Old 07-31-2015, 04:33 PM   #29
2014 23' Flying Cloud
Rhinebeck , New York
Thumbs up
Originally Posted by phlegm View Post
How about something like..
If your driveway is flat enough you can pull it by hand.
If not, you can improvise a way to tow it with the mini-ex or a riding mower, or even if you are brave.. use this in the front to steer and PUSH the trailer with the mini-ex.
MaxxTow Trailer Dolly with 1-7/8" Hitch Ball - Black Powder Coated Steel - 600 lbs MaxxTow Hitch Accessories MT70225
I bought a battery powered unit something like the manual one shown. It has two good size tires and a powerful electric motor run by the 12V battery. This thing will pull our 23' IngternationalSerenity if on a smooth and hard surface. Macadam for example. Our unit is new and unused as we have gravel drive surfaces and the tires simply dig-in rather than pull the Airstream. I recommend the product to pull and maneuver trailers where the surface is "hard." Special tires for the unit are available…….maybe I'll get some!! All the best!!
Adam Geuss is offline   Reply With Quote
Old 07-31-2015, 06:30 PM   #30
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
I must have missed something. You want to get the AS into your drive nose first. Then what? Will it always stay there in that position? How will you hook it up to your TV to exit and go RVing?
You could always back the AS into the driveway, chock one side and use a dolly wheel on the jack post, and rotate the AS so it winds up the way you want, but then, you would have to reverse that to get it out. What are you trying to accomplish, big picture?
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 07-31-2015, 06:31 PM   #31
lcurrie's Avatar
2005 19' Safari
Use a Mini Excavator to Move 19' in Driveway?
Adam, where did you get the motorized trailer dolly? My driveway has a slight incline, maybe 3%?
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 07-31-2015, 07:49 PM   #32
Could you just back it in?
itldo is offline   Reply With Quote
Old 07-31-2015, 07:55 PM   #33
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Could you back it up the driveway then turn it around with a dolly at the top? I've turned mine 180 deg with just a comalong <sp?>.
jbxx is offline   Reply With Quote
Old 07-31-2015, 07:57 PM   #34
I also have one worktruck with the receiver mounted on the front.
Old 07-31-2015, 08:11 PM   #35
2015 30' FB FC Bunk
Ayer , Massachusetts
I would say with the right ball hitch attachment on the excavator bucket it would be no problem to move. Mini excavators vary in size, so if it is really small it might be a challenge. Maybe flip the bucket and attach the hitch to the underside of the bucket. I do it with a Bobcat, much easier.
More importantly, you need to know the machine pattern, you will need to make compound movements. If you can't operate one now, don't learn on an Airstream. Not worth it. Maybe back it in, then with a wheel on the tounge jack, spin it around. Not sure what a 19' weighs
Ted S. is offline   Reply With Quote
Old 08-01-2015, 11:45 AM   #36
2015 25' International
Rittman , Ohio
Lawn Tractors/Trailer Dolly
We encountered a similar issue. We pull our 25' Serenity into the driveway and back it into our turnaround. We then detach the TV and get it out of the way. Initially, we used our Kubota BX2350 (lawn tractor on steroids) and put a 2" receiver on the 3-point hitch. After much searching, we found that the tractor said we could accommodate a 600 lb hitch weight, while the trailer has an 880 lb hitch weight. With a family of engineers, we decided that if we fixed the height of the hitch and lowered the trailer onto it, it should work and not overload the hydraulic pump. We also put the snow plow on the front of the tractor for counterbalance weight. It worked, but the steering was a little light. Since then, we've invested in a Parkit360 electric dolly with the trailer brake option (our drive has a slight slope). For straight pulls, that works well. You can make corners, but you have to work at it. And, it's small enough to store in the back corner of the garage.
Rabid54 is offline   Reply With Quote
Old 08-01-2015, 02:12 PM   #37
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by lcurrie View Post
Hi All,
I'm trying to get my Bambi into my driveway hitch first, which means pulling it in. I'd then like to get the tow vehicle out. I won't bore everyone with all the details of my driveway, but if I use the car/truck to do this, I'll need to leave it in the the driveway, there would be no way to get it back out.
