Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
2air I don't have a HA HA but your pics have given me some useful hitch tips... the protective noodle knee knocker, and the hitch up poles... good stuff. Great looking pics of your rig also.. man even though your AS is only 4 feet longer I don't know why, but a 34 footer just looks huge.
__________________ AZstreamin goin' where the weather suits my clothes....
I have two nasty scars on my shins that might match yours...
Because I am also a slow learner I never leave the "stinger" in the Burb. I also have the Enkay mud flaps, so as soon as I get the wheels chocked, I lock the stinger with attached Enkays to the Hensley. I use a the 2 part master lock set to secure the ball latch and the draw bar.
Thanks for the Hensley thread!
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
2Air. Good posts. Thanks. Practice has made a world of difference for me too. I no longer have to think twice about unhooking. Have you modified your TV suspension yet? I'm still thinking about it. See you next spring at Midwest Rally, I hope.
Rich
2006 Classic 34 Front Lounge
2004 GMC Duramax CC SB
Hensley Arrow
WBCCI #5401
AIR #4489
I had the dealer install a Hensley on my 2007 25' Classic that I picked up last Thursday.We've had one day of heavy rain and this thing is showing rust everywhere. When the tech was showing me how to adjust the jacks the paint was just chipping off the jacks as he tightened them. This may be the greatest hitch since the invention, but for 3 grand the paint job STINKS big time. As the paint continues to chip off you can tell that it wasn't primed. I guess quality only goes so far.Maybe they should offer a paint job that would hold up to the elements as an optional upgrade then they could charge a few hundred more. They now offer a cover for $80.00. This will help keep the moisture in so the rust can really do it's job.
agree completely.
mine had large flakes of paint come off early on. it has settled down now.
i don't like the color either.
and don't call them for help with the paint...they don't care about it..
allis chalmers orange from the hardward store is supposed to be a match,
but they could at least advise folks to put a couple of coats of clear coat on, day 1;
that would help.
rich luhr? i think, had his painted to match the a/s underbelly.
i have purchased rust stopper primer and silver/grey and clear coat,
but need a week of dry warm weather...so it will await for now.
cheers
2air'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
How it works? By moving the pivot point forward so that the sideways push of the trailer at the ball tends to push the tow vehicle sideways rather than rotate it. This tends to remove the stimulus for innapropriate understeer corrections that occurs with the usual trailer hitches.
Weight? 80 lb - a bit heavier than most
It also adds nearly a foot to length at the hitch which can be useful in some vehicles to help prevent binding in tight turns.
It is a bit more complex that most load leveling sway control hitches with relatively small moving parts
The ruckus about hitching is mostly a matter of technique although many use the sideways adjustable jack stands to help with final adjustments. The ha does require a different attitude, geometric paradigm, and skill set for easy hitching.
Flame wars? These usually revolve around the binary safety debate involving catastrophic sway, jacknifing, or similar unpredictable loss of control scenarios. Some folks think a mechanical fix is all that is needed to prevent them.
The HA is an ideal hitch if you have a suboptimal towing vehicle. Can Am RV uses it with other adaptations to configure interesting tow combinations.
For a lot of folks the HA can improve handling as one factor in many. Whether it is worth the 5x or so expense over other options is (or should be IMHO) a matter of personal preference. The Pullrite will achieve near equivalent handling improvement for less than half the cost. The Equal-i-zer or Reese Dual Cam are the next step down at less than a quarter the cost of an HA. The most common solution, a friction bar is half that again.
One thing I didn't get around to doing at the I'Rally was taking a survey of hitch types. That would generate some interesting numbers.
