Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-01-2007, 11:20 PM   #309
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by tin sista
So watcha think about a pink hensely hitch??
I LIKE IT!
dat be cool....
how about rainbow? or tie dye?
or beads and rhinestones!
seriously any fun color would be neat but go for durable too...
i've considered something like rhino or linex spray coatings, rough and tough!
be sure to take pictures of the facelift 'sista!
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-02-2007, 09:10 PM   #310
dufferin
dufferin's Avatar
Profile:  2007 28' International CCD
on the go , Canada
Images: 11
After reading the all thread and 1,000 miles with the new AS and Haha I checked it to see how it was doing. I had to tight the trust as they were a little loose... I'll go tomorrow to buy a grease gun as I am already late for the service. What kind of grease should I get?
And I think to order soon a kit from hensley not to be short in case of problem. I am heading to Vancouver and I am right now in Winnipeg.
That's quite a drive and I want to be all set to take care of the haha.
Pdt Canadian Atlantic U. - WBCCI # 6162 - AIR #8059
Attn : IBT
Here's what the free of speech is :
"I may not agree with your ideas but I will fight to death to let you express them"
Voltaire - (rough translation from french)
dufferin is offline   Reply With Quote
Old 10-02-2007, 10:01 PM   #311
ROBERT CROSS
"The Frantic Banana"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 41
Thumbs up Grease That Haha
GREASE...Any good quality automotive chassis grease will work just fine.
I'd recommend a standard size hand grease gun, the one with the pistol
grip handle and rubber hose is easier to use.
As far as the parts kit goes, I did get one from Hensley, I talked them
into including it with the purchase, but you could get most, if not all the
various pins, clips and retainers at any good Home Store...Home Depot
Lowes etc. I'm not sure, but I think Hensley gets $29.95 or so for the
kit. Any good RV supply store like ,Camping World should Have the
zirk grease fitting, there was only one included with kit that Hensley sent.
Good luck on your up-coming trip........Stream safe!!!
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-02-2007, 11:08 PM   #312
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Wink Get yer head on straight!
Originally Posted by hookedonclassic
I took my HA off this summer to lubricate ball etc. Since then I notice that my TV wants to pull to the right when I hit the TV brakes hard. ... Anyone run into that issue. HA looks like it mounted squarely to the trailer.
I had that issue. I'll bet that when you put the Hensley back on you didn't get it perfectly straight. Eyeballing it isn't good enough, I've found. Just one turn on the strut bars can misalign the head enough to cause this issue.
I'm not sure of the factory-recommended procedure, but I cured it by finding a flat straight stretch of road, and repeatedly braking to test the adjustment. After each stop I'd twist both strut bars evenly, 1/4 turn at a time. After 30 minutes of trial-and-error I got it to where I could hit the brakes at highway speeds with hands off the steering wheel and get a straight stop every time (on level ground). Make sure when you're done that both strut bars are tight.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline   Reply With Quote
Old 10-02-2007, 11:18 PM   #313
ROBERT CROSS
W.N.Y. , "
Images: 41
Braking Straight
Originally Posted by rluhr
1/4 turn at a time.
I assume, loosening one and tightening the opposite.
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-02-2007, 11:36 PM   #314
2airishuman
Profile:
well richL is definitely correct about adjusting the struts to straighten it...
the haha comes with 2 small reflective tabs/squares on top...
and these 2 'marks' are used in the alignment process...
it may be necessary, in loosen one side (rc) while tightening the other...
but IF one sticks to 1/4 turns only and makes several stops to adjust,
loosening the opposite side isn't usually needed.
just DON'T OVER TIGHTEN the struts
and always check it on a very straight section of roadway...
i usually touch the brake controller just as it rolls to a stop to pull the trailer back/into alignment.
cheers
2air'
Old 10-03-2007, 04:09 PM   #315
ROBERT CROSS
W.N.Y. , "
Images: 41
Thumbs down NOTICE ANY DIFFERENCE?? (mistake)
OPPS
2AIR, I CAN'T BELIEVE YOU DIDN'T CATCH ME ON THIS.
MUST HAVE BEEN THAT ONE BEER!!!!!!
ID:	46497   Click image for larger version
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-03-2007, 08:43 PM   #316
dpandorf
dpandorf's Avatar
Profile:  2000 34' Limited
Somewhere in Western , North Carolina
Originally Posted by ROBERT CROSS
OPPS
Yep, the jacks are backwards in one.
