Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 03-21-2007, 12:56 AM   #1
Profile:  1992 34' Limited
Falls Church , Virginia
Upgrade the Current hitch?
Hello all -
Have a '01 K2500 Burb - 6L, 3,73 gears - Schefenecker mirrors. It pulls SilverToy. SilverToy is a '92 34' Classic Limited. The TV has (Class 3 or possibily IV) the standard GM hitch and I have heard that these hitches can serve quite fine.
On the other hand, Have read about some failures where the basic bolt on hitch bent some distance and caused all mannor of unneeded driving drama. To fix that, I have looked, read, consulted and have the following to offer as a possible upgrade. There is a way to weld angle iron in on, a diagonal to a frame cross member from the rear of the receiver tube. This seems like it would add quite a bit of stiffness and certainly eliminate the hitch issue where it would bend.
Haven't even gone and done any 'price' consideration prep work yet. Perhaps there is someone here that can 'make me come to my senses"?
I'll toss it out to see what I get. Will decide there-after.
Thanks for any an all that took the time to answer me.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 03-21-2007, 04:11 AM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 76
Everyone loves a good horror story
Originally Posted by SilverToy
... Have read about some failures where the basic bolt on hitch bent some distance ...
What were the circumstances of these failures? Can you share either a link or a few more details?
My '99 Silverado 2500 has, I believe, the same hitch your 'Burb does, and I think I understand where you are thinking about reinforcing it.
If I was concerned about potential hitch problems, I would investigate replacing the hitch with either a certified Class V hitch or a Pullrite.
Tom
Old 03-21-2007, 05:37 AM   #3
Silverhobby's Avatar
Profile:  1964 17' Bambi II
1956 26' Cruiser Overlander
1957 26' Overlander
Vale , North Carolina
Hitch Warnings
Pay attention to labels that may be still attached or may have been removed from your factory hitch. Many times the manufacturer will state that nothing is to be altered or welded to the hitch platform.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 03-21-2007, 05:44 AM   #4
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 35
Have a look at post #76 http://www.airforums.com/forum...a-28364-6.html
Old 03-21-2007, 06:55 AM   #5
Profile:  1975 27' Overlander
In the Kootenays , BC
I've seen photos of similar improvements elsewhere; one installer went around either side of the spare tire so it could stay in place.
The warning about welding is liability protection for the manufacturer. The receiver is no doubt made of low-carbon mild steel, so hardening of the steel from welding is not going to happen, and you'd be making it stronger and safer in any event. Also, removing the flex will aid weight distribution.
However, depending on your tools and your skill, it may be easier to throw away the OEM receiver and install a good aftermarket unit. Putnam seems popular, and I've seen a Valley Industries unit on a full-size GM van that I was impressed by.
AlbertF is offline   Reply With Quote
Old 03-21-2007, 07:21 AM   #6
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Axel, If you're really that concerned about it, I think that for all of the effort and expense in upgrading what's on there, you'd probably be better off just replacing it with a good quality, well-engineered class IV hitch reciever and be done with it.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 03-21-2007, 07:40 AM   #7
empresley's Avatar
Profile:  1984 34' International
1977 Argosy 24
Central , Georgia
IMHO...
Your 34 footer represents some serious weight issues. If you can confirm that you have a Class III it should be replaced with a higher rating hitch.
Just in case you decide to take the homemade approach for this or any other project that involves welding; take precautions to protect the vehicle's computer system. Often disconnecting both terminals on the battery will work but check with an authorized dealer first.
Tow safe,
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 03-21-2007, 07:55 AM   #8
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Exclamation extensive news concerning..
Admittedly old news worth revisiting..
Here's a few threads..
RV.Net Open Roads Forum: Tow Vehicles: Hitch Failure
PickupTruck.com Community Forums: GM Hitch failures
This link shows some SHOCKING RESULTS..
The date is wrong on these pictu
53flyingcloud is offline   Reply With Quote
Old 03-21-2007, 09:37 AM   #9
2airishuman's Avatar
Profile:
we've discussed the ge'em receiver recall issue before...
where is that thread?
there was a batch in 2002 or '03? on the suv side? with a higher failure rate...
and these were/are replaced by the general...
IF the receiver in question is from that batch yes replace it.
IF the receiver is a class 3, which is unlikely, replace it.
IF the receiver is a class 4 with sx of fatigue replace it.
IF a/s tongue mass is 1200lbs or more replace it with a 5.
gotta weight it to know...
road ruler's 3rd leg looks really functional and done nicely,
but a new receiver is not much more coin than mystery welding.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-22-2007, 12:34 AM   #10
Upgrade is likely....
Thanks for all the replies!
Good to see that others have the same general thought as I am having. Current hitch is standard GM with the HD K2500 set-up. No signs of issues, but this is something that I feel is easily upgraded so I can concentrate on other 'possible' issues.... nothing like having that 'upgrade' itch, is there?
Will look into having a local welding place - VERY highly recommended! This is a place that hasn't advertised in 30+ years, but still has more business than they can handle.... all word-of-mouth. Got recommends from all over town for about 3+ years now. Does it get better than that?
It will likely be that a new C5 hitch will be as/ more cost effective than adding to the current set-up. Now about which brand of C5??? Seen 2 thoughts already... any others? Anybody have Curt experience?
Hitch $300 or so? Install? Do it myself? or not?
Thanks again!
Axel
SilverToy
Old 03-22-2007, 04:27 AM   #11
If you're comfortable crawling under the back of your truck and wrenching, install it yourself. The new one will likely require just 6 1/2" or 5/8" bolts. Find someone to help to get the new one in place, and use a jack (floor jack or bottle jack) and a piece of lumber to keep the receiver in place while you fiddle with the bolts. The receiver will get heavy very quickly.
Old 03-22-2007, 06:14 AM   #12
85MH325's Avatar
Images: 37
Axel, I had a Curt Class III on a Ranger pickup. They're obviously built quickly with a fair amount of slag not ground off. Some of the welds may not be the prettiest work you've ever seen. The edges aren't milled well, and they appear a little crude by some of the other manufacturer's standards, but they're as strong as any product out there, and they certainly do the job. They're painted, not powder coated, so it's best to keep a can of Rustoleum nearby and use it liberally. Other than that, they'll do fine.
Roger
Old 03-22-2007, 07:51 AM   #13
Roadtoaster's Avatar
Profile:  2006 28' Classic
Byhalia , Mississippi
Had a quote yesterday from a local hitch shop for a Putnam class v with a 2" receiver, $250 plus tax installed. Seems pretty cheap to get lots of muscle and not worry about anyone's welding skills. JMHO.
Greg
Roadtoaster is offline   Reply With Quote
Pingbacks are On
Hensley Arrow Hitch Les Hitches 10 02-28-2007 08:59 PM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
SEO by vBSEO 3.1.0
