01-28-2015, 07:20 PM
Oakland
Twisted PP Stinger
We bought a Propride a year ago for our 25' 1970 Airstream and have put about 3,000 miles on it. The stinger is slightly twisted to the right along the axis of that portion of it that inserts into the TV receiver. We noticed this after a 2,000 trip. I put the TV on a lift and the hitch looks fine. I emailed Sean who said that a twisted stinger is not normal, that I should be able to use it, but should "watch it." He asked if the head moved side-to-side by hand if if we ran our chains through the bars. Yes to both. Our TV is a 2014 ML350 and we don't over torque the jacks because the front wheel wells are 1/2" higher with the jacks raised than without the TT hitched up. Has anyone else experienced a twisted stinger or know what causes it?
01-28-2015, 08:08 PM
2014 27' FB International
salem
, Oregon
Can you post a photo?
01-28-2015, 09:34 PM
1999 34' Excella
Hillsboro
Twisted? Did the 'yoke' move?
Peace and Blessings..
Channing
WBCCI# 30676
01-29-2015, 04:42 AM
Retired.
, At Large
One of our customers had this occur. There were two theories about what happened. First, that the safety chains were run over the bars, instead of between them, and the second was the driver jacknifed the trailer while backing.
01-29-2015, 04:53 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"watch it"?.....yeah, I think thats a good idea,
01-29-2015, 05:19 AM
Oswego
Do you leave it in the receiver while unhitched? Somebody hit it in a parking lot? Any witness marks pointing to a hit?
-Rich-
01-29-2015, 07:16 AM
Oakland
Neither happened to us. Most of the paint has flaked off that portion of the stinger that is twisted. I wonder if that hints at the cause.
01-29-2015, 07:19 AM
Oakland
I don't think it would show much. I haven't measured it, but the twist is probably less than 10 degrees
01-29-2015, 07:22 AM
Oakland
Good thought. We did leave it in the receiver while unhitched, but no witness marks.
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
A picture of the hitch bar would really help in trying to determine a cause for the twisted hitch bar. This is important information as many Airforums Members are using the ProPride Hitch System.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-30-2015, 07:33 AM
Oakland
Brian
I'll post a picture over the weekend.
01-30-2015, 04:11 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Gee, interesting. A twisted 2" mild steel hitch bar. I wonder how much torque it would take to permanently deflect a 2" steel bar.
The Propride hitch rides under the ball coupler. It's a socket joint so we can traverse up inclines to buy fuel without putting stress on the A frame or tow vehicle receiver. I don't know what angle the rotation stops when the hitch hits the coupler, maybe 30 degrees? The hitch bar is pulled tight into the hitch with the over center clamps. it is constrained by the 2" receiver and hitch coupler. It seems it would be very difficult to apply much twist to the hitch bar when connected.
You engineers out there calculate the twisting force to permanently deform a 2" solid bar that's say 1 foot between the applied force and the attachment point. I know I don't have a wrench in my garage long enough to do it!
Tintini, put a level or some other straight edge on your stringer and take the photo. Then we can compare the angle of the straight edge to your rear bumper. That might magnify the twist you see.
It's a mystery to me. Finding the cause will be interesting.
David
01-30-2015, 04:27 PM
2012 27' Flying Cloud
W
, New England
Twisted PP Stinger
Originally Posted by Tintini
...snip...
...snip...
Yes to running the chains through the bars? That would be problematic and possibly the cause of the twist of the stinger. Let's make sure we're talking about the same thing. Please see my picture below. This is how the safety chains should be connected to your TV - they are NOT running through the bars. Did you run your chains a little backward first and then THROUGH the bars or did you run them under the bars as in the photo?
01-30-2015, 04:57 PM
Livingston
We bought a Propride a year ago for our 25' 1970 Airstream and have put about 3,000 miles on it. The stinger is slightly twisted to the right along the axis of that portion of it that inserts into the TV receiver.---
Is your stinger bent to the TV's right like the one shown in the photo below --
or is it twisted about its longitudinal axis as a drive shaft might be if too much torque was applied?
The thread in which this photo was posted is: http://www.airforums.com/forums/f464...ml#post1377674
Ron
01-30-2015, 05:31 PM
Santa Rosa Beach
I remember that thread. the bent hitch bar was the result of the safety chains being routed above the spring bar. I thought then, as I do now, that the chain would have broken prior to the hitch bar bending 45 degrees.
Brian
01-30-2015, 05:44 PM
W
, New England
Brian
Brian - not sure if these are the same chains but according to this article, http://www.etrailer.com/question-21549.html this pair of safety chains had a 17 ton break point. I'm guessing that kind of pressure (via chains over the WD bars) could twist a 2" stinger before breaking the chains.
Note: Like Bill Belichick - I wouldn't say I'm the Mona Lisa Vito of trailer chains... :-)
01-30-2015, 07:26 PM
2012 25' Flying Cloud
Battle Lake
I don't know of a positive conclusion of what bent that earlier bar, but I think many of us believe it was from jackknifing the trailer when backing into a camp site.
As Ron questioned, is this one a twisted bar or a bent bar?
Doug and Cheryl
01-30-2015, 07:33 PM
Oakland
Attachment 231409
We may be getting somewhere, but I'm confused about "through" and "under" the bars. I drop the chains between the bars to the ground, then run them under the bars to the TV. I think they look like your photo, but I'm not sure.
01-30-2015, 07:37 PM
Oakland
Ron
Ron:
The stinger is not bent as in your photo, but twisted along the longitudinal axis of that portion of the stinger that is inside the TV receiver.
Jeff
01-30-2015, 08:14 PM
W
, New England
Ok. Here's the difference between "under" and "through". If you go back to my picture - that shows chains UNDER the ProPride entirely. It's really critical for you to remember whether you had them in that position - or THROUGH the bars which, if you look at my picture would mean you brought the chains backwards (to the left side of the picture) to go under then over the weight distribution bars and forward (to the right of the picture) to the tow vehicle.
Can you remember exactly how the chains were connected to the tow vehicle? It takes an awful lot of force to twist a 2" (or in my case, a 2.5") steel "brick" like the ProPride stinger. If your safety chains were wired around the weight distribution bars, that would apply an enormous amount of pressure to the stinger it's not expected to see (with safety chains under the head as described in the user manual).
