Old 09-23-2013, 09:55 AM   #1
2010 25' FB Flying Cloud
Danville , Pennsylvania
up/down control on Barker hitch jack
Sometimes the UP control does not activate. I can usually get it to work by pressing the switch to DOWN momentarily, then again press UP. Is this a switch or motor problem? Is it likely to fail?
pjmoser is offline   Reply With Quote
Old 09-23-2013, 10:22 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are 2 internal parts that simply plug in. Right now I think they are limit swictches but am not sure. Try reversing them or replacing them before giving up on the jack. You can get custodmer service from Barker and they are helpful.
Mr. Barker has become a bit persnickity with me. If I don't stop short of the felly exetended position I will often blow a fuse.
Old 09-23-2013, 11:39 AM   #3
SteveH's Avatar
Common Sense , Texas
It's most likely the switch, and they usually fail in the "up" mode because that's where the load is that requires a higher current draw.
If you're savy about DC theory, you can take the top of the jack off, reverse the output wires from the switch to the motor, and then the intermittent will be on the down, or low current demand side. Eventually you'll need to replace the switch.
Just went thru this exercise on our trailer last month.
Regards,
Steve
Old 09-23-2013, 11:45 AM   #4
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
I just had this problem as well. Just change out the switch, it's easy to do. The cost was like $16 plus postage.
John H
johnhh is offline   Reply With Quote
Old 04-18-2014, 02:45 PM   #5
bfd
1998 31' Excella 1000
Athens , Alabama
I'm having a similar problem with my tongue jack, except that in my case, the 'up' function still works, but the 'down' function has failed. Occasionally it will still work in down mode, but only occasionally.
I tried reversing the control wires on the switch in the power head, and this restores the 'down' functionality, at the expense of the 'up' function. After performing this test, I assumed the switch was at fault, and got a new replacement switch. But this had no effect on the problem; the behavior was still the same with the new switch.
At that point I did a continuity check on the old switch (I should have done that first) and found the switch is functioning as it should.
So it appears I have a good switch and a good motor. That is, the motor still runs perfectly in both directions; only, not without reversing the control leads at the switch. Anybody have any thoughts? I don't want to buy a whole new tongue jack next and find out that I still haven't fixed the problem.
thanks,
Bruce
Bruce Davis
1998 Excella 1000 31'
2008 Tundra
bfd is offline   Reply With Quote
Old 04-18-2014, 02:48 PM   #6
SteveH's Avatar
The only thing I can think of, and this is just a guess, but maybe an intermittent limit switch. Or, possibly a resistance connection at one of the connectors.
Regards,
Steve
Old 04-21-2014, 10:18 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Change out the switch...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-23-2014, 06:04 PM   #8
bfd
Athens , Alabama
Yeah, tried replacing the switch. I ended up just buying a new Barker jack and took the power head off of it, then replaced the old one with it. Maybe not the most efficient or cost-effective approach, but it fixed the problem. And it looks very nice.
Bruce Davis
2008 Tundra
