Old 01-05-2014, 07:36 AM   #1
2014 25' FB Eddie Bauer
Okemos , Michigan
Turn off electronic sway control with Propride?
I have a 2011 F50 which has a sway control feature built into the tow package. I am confused about how to use this in conduction with a ProPride hitch. Should it be left on or turned off? I have seen write ups which suggest that the two work against each other and write ups which suggest they are complimentary.
Wanna EB is offline   Reply With Quote
Old 01-05-2014, 07:52 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question We use a Hensley....
.....the PP eliminates sway...
The built in ESC uses the TV brakes.
IMHO....redundant.
I would shut it down...but I'm new here and know nothing.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-05-2014, 07:58 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have a Ram 1500 (electronic sway control) with ProPride hitch and it's solid as a rock. Neither one can be shut off. But always learning something new.
The ProPride stabilizes the trailer with is converging linkage design transferring the trailer tongue pivot point forward near the truck rear axle. This linkage prevents the trailer from initiating any turn off centerline; only the truck can initiate a turn.
The electronic sway control applies braking to the trucks wheels to counteract any sway motion its sensor detects. Just an enhancement of the electronic stabilization systems that have been around for some time.
Doug and Cheryl
Old 01-05-2014, 08:00 AM   #4
dznf0g's Avatar
Oswego , Illinois
I leave it on. It only activates if a sway condition actually occurs....when things go horribly wrong. It operates like an unhumanly fast correction in an emergency better than you could to correct truck yaw. I cannot fathom it interfering with PPP at all.
-Rich-
Old 01-05-2014, 12:10 PM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
We run with ours on as well.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-06-2014, 10:13 AM   #6
2013 28' International
Bozeman , Montana
I also run with it on with my 13' F150, Propride with 1400lb bars, 28' International. Tows great and have driven in some pretty intense sidewinds.
HeadWest is offline   Reply With Quote
Old 01-06-2014, 10:22 AM   #7
2013 25' Flying Cloud
Rosemere , Quebec
technically the electronic system on the PU won't do anything because the trailer won't sway. So don't worry.
Christian
2013 FC 25 B
F-150 ECO BOOST
WBCCI 20130
TAC QC-2
Pitou49 is offline   Reply With Quote
Old 01-06-2014, 10:31 AM   #8
Bozeman , Montana
Good point!
