Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
I did not grease the hitch bar at first. Not doing so extended my learning curve as the unit would sometimes move sideways on me when not perfectly lined up. I decided to try some grease on the hitch bar, and I have gotten hooked up first time, every time since (about 25 hook-ups). Granted, it's messy, but it sure does work. I use the same grease that I put into the Hensley's zerk fittings.
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 4x4x4 (Olivia)
2air, Great paint job. I plan to disassemble mine this winter and paint it the same color. For three thousand dollars the paint job is awful. Mine was showing rust just days after it was installed. Hensley should be ashamed of such a poor paint job, or maybe just add to the first instruction page " painting required".
I don't grease the bar on the Hensley am I suppose to?
Other than a little silicone spray on the wedge portion to faciliate hooking up from time to time.Pappy
hi pappy and welcome to the haha thread...
i don't use lube on my bar either. actually prefer it bone dry.
occasionally spray it with an anti corrosive or ptfe product on the wedged area.
i've met folks who grease 'em, if you are having trouble with hooking up smoothly it can help.
but the grease will attract dirt/debris and is very messy as moosetags reports...
cheers
2air'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
I keep a pair of old GM tire changing gloves on hand for hitch related stuff...they are washable, tough, and provide a good grip.
(Also a box of disposable latex gloves for the tank flushing chores.)
On greasing the hitch bar -the HA book (page 29) says a coating of oil or grease will make latching and removal of the bar easier. I used the same grease used for greasing the spring bar ends....it's messy but works well. It would be easy to weld a handle to the hitch bar....something to think about!
I notice in one of the pictures 2airishuman that you are using the round electric jack stand that airstream provides. If I use that it does not allow me to lower my front enough to level it up in most spots. I just use the hensley
sidewinder device and a board. Just curious?
We have a 6" drop bar that I keep well greased on both ends. When I pull the pin from it in the truck receiver, I slip a heavy duty trash bag over it so it's totally enclosed as I pull it out, and then I put it in a big, yellow, 26" long Plano 681 toolbox. The tools for hooking up are in that toolbox also, but there isn't room left for the black plastic tray that comes with it. To install it in the truck I just pull back enough of the bag so I can see the truck end, and insert it into the receiver while still in the bag. Slip the bag off it and put it back in the toolbox. The toolbox will fit in the storage area in the back of the Airstream, if necessary, and sure makes carrying the drop bar easier.
I had a recent HAHA experience which I think is worth mentioning.
We were on the Road with Lucy and got off the Interstate to take a break. As we came to a stop on the off ramp. Lucy bumped forward hard enough to be felt in the TV. I looked in the rear view mirror and she seemed slightly off center. As I moved forward, she straightened out. When I next stepped on the brake, she slipped to the side again.
Upon inspection, I found that the right side spring bar bracket had slipped to the rear of the yoke about six inches, and the shear bolts had done just that, SHEARED off. This was apparently the cause of the unusual braking behavior.
I readjusted the unit, got new shear bolts and everythig was working fine again.
The next day I called one of the technicians at Hensley and discussed the problem that I had experienced. He told me that the torque on the U bolts that hold the rear spring bar brackets needs to be checked an retightened often. I had not done this and my U bolts had become too loose. The tech told me that a tight turn in a parking lot had probably caused the bracket to slip with sufficient force to cut the shear bolts. He also told me to use only low grade shear bolts so that they will fail before any serious damage is done to the HAHA.
I now have my torque wrench set at 45 foot/pounds and chech the U bolts daily when traveling. I have found on several occasions that tightening was, in fact, necessary. These bolts apparently have a tendancy to loosten.
I realize that everyone else probably already knows this so please excuse my ramblings.
2air--my eyes are bugging out!! I've read every word on this thread. Have new haha on order--should be here by monday--reason for purchase,2 fold
{1} I'm a mechanical kinda guy--this thing facinates me--{2} reciently drove 3 days in 35-40 mph with reese dual cam--not bad but annoying wag that kept me on my toes.---one more reason--they were on sale.--will keep you posted on my exper.--pieman
Thanks for the bolt info... I will check them before our next trip!!
As far as grease, I spray wd 40 on the hitch side now and then, but I keep the other end dry.
As far as the paint I will have our hitch head sand blasted and repainted silver... I did call Hensley and they will send out new stickers at no cost... The only sticker that they can not replace is the red one with the serial #
They told me to remove the serial number and keep it in my owners manual...
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
Pieman- another tip since you are ordering a new HAHA - if you keep a good coat of car wax on the orange casting, it will stay orange. Otherwise, it will quickly turn pink, and then you can paint it black, or puple, or green...
A HAHA is "supposed" to be orange. It is done that way so that passersby will ask you, "Hey, what the heck is that orange thing hooked to your trailer?"
