Have a '01 K2500 Burb - 6L, 3,73 gears - Schefenecker mirrors. It pulls SilverToy. SilverToy is a '92 34' Classic Limited. The TV has (Class 3 or possibily IV) the standard GM hitch and I have heard that these hitches can serve quite fine.
On the other hand, Have read about some failures where the basic bolt on hitch bent some distance and caused all mannor of unneeded driving drama. To fix that, I have looked, read, consulted and have the following to offer as a possible upgrade. There is a way to weld angle iron in on, a diagonal to a frame cross member from the rear of the receiver tube. This seems like it would add quite a bit of stiffness and certainly eliminate the hitch issue where it would bend.
Haven't even gone and done any 'price' consideration prep work yet. Perhaps there is someone here that can 'make me come to my senses"?
I'll toss it out to see what I get. Will decide there-after.
Thanks for any an all that took the time to answer me.
Pay attention to labels that may be still attached or may have been removed from your factory hitch. Many times the manufacturer will state that nothing is to be altered or welded to the hitch platform.
I've seen photos of similar improvements elsewhere; one installer went around either side of the spare tire so it could stay in place.
The warning about welding is liability protection for the manufacturer. The receiver is no doubt made of low-carbon mild steel, so hardening of the steel from welding is not going to happen, and you'd be making it stronger and safer in any event. Also, removing the flex will aid weight distribution.
However, depending on your tools and your skill, it may be easier to throw away the OEM receiver and install a good aftermarket unit. Putnam seems popular, and I've seen a Valley Industries unit on a full-size GM van that I was impressed by.
Axel, If you're really that concerned about it, I think that for all of the effort and expense in upgrading what's on there, you'd probably be better off just replacing it with a good quality, well-engineered class IV hitch reciever and be done with it.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein 2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Your 34 footer represents some serious weight issues. If you can confirm that you have a Class III it should be replaced with a higher rating hitch.
Just in case you decide to take the homemade approach for this or any other project that involves welding; take precautions to protect the vehicle's computer system. Often disconnecting both terminals on the battery will work but check with an authorized dealer first.
Tow safe,
em.
__________________ Travelers by aluminum roadships, loyalists to one species, masters of convenience, herdsmen steeped in maintenance and restoration.
Good to see that others have the same general thought as I am having. Current hitch is standard GM with the HD K2500 set-up. No signs of issues, but this is something that I feel is easily upgraded so I can concentrate on other 'possible' issues.... nothing like having that 'upgrade' itch, is there?
Will look into having a local welding place - VERY highly recommended! This is a place that hasn't advertised in 30+ years, but still has more business than they can handle.... all word-of-mouth. Got recommends from all over town for about 3+ years now. Does it get better than that?
It will likely be that a new C5 hitch will be as/ more cost effective than adding to the current set-up. Now about which brand of C5??? Seen 2 thoughts already... any others? Anybody have Curt experience?
If you're comfortable crawling under the back of your truck and wrenching, install it yourself. The new one will likely require just 6 1/2" or 5/8" bolts. Find someone to help to get the new one in place, and use a jack (floor jack or bottle jack) and a piece of lumber to keep the receiver in place while you fiddle with the bolts. The receiver will get heavy very quickly.
Axel, I had a Curt Class III on a Ranger pickup. They're obviously built quickly with a fair amount of slag not ground off. Some of the welds may not be the prettiest work you've ever seen. The edges aren't milled well, and they appear a little crude by some of the other manufacturer's standards, but they're as strong as any product out there, and they certainly do the job. They're painted, not powder coated, so it's best to keep a can of Rustoleum nearby and use it liberally. Other than that, they'll do fine.
Roger
Had a quote yesterday from a local hitch shop for a Putnam class v with a 2" receiver, $250 plus tax installed. Seems pretty cheap to get lots of muscle and not worry about anyone's welding skills. JMHO.
