ok we are started...
i've got lots of bits and pieces to eventually put here...
in no particular order...
buzzy4/ed, asked a few common questions
http://www.airforums.com/forum...06-post36.html
so i'll offer up a reply...
1. semi turbulence
2. crosswinds
3. hitching on uneven surfaces..
ed...
1. semi turbulence...
there is lots of good info on semi turbulance (bow waves and the venturi effect)...but an interesting fact is that oncoming trucks give us less of this effect than passing/overtaking semis...basically the fraction of a second for oncoming trucks and the 1-3 seconds for overtaking trucks creates a greater push/pull and as drivers we have more time to over react....also we usually see the oncoming trucks better than the overtaking ones...so even big box trailers feel less from fast approaching semis...now as for how the haha impacts push/pull turbulance...another time...soon.
2. i wondered about cross winds too. coming from a moho to a trailer and living in 'oz' ,
i've driven in lots of crosswinds. airstreams all handle this issue better than 'boxes' imo.
but i've seen a lot of trailers moving down the road angled behind their tv because of wind.
one can also see the constant steering corrections from many drivers....
i've seen long rows of semis and 5th wheels on interstates...all bents slightly at the hitch from wind...
so during the first few weeks using the haha i regularly thought about crosswinds...
the constant ones that blow and the effects of overpasses or interupted crosswind...
of course many things effect how wind forces are felt. tires, pressures, alignment, mass, load distribution and so on...
my experience with the haha is that it stays uncanningly straight, right behind the truck...while others are crooked and wagging.
if someone else drives while i focus reward, what i do see is 2-4 inches of movement at the front of the trailer side2side, not at the rear.
the hitch design allows small lateral movements at the front...but the design of the haha makes fishtailing of the 'trailer only' nill.
in other words the drive wheels/tires of the tv would have to slide sideways for fishtailing and they don't.
so having towed in at least 50-60 mph crosswinds and having been on the edge of some big midwestern storms...
the tv/haha/airstream are calm...so calm that getting out of the truck is often the only clue...
oh and the occasional house that blows across the road!
i did not suggest jack knifeing isn't possilble with a haha and that isn't what you asked.
3. hitching on uneven surfaces...
many suggest this is a deal braker for getting a haha...
i was so clueless about the potential, that i completely missed this when i selected a haha.
yes alignment must be considered when hooking and unhooking with a haha...
but going from zero to 20,000 miles of usage...
this has been a very minor issue for me.
and i've developed 2-3 tricks to make it very easy.
also the owners manual offers some guidelines...
perhaps other users want to share their tricks too!
i'll cover these in another post with pictures which will help more than words...
but i've hooked up at some very odd angles and very uneven surfaces...when i had to.
i mostly travel alone and hook/unhook without any human help...
i've even gotten good at doing it alone while others WATCH....that used to double my time!
so hitching isn't a big deal after some practice...i do it alone.
cheers
2air'
