach from the tongue hitch. Raise until clear of "ball" mounted to PP.
Carefully ensure trailer and pp are stable. Now , clean off ball old grease (I use a rag saturated in WD40. Clean inside hitch carefully. Regrease.
Carefully lower trailer tongue onto the PP ball. Relatch hitch. Raise trailer.
I used a low clearance floor jack to lower and raise the PP from the hitch.
My son was there to help stabilize the PP.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-02-2014, 09:19 AM   #13
switz's Avatar
2014 31' Classic
Images: 8
For additional safety after raising the hitch off the Hensley or ProPride ball, place jack stands under each side of the "A" frame so a hydraulic jack failure does not result in injury.
Old 09-02-2014, 09:22 AM   #14
2016 30' Classic
Erie , Colorado
I do the floor jack method. Takes only a few minutes to clean and grease. I have a can of Reese Hitch Grease that never seems to run out.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NŘVPN
ghaynes755 is offline   Reply With Quote
Good Video or 'How To' On Hooking Up to Hitch? mrpettit Towing, Tow Vehicles & Hitches 10 06-19-2014 04:41 AM
Video: New Video from our 2010 summer trip to Austria (Alps) and South Germany aheun Global 'streaming 9 09-28-2010 03:54 PM