I have access to a mini-excavator and am wondering if that would work. Would it be strong enough? If so, the next challenge - how could I attach a hitch receiver? I've seen the hitches that clamp on to buckets, but the reviews say that they only work with light weight trailers because they'll twist.
Since the mini-excavator isn't mine, I don't want to make permanent modifications to it. Maybe I can remove the bucket and have something made/welded that will attach to arm?
Thoughts?
Lynn
One of these for ~ $65 and a few friends, moving it will not be a problem.
600 lb. Heavy Duty Trailer Dolly
4 pulling on the front (2 on the dolly & 2 on the chains or use rope)
2 pushing on the back. Just tell your friends not to push on the skin, except directly on a rib.
I have a 1,600 lb 17' long utility trailer I move around by myself.
Alan
Old 08-01-2015, 04:03 PM   #38
lcurrie's Avatar
2005 19' Safari
Thanks again for all of the info. Here's the plan, which is already in motion:
  • Winch - acquired off of Craigslist today per Channing's tip.
  • Trailer dolly, jack with wheel, or just a wheel for my existing jack - still thinking a bit on this one. I like the dolly route because it has the knobby wheels and I'm going to have to create a plywood path over the grass center on my driveway for the wheel(s) to roll. Liking the wheel on a regular jack idea because it's one less thing to store + it will require 1 less thing to have to man during the move. Is it safe to assume the weight ratings on those are for the tongue weight and not the trailer weight?
  • Chocks for the wheels during moving - aquired
  • 12V battery for the winch - will likely swipe out of my car to use since I won't need it often.
  • Post to attach the winch to and lay across driveway in front of carport posts - hoping to borrow this from one of several friends. Again I don't want to store anything I don't have to, but if needed I'll purchase from Home Depot.
Lynn
Old 08-01-2015, 04:52 PM   #39
Parking your Travel Trailer
The unit is a "Parkit 360" which we purchased on line. I am confident the unit will pull and maneuver well over our 6000lb (max weight TT) on hard surfaces. Concrete/macadam etc.. A 3% grade should not matter with the weight of your TT. Check out the item on line. Remember the unit requires a battery (you buy separately). If you are interested in purchasing one send me an email…adamgeuss1945@gmail.com If opportune we will sell at 1/2 price. New and literally unused with battery. Hope this isn't against the Forum rules. I really am not a seller of things. I like to buy…….Hmmmm.
Old 08-01-2015, 06:00 PM   #40
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Lynn
Yes, the ratings of the trailer dollies are the tongue weight, not the trailer weight. I use one of those manual HF units to drag my trailer around. It is rated to 600 lbs tongue weight, and my trailer weighs around 4500 empty--haven't had any worries using it.
Belegedhel is online now   Reply With Quote
Old 08-06-2015, 04:25 PM   #41
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
As I read the thread, I was hoping someone would suggest a winch. It's an interesting idea for a straight pull. Hope it works well for you. If you have a Harbor Freight, Tractor Supply, or similar discount store in the area, they have wheels and other inexpensive hardware that can be used for light duty applications. I use one of their swivel casters on a light boat trailer and it's easy to push on level ground. Takes two to three guys to push it up a ramp, so the winch is something we have considered. Hope this works for you. Pat
Old 08-07-2015, 05:40 AM   #42
Gainesville , Florida
Something to think about. Was watching a truck driver winch a trailer from a flat bed truck and the winch gears broke. The trailer boogied down the ramp at warp speed hitting nothing and stopping mainly because the truck driver pulled the breakaway switc just in time. Be sure the winch is powerful enough, the cable is in good condition. The gears can strip if overloaded and a runaway occurs. Slow and deliberate. Good luck.
ProPride hitch use when storage firm needs to move trailer Wanna EB Hitches, Couplers & Balls 9 11-10-2013 08:48 PM
Driveway camping with new mattress! 85MH325 Our Community 11 05-04-2004 03:42 PM
Bambi's back in our driveway! KY Girl Our Community 5 05-07-2003 07:21 AM
Attention: Driveway Campers _ time to hit the road ! femuse Our Community 5 04-04-2003 12:01 AM
