Old 06-15-2007, 09:35 PM   #1
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Use of jack stands results in crushed propane line
I hate to admit what I did, but maybe my "confession" will keep someone else from making the same stupid mistake. My wife was concerned about how extended the hitch jack was, so, since we were at home, I got a couple of jack stands out of the garage and placed one under each side of the tongue rails.
What I didn't notice was that the line from the propane tanks on our 2003 Classic 25 runs under one of the rails. Several days later, while checking the air in our spare tire (we are getting ready for a long trip), I noticed that the line had been crushed by the jack stand! I was able to replace the damaged section of the gas line without too much trouble. We were very fortunate to find this problem before we left!
In the attached photo, you can see two crushed areas. I had to move the jack stand to lower the spare and that is when the front crushed area occurred!
Name:	crushed gas line.jpg
ghatfield is offline   Reply With Quote
Old 06-15-2007, 10:31 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Oops! I think that's why they put a valve on the tanks.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-15-2007, 10:32 PM   #3
TIMETOGO's Avatar
1988 29' Excella
PATAGONIA , Arizona
Life is a dance, you learn as you go.
TIMETOGO is offline   Reply With Quote
Old 06-16-2007, 05:30 AM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Ouch, but shame on AS! I am in the process of putting all new lines in our '60 Tradewind and I ran them inside the tongue frame to protect them from any road hazzards or mishaps like yours. Thanks for posting, you very well may have someone else from the same circumstance!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 06-16-2007, 05:39 AM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I agree. Seems like a dangerous location for gas lines considering so many will be attaching w/d hitch brackets along the tongue frame there.
mojo is offline   Reply With Quote
Old 06-16-2007, 06:54 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's still a good idea to use support, especially when working under them. A colleague of mine was killed day before yesterday when a car he was working on fell on him.
Old 06-16-2007, 07:14 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree with Terry, if it's a matter of a crushed line or something worse, even not as severe as an EOL (end of life) event, I'd take the crushed line.
In the end, we've all had our moments. But I'll pay even more attn to that area now that I've seen some pics.
Old 06-16-2007, 08:02 AM   #8
ghatfield's Avatar
2006 19' Safari SE
Fix for crushed propane line
Here is an image of the repaired line. The line on my AS is 5/8" and all the parts and tools were readily available from Lowe's. The "soft" copper tubing is normally only available in rolls, but they were willing to sell me a couple of feet from a damaged roll.
George
Old 06-24-2007, 11:03 PM   #9
1992 34' Limited
Falls Church , Virginia
Still using jack stands!?
George -
Thanks for the great photo documentation on the 'repair' you did. Notice that you still have jack stands employed.... Why? Doesn't you AS have the normal stabilizers that come with every other AS?
Curious.... as the problem came about with the use of jack stands, and there they are again...
Thanks!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 06-25-2007, 07:02 AM   #10
Well Preserved
1993 21' Sovereign
From reading your original post, your wife was worried about the tongue jack being extended too far. Why not go to your local home improvement store, and get a railroad tie? Cut about 12-14" off, and use the 12" piece to go under the tongue jack. They are more than sturdy enough to hold your trailer, with proper support they can hold a 125 ton boxcar, and do so for 20 years, one should be able to support the 600 or so pounds of your trailer's tongue.
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
Jack Point 74Tradewind Jacks, Stabilizers, Lifting and Leveling 1 05-15-2002 06:27 PM