Duane
Air# 16888
2000 34' Limited
2008 F250 Powerstroke
Hensley Hitch
dpandorf is offline   Reply With Quote
Old 10-03-2007, 10:02 PM   #317
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
And the struts are pinned in different holes curb side is in the center driver in the bottom.
The torque on the curb side front ubolt bolt is incorrect.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 10-03-2007, 11:00 PM   #318
hookedonclassic
hookedonclassic's Avatar
Profile:  2006 34' Classic
Fond du Lac , Wisconsin
Now that would make perfect sense to me because I did have to adjust the strut bars when I put them them back on. And they could be off just enough to make it pull to the right. Any guess which way it needs to be adjusted since it pulls to the right when I brake. My first guess would be the right side is shorter and the left side is longer now. Opinions?
Rich
2006 Classic 34 Front Lounge
2004 GMC Duramax CC SB
Hensley Arrow
WBCCI #5401
AIR #4489
hookedonclassic is offline   Reply With Quote
Old 10-04-2007, 12:40 AM   #319
2airishuman
Profile:
OPPS
too funny...
yep i was too busy looking at the beer bottle brand...
it takes a village...
in haha land.
cheers
2air'
Old 10-04-2007, 02:56 PM   #320
ROBERT CROSS
W.N.Y. , "
Images: 41
Thumbs down U-bolts And Struts
As a matter of fact..the u-bolts arn't torqued at all, maybe some others
have had the same problem. Was tightening them in stages, at 45ft/lbs
three of the lock washers split...off to Home Depot for stainless replacements
2air mentioned that in the original pic's the strut bars weren't quite
parrallel, down to the third hole he said.
Quess I hadn't done both sides when
I took the pic.
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-08-2007, 12:40 AM   #321
ROBERT CROSS
W.N.Y. , "
Images: 41
Thumbs up Haha Shakedown, Letchworth St Park
Well the first haha trip is in the books. Started well and ended even
better.
With the cargo doors of the Burb about a foot further away
we can now hook-up with them open. Using the Hitch'n Rods from
Camping World made it a back up 3 time experience.
Used a nearby vacant parking lot to get used to the different driving
techniques, and to take the four corner measurements for the wd bars.
Ended up at the center mark on the jack bar with three holes showing.
The Burb only needed a little over a one inch shift to the front axle on
a 50/50 split. With no wd we dropped from 36" to 34" measured at the
rear wheel wells. Tried several different settings on the drive home, but
the original seemed to be the most comfortable ride.
Used the NYS Thruway to Letchworth St. Park and the two lane country
roads on the way home. It was simply the BEST DAMN Stream ride I have
ever taken. It is just so nice to see that AS stay right behind the Burb.
Even on the exit ramps you'd look in the rv mirror and you still couldn't
see your rear clearance lights. Absolutely no sway at all, and the most
comfortable tv ride ever. Can't wait for the first "real" trip, 250mi just
not enough
Take a close look at my "one trip" main assembly. If thats powder
coat I'll eat your shirt, will need some attention over the winter for sure.
What do you all think an the wd bar deflection, looks a bit more than
two inches to me, but the ride was so good I always returned to that
setting!! Been Stream'n for 18 yrs, and I feel this has been THE
best Investment I have made, both for safety and comfort.
THE FRANTIC BANANA RIDES AGAIN
Name:	HAHA SHAKEDOWN 007.jpg
ID:	46712   Click image for larger version
Name:	HAHA SHAKEDOWN 015.jpg
Name:	HAHA SHAKEDOWN 024.jpg
ID:	46714   Click image for larger version
Name:	HAHA SHAKEDOWN 008.jpg
Name:	HAHA SHAKEDOWN 019.jpg
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-08-2007, 01:13 AM   #322
2airishuman
Profile:
hi robert...
nice looking rig, pooch and mate!
good report. it IS quite the tow, that's for sure.
looks like you coated the U-bolts too?
nice.
the trailer nose looks a tad high, but on grass and in a pic that's only a guess.
did you measure the trailer for level as well as the burb?
you didn't mention brakes...
the haha/trailer should NOT push the tv at all when braking.
some have had to boost the controller to address this.
as to the crappy paint, it might be useful to apply 3-4 coats of automotive clearcoat.
it will reduce the orange fade significantly.
doubt it will help with chipping.
cheers
2air'
