Old 04-30-2008, 12:05 PM   #15
Hensley Ron's Avatar
Oxford , Michigan
Originally Posted by 2airishuman
no hitch is worth cutting up a new trailer, it's hensley's problem, so solve it...
vendors.
cheers
2air'
Umm...I didn't design the truck. It is not my problem, it is GM's problem. I won't be making a 10" drop bar because that would create too much stress in the receiver.
I was asked for suggestions, so I'm making them.
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Hensley Ron is offline   Reply With Quote
Old 04-30-2008, 01:54 PM   #16
_
Originally Posted by CA Streamer
Have you thought about using a drop receiver?...
hey ya ca' !
these could work for the op, given he's towing a 22 footer...
but the lower bumper fascia would still need some surgery.
on mid size or larger trailers i'd be very concerned about the drop extension handling all the stress from the arrow...
Originally Posted by Hensley Ron
Umm.. It is not my problem, it is GM's problem.
I won't be making a 10" drop bar because that would create too much stress in the receiver...
it's this sort of attitude that contributes to the decline of many products.
so as ford and others build 3/4 and 1 ton vehicles with >21 inch high receivers,
we can ALL remove the hensley from our hitch options.
premium price carries the expectation of premium product, service and response to changing needs...
IF a 10 or 12 inch drop bar was available and the "receiver stresses" become an issue...
THEN the problem does shift to those who design and fabricate receivers.
cheers
2air'
Old 04-30-2008, 02:31 PM   #17
Oxford , Michigan
It wouldn't be very ethical of me to make a 10" drop bar, knowing it would cause problems.
We're getting off track, here. I don't make receivers, so I'll leave it up to my friends over at Putnam and Reese to come up with a solution on the truck end. That will certainly happen long before GM makes a change.
The coupler change is the best solution I've heard. Inexpensive and won't look ugly. As far as warranty, maybe someone needs to tickle the ear of an Airstream rep about that. I'm sure someone's already tuned in over there, given the popularity of the Suburban/Airstream combo.
By the way, I have a GM truck (Avalanche), my 4th one. So I like their products, too. This isn't the first time an OEM has made a change that caused the RV industry problems. We always work them out.
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Old 04-30-2008, 02:58 PM   #18
_
the op has a 23 inch high receiver...
this is MORE that an 8 inch bar will accommodate...
the 2008 FORD SUPERDUTY 4x4 also has this height on the receiver...
the only OFF track suggestion is to modify a 50-100,000$ trailer when other hitch options exist...
or suggesting a/s is looking into this, or that it's ge'em issue ...
there will be LOTS of folks with this issue on NEW TOW VEHICLES...
while the hitch vendor that IS the subject of the thread is ignoring this issue.
Originally Posted by Pete Vermont
....I just picked up my new 2007 22 ft Airstream ordered with a Hensley Arrow hitch as a result of comments on this BB...
so another option for this member is JUST RETURN THE CONTRAPTION, it's still within 90 days right?
if the hitch cannot be used safely and without altering the trailer or tow vehicle...
and the maker suggests it's someone else's problem, spend the 3,000 $ on some other approach.
cheers
2air'
see the FORD pic below for just a few 100,000s of potential tow vehicles...
Old 04-30-2008, 03:28 PM   #19
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
2air'
Howdy 2air
The receiver is adjustable to 10" which should clear the bumper fascia easily (at least it looks like it if you look at post #3 photo)... no mods needed. I would adjust it so that it clears the fascia and swap out the 8" Hensley drop bar for a straight bar, 2", 4" or 6" drop...whatever it takes to make up the difference so the trailer rides level.
The 22'er is fairly light...definitely wouldn't want to use it for your 34'er or my 28' slide out.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 04-30-2008, 04:06 PM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Howdy 2air
Sorry, but I see no way this receiver is adjustable vertically, how is that
done? As you can see it bolts directly into the frame rail extensions.
(IF this is the reciever in question)
Name:	2007 SUB #2.jpg
ID:	59497   Click image for larger version
Name:	2007 SUB #3.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-30-2008, 04:15 PM   #21
TinShack's Avatar
2005 28' Safari S/O
Actually Robert, we were discussing the drop receiver in post #14 and if it would work with the Tahoe's receiver....
Steve
Old 04-30-2008, 09:27 PM   #22
_
...my new 2007 22 ft Airstream...
hi pete...
did a/s make ANY 22 footers in the 07 model year?
other than the safari sport, which is an 08 i think.
i though the 22 ft ccds stopped in 06.
does YOUR unit have 14 inch tires/wheels?
IF so, the wheels/tires could be replaced with the more common 15s and that would raise the trailer a tad...
perhaps enough to get ya level hitching with the 8 inch bar...
just another idea.
cheers
2air'
Old 05-01-2008, 08:50 AM   #23
Opp's
Kinda what I thought....we need a glossary.
PFC
"Tahawus"
RLC
John Prine
Old 05-01-2008, 12:16 PM   #24
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
cheers
2air'
I didn't know that the Ford's SDs were also same height...
Looks like Hensley does need to look at a refresh in design to accommodate the newer truck hitch heights.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 05-01-2008, 01:29 PM   #25
Oxford , Michigan
That's about what it will take, though "refresh" is putting it lightly. Fortunately, we're looking at new designs already. Unfortunately, that's not fast enough to help out you guys right now. All the ideas posted here are good ones, but not the final solution.
Back to the drawing board...
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Old 05-01-2008, 05:25 PM   #26
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
That's about what it will take, though "refresh" is putting it lightly. Fortunately, we're looking at new designs already. Unfortunately, that's not fast enough to help out you guys right now. All the ideas posted here are good ones, but not the final solution. Back to the drawing board...
Ron,
We spent some time with Kevin & Prim last weekend or so, talking about the hitch (they love it)... this was sometime after talking with 2Air in Branson (he loves it)... well, maybe "loves it" is a bit strong, but they do swear by it.
$3 grand is alot of bucks to spend, so the company behind the product is the clincher in the deal. Too many businesses use the popular cliche "customer #1" and "service is our goal", and so on and it's usually not more than words on letterhead.
We are seriously considering either the Hensley or ProPride.
This is an issue after market manufacturers have to pay attention to. We're paying attention to it...
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 05-02-2008, 06:36 AM   #27
Oxford , Michigan
Jaxon, you're right. The aftermarket companies have always had to keep up with the trends in the OEMs. It's just part of the business. This receiver issue will, no doubt, push us into a major re-design. After 15 years, maybe it's time anyways.
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Old 05-03-2008, 04:17 PM   #28
valletta , malta
Hi
The last post from C. A Streamer helped me a lot, Bearing in mind I intend to tow a 34 footer with an H2 ,and just to be totaly clear, should I go for the maximum drop tow hitch (10 inches not twelve or who does a twelve? it is mentioned that a twelve is not available) and be done?
Best Regards
Philip
bronywolfe is offline   Reply With Quote
Receiver Hitch pin hole repair ? Davis Hitches, Couplers & Balls 17 06-15-2017 06:03 PM
Hitch and receiver rattle Devoman Hitches, Couplers & Balls 53 09-09-2009 08:16 AM
Hitch receiver plaques rangebowdrie Off Topic Forum 10 11-30-2007 02:48 PM
Receiver Hitch Bolts Davis Hitches, Couplers & Balls 2 08-04-2006 09:06 AM
hENSLEY HITCH TCP4 Hitches, Couplers & Balls 20 10-30-2002 05:44 AM
