Prompted to increase WD based on CAT numbers only… performance of the rig as a whole is outstanding… frankly, I was very surprised to see such disparity between steer/drive
Full TV gas tank. Tool box in hatch. Full LP tanks (two thirtys). Full fresh water holding. Both OEM batteries.
Steer: 3280
Drive: 4600
Trailer: 7940
1400# bars
‘Burb has ClassV Reese Tow Beast (using reducer sleeve… maybe some play there..)
Tail of TV is just a smidge lower than I’d like… but then again, I’m maxing out the weight rating on the roof rack…
Note: the CAT numbers above do not reflect passengers and cargo
assuming that only one person is available what is the correct procedure to grease the ball of the hitch of the Aistream? The traler jack component sits on top of the ball and it would seem that the that the Ha Ha would have to be sitting on something or perhaps attached to the tow vehicle before separating the the Ha Ha from the trailer. Sounds confusing but hopefully you may understand. I read that the ball should be grease annually.
While hitched up, raise the trailer off the ball with the tongue jack. Loosen the struts so that they aren't pushing the ball forward in the coupler. The weight of the hitch is supported by the tow vehicle while the tongue jack raises the trailer off the ball.
Just changed from an Equalizer hitch to the Hensley. There has become a tremendeous change in the reaction of the tow vehicle when the brakes are applied. The trailer is now pushing the rear of the tow vehicle to the right. I never had this sensation while using the Equalizer. I can watch the Hensley hitch during braking by using my backup camera. The hitch rotates to the right (curb side) every time and you can see and feel it pushing the tow vehicle. This may belong in the brake area but since this is a new event that started when I installed the Hensley I put it here.
Has anyone else had this experience? If so, how did you handle it. Need a fix quickly since I am leaving for Bozeman on Sunday. Adjusting brakes tomorrow to see if this makes a difference.
I am using a Hayes Genesis brake controller and almost have the minimum power and maximum power settings maxed out.
What you're experiencing is the infamous "Hensley bump". You need to advance the brake controller settings so that the TT brakes engage just ahead of the TV brakes, thereby keeping the Hensley linkage "taut" so it cannot collapse when braking. If your Hayes can't be adjusted to do that, it will have to be replaced.
Gary & Debbie
2001 Safari 25 SS
2001 Yukon 5.3L 3.73 • Hensley • Jordan Ultima • McKesh
Yep, the real fun is going around a downhill curve on the interstate with a crosswind.
In the rear view mirror, you can see the front of the trailer swinging back and forth. A light touch on the manual lever of the brake controller will stop it instantly without slowing you down. Do the Ford integrated brake controllers have this lever on the dash?
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
The strut bars are also not adjusted to the same length.
This, along with the brake controller, is my thought as well. Worth checking.
I've not ever had the "bump", but I have had to go over the strut adjusters on mine before and after a trailer axle alignment; first time, after installation, second, after alignment (trailer still tracked to one side); third, to really, truly dial it in (a job awaiting me).
Once the hitch bar sticks in the hitch box go back to your spring bars to see which one is tightened up. Maybe both. Adjust your jacks until the spring bars are sloppy again and that will adjust the hitch head on the hitch bar. Once they are loose continue to back into the hitch the rest of the way.
Whenever the hitch bar sticks in the hitch head you can always go to your spring bars and you will notice one or both are tight again. That is the hitch bar pushing the inside of the box and making them tight. Just adjust the jacks to make the bars loose again and it will take the pressure off the hitch box and allow you to hitch up. You don't need to continue pulling out and trying to line everything up and then trying to go back in. This is also necessary anytime you adjust the tongue jack when the bar is part of the way in the box. Always adjust the spring bar jacks as the last step anytime you raise or lower the tongue jack.
Another note is that when you get the wedges about 1/2 to 3/4 buried in the opening you can use your over-center-latches to pull the hitch bar back into the box.
Just getting caught up on my reading and just saw this posting.
Last time I was at the dealer the service mgr did "something with one of the spring bars after the hitch bar was mostly in, but not quite. I did not see what he did, but it was quick and loosened up the bar/box so the hitch bar literally popped right in.
