Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 04-16-2007, 06:33 PM   #225
breakaway's Avatar
Profile:  1989 29' Excella
Bloomfield Hills , Michigan
Images: 20
Is anyone else hearing things?
Hi 2AIR,
The noise happens at slow speed when turning a corner, both left and right, and sometimes when first starting out.
I noticed that he “Frame Bracket” requires grease where the “Jack Assembly” is connected so I will be taking care of that today.
I have also read where some owners have lubricated the “Hitch Bar”, but I truly want to avoid that simply due to the “MESS” factor.
So again I was wondering if anyone else is hearing things? Or is it just me…. I think I hear my Airstream calling me now…
John
1989 Excella 29
Hensley Arrow
Garmin 650
AIR 4580 - Join Date: 03-10-2004
breakaway is offline   Reply With Quote
Old 04-16-2007, 06:40 PM   #226
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 36
When I was watching Silverback hitchup at the Tucson Rally I noticed that he has a fitting on his.....
Richard
Charter Member Four Corners Unit
Old 04-16-2007, 07:09 PM   #227
2airishuman's Avatar
Profile:
where's the noise?
hi john...
how old is your haha?
as always photos may help.
my concerns would be...
1. check the shear bolts; torque 2 spec.
2. check the jacks at the hex attachment; tighten and lube.
3. check the spring bars at the jack extensions; the bolts and little U bracket.
4. check the spring bars at the bushing/grease zerks; are they fully up, is there much play?
5. check the strut assemblies and tighten to 'firm'
6. check the strut assemblies at the pins/main haha body; are the holes worn or stretched.
7. check all the retentiion pins for wear...
and of course...
8. check the reciever for play or wear; the haha puts a lot of stress on the tv receivers
noise isn't a regular feature of the haha that i've found...
like, for example the haha 'bump' associated with trailer brake delay...
we have one report in the thread of what can happen IF the shear bolts back out or break...
and do i recall he heard or felt something prior?
this post the ultimate haha users guide...
we also know play in the struts makes noise/problems...
and general wear must be an issue too.
anyone worn OUT their haha?
i'm sure the bushing wears and the spring bars can shift/move at the zerks...
so john, those are my thoughts...
others?
2air'
hi azfly' thanks for the photo addition for reference...
that is exactly where i drop the martini glass!
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-16-2007, 08:17 PM   #228
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Jeez.
pmclemore is offline   Reply With Quote
Old 04-16-2007, 08:20 PM   #229
Profile:
Originally Posted by pmclemore
Jeez.
is that a good jeez or a bad jeez?
cheers
2air'
Old 04-18-2007, 12:02 AM   #230
Profile:  1999 23' Safari
Palm Desert , California
One Final (I hope) Question
When you are stopped for the night and don't unhitch should you loosen the spring bars--hoping to get pull throughs on our trip cross country so we don't have to unhitch. I am hoping that this is the end of my questions--at least until after our trip
Gail
hapitauk is offline   Reply With Quote
Old 04-18-2007, 01:13 AM   #231
Profile:
Originally Posted by hapitauk
When you are stopped for the night and don't unhitch should you loosen the spring bars-Gail
hi gail...
personal choice on this.
i do loosen mine.
1. lower the tongue jack to relieve tension.
2. loosen bars evenly (watch the receiver twist)
3. now adjust tongue jack for some levelness, keeping in mind the tv rear end rise...
4. block a wheel on unit ans set the tv brake...
have a safe and fun trip!
2air'
Old 04-18-2007, 06:33 AM   #232
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
John, I think you're on the right track. I had popping noises from mine on tight turns and greasing exactly where you indicated solved the problem (b/t the jacks and the frame brackets).
Gail, I'm one who usually doesn't loosen the jacks at an overnight pull through. A lot of those sites are designed so the front of the trailer is low. I just crank up the jack and watch it doesn't lift up the back of the tow vehicle too far. That should take pressure off the spring bars I think. Hope you have a great time on your cross country trip!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 04-18-2007, 01:01 PM   #233
pmclemore's Avatar
cheers
2air'
Sorry - didn't mean to say that out loud. It's just that whenever I think that I should save my pennies for a haha, I read some more of these helpful hints and think maybe I'm not up to the challenge.
Pat
Old 04-18-2007, 01:55 PM   #234
Profile:
and think maybe I'm not up to the challenge.Pat
true true...
and an honest philosopher once closed...
"a man's got to know his limitations."
cheers
2air'
of course he also said...
"do i feel lucky?"
Old 04-18-2007, 02:23 PM   #235
pmclemore's Avatar
lucky is what I'm working on now, by the way. Gonna roll 'dem bones a little tonight.
Old 04-20-2007, 07:27 PM   #236
All the frustration and work on Hensley worth it
Just want to report that all the aggravation we went through with the Hensley Hitch has been worth it--at least so far--and it was a lot of work. At one point my husband said that when we bought the motor home we just got in it and drove it--didn't have to go through all the work that the Hensley entailed. And we do miss the room we had in the Winnebago BUT I will gladly give up the room for the ease we are now having towing. We have put in 3 days (420 miles today) and two of them in very heavy winds and did not feel a thing except the occasional push on the Suburban from an extra strong gust of wind. I drove 3 hours yesterday and again today in the winds and it was like nothing was behind me and I would not drive the motor home. So we are very pleased so far and are finding the trip across country much easier than it has been in the past. Thanks so much to everyone for all the help you gave us.
Gail
Old 04-20-2007, 08:09 PM   #237
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
Pat
Pat------
I must admit I had some of the same feeling until I saw one in person. My thought's then and still are, "Hey what's the big deal?". Quit frankly this is a straight up piece of cake !!!.. Everyone here that has had problems seem to struggle with the same thing, that being able to look at the geometery of this thing and understand what happens as different components move. I worked as an auto mechanic 40 years,mostly with steering and suspention systems so maybe this come a little easier for me than some. My point "don't be afraid of it". ----pieman
Mike Lewis is offline   Reply With Quote
Old 04-22-2007, 07:46 PM   #238
breakaway's Avatar
Images: 20
All quiet on the Hensley front
2AIR and all HAHA believers,
The noise has stopped now that both the Hitch Ball and Frame Brackets have been greased. [See Picture]
The Hensley was new in the spring of 2005. It has been used on about 20 trips and 10,000 miles. The noise started this spring but now is gone. I just towed over 1200 miles and the noise issue is cured!!
I checked all the 2AIR suggestions and everything else seems fine.
My only Hensley disappointment is the paint failure. It seems to be a common problem.
John
1989 Excella 29
Hensley Arrow
Garmin 650
Pingbacks are On
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 27 07-27-2007 09:50 AM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 12:01 AM
Price guide for site? 1985air345 General Motorhome Topics 7 01-04-2003 11:06 PM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 05:53 AM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
SEO by vBSEO 3.1.0
