Old 01-28-2015, 07:20 PM   #1
Tintini's Avatar
Oakland , California
Twisted PP Stinger
We bought a Propride a year ago for our 25' 1970 Airstream and have put about 3,000 miles on it. The stinger is slightly twisted to the right along the axis of that portion of it that inserts into the TV receiver. We noticed this after a 2,000 trip. I put the TV on a lift and the hitch looks fine. I emailed Sean who said that a twisted stinger is not normal, that I should be able to use it, but should "watch it." He asked if the head moved side-to-side by hand if if we ran our chains through the bars. Yes to both. Our TV is a 2014 ML350 and we don't over torque the jacks because the front wheel wells are 1/2" higher with the jacks raised than without the TT hitched up. Has anyone else experienced a twisted stinger or know what causes it?
Tintini is offline   Reply With Quote
Old 01-28-2015, 08:08 PM   #2
cptfish's Avatar
2014 27' FB International
salem , Oregon
Can you post a photo?
cptfish is offline   Reply With Quote
Old 01-28-2015, 09:34 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Twisted? Did the 'yoke' move?
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-29-2015, 04:42 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
One of our customers had this occur. There were two theories about what happened. First, that the safety chains were run over the bars, instead of between them, and the second was the driver jacknifed the trailer while backing.
Old 01-29-2015, 04:53 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
"watch it"?.....yeah, I think thats a good idea,
Old 01-29-2015, 05:19 AM   #6
dznf0g's Avatar
Oswego , Illinois
Do you leave it in the receiver while unhitched? Somebody hit it in a parking lot? Any witness marks pointing to a hit?
-Rich-
Old 01-29-2015, 07:16 AM   #7
Tintini's Avatar
Neither happened to us. Most of the paint has flaked off that portion of the stinger that is twisted. I wonder if that hints at the cause.
Old 01-29-2015, 07:19 AM   #8
Tintini's Avatar
I don't think it would show much. I haven't measured it, but the twist is probably less than 10 degrees
Old 01-29-2015, 07:22 AM   #9
Tintini's Avatar
Good thought. We did leave it in the receiver while unhitched, but no witness marks.
Old 01-29-2015, 07:22 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
A picture of the hitch bar would really help in trying to determine a cause for the twisted hitch bar. This is important information as many Airforums Members are using the ProPride Hitch System.
Brian
SuEllyn & Brian McCabe
Old 01-30-2015, 07:33 AM   #11
Tintini's Avatar
Brian
I'll post a picture over the weekend.
Old 01-30-2015, 04:11 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Gee, interesting. A twisted 2" mild steel hitch bar. I wonder how much torque it would take to permanently deflect a 2" steel bar.
The Propride hitch rides under the ball coupler. It's a socket joint so we can traverse up inclines to buy fuel without putting stress on the A frame or tow vehicle receiver. I don't know what angle the rotation stops when the hitch hits the coupler, maybe 30 degrees? The hitch bar is pulled tight into the hitch with the over center clamps. it is constrained by the 2" receiver and hitch coupler. It seems it would be very difficult to apply much twist to the hitch bar when connected.
You engineers out there calculate the twisting force to permanently deform a 2" solid bar that's say 1 foot between the applied force and the attachment point. I know I don't have a wrench in my garage long enough to do it!
Tintini, put a level or some other straight edge on your stringer and take the photo. Then we can compare the angle of the straight edge to your rear bumper. That might magnify the twist you see.
It's a mystery to me. Finding the cause will be interesting.
David
Old 01-30-2015, 04:27 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Twisted PP Stinger
Originally Posted by Tintini View Post
...snip...
...snip...
Yes to running the chains through the bars? That would be problematic and possibly the cause of the twist of the stinger. Let's make sure we're talking about the same thing. Please see my picture below. This is how the safety chains should be connected to your TV - they are NOT running through the bars. Did you run your chains a little backward first and then THROUGH the bars or did you run them under the bars as in the photo?
Name:   ImageUploadedByAirstream Forums1422660249.371043.jpg
Old 01-30-2015, 04:57 PM   #14
Livingston , Texas
We bought a Propride a year ago for our 25' 1970 Airstream and have put about 3,000 miles on it. The stinger is slightly twisted to the right along the axis of that portion of it that inserts into the TV receiver.---
Is your stinger bent to the TV's right like the one shown in the photo below --
or is it twisted about its longitudinal axis as a drive shaft might be if too much torque was applied?
The thread in which this photo was posted is: http://www.airforums.com/forums/f464...ml#post1377674
Ron
Ron Gratz is offline   Reply With Quote
twisted safety chains - damage to chain holders Ramblinboy Hitches, Couplers & Balls 7 04-23-2012 04:12 PM
Hensley Stinger Exchange ctdair Hitches, Couplers & Balls 0 08-30-2010 05:48 AM
Hensley Arrow on a 2006 GMC 2500 - what is the 'drop' for the stinger? 72Blazerod Hitches, Couplers & Balls 5 05-13-2010 10:13 PM
Hensley with Propride adjustable stinger boondockdad Hitches, Couplers & Balls 5 12-03-2008 07:55 PM
Hensley Stinger Cover davidz71 Hitches, Couplers & Balls 2 05-14-2006 09:21 AM
