What great timing on a very good topic. Expecting to pick up my 25' fb next week, I have decided to trade in the Sequoia and purchase a solid tow vehicle. (Any suggestions? I was going to look at a Dodge 2500) My other potential investment was going to be the ha ha (great abbrev!). Keep up the thread and educate this first time RV'er.
I have pretty much used all of two small tubes of grease (6" x 1/1/4 dia) and have never seen grease oozing from anywhere. This is after the dealer said they had greased the hitch.
Probably should buy a larger grease gun and use larger tubes?
yea the small grease gun cartridges hold about 1/5th as much grease as the standard size...
as i recall richL used the small size (4 awhile) and it took 20+? pumps before old grease was dispelled from the bushings.
since the haha springbar head/bushings should be greased OFTEN (manual says 500 miles) those little cardridges don't last long...
typically requires 4-6 pumps with the bigger gun, AFTER the bushings are really really filled the first time.
i'm using about 2-3 cartridges/year, and they are also used on the stabilizer jacks.
depends on if you are using the tongue jack to raise the trailer, which reduces the torque required on the screw jacks....
IF tightening without the tongue jack my 18v cordless will just handle the torque needed,
but it spins 'em right up quickly IF the tongue jack is used to establish 'level' first.
i use a typical 3/4" craftsman socket which takes a 1/2" ratchet driver...
there are hex/driver-drill-ractchet adapter-thingies, in all the popular driver sizes that match the socket set...
see pic below.
cheers
2air'
Thanks for the reply.
You may have touched on the something that I am doing out of sequence when I hook up.
I have not been tensioning the spring bars until after I raise the tongue jack.
Got to ask another question, and as far as I know its not in the haha manual, is the correct hook-up sequnce to first tension the spring bars and then raise the tongue jack?
OK, belay last.
After a careful reread I do see that "Step 10" says raise the tongue jack.
That's NOTwhat I have been doing. As I said I have been raising the tongue jack, and then tensioning the spring bars.
