Old 02-03-2013, 12:41 PM   #1
2008 25' Safari
Temple , New Hampshire
Trunnion head failure
I just purchased a 2008 25' AS with a Reese dual cam WD hitch with 1200# spring bars. When backing up my driveway for the first time I heard a loud pop and when I checked the drivers side spring bar was on the ground. After I checked the hitch I found that the trunnion head had ripped the cast iron ear that holds it in. My driveway is is sloped up from the road.
Has anyone had a similar experience? I spoke with a tech. rep. from Reese and he has seen this before. He stated that Reese has beefed up the new hitches in this area. I saw an online message from someone that had this occur after going over a dip in the road.
My thoughts as to possible causes are: ball too high- resulting in extreme angle between vehicles when backing up a grade, too stiff springs.
Any help that does not include buying a Hensley or PP would be appreciated.
nhrocks is offline   Reply With Quote
Old 02-03-2013, 12:48 PM   #2
1974 Argosy 20
Kooskia , Idaho
1200 # spring bars are most likely way too large for your 25' trailer. I would suspect you need bars in the 800# range. In addition, you will need a new ball head for your current Reese. So, about the only thing you would salvage would be the stinger bar itself from the old hitch.
So, replace and repair what you have, or consider a new hitch altogether. There are many out there which do not have the price tag of the PP or Hensley. I happen to like my Andersen, but would not reject many others.
Old 02-03-2013, 12:50 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
This is not an uncommon failure... try googling for "reese trunnion head failure".
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-03-2013, 01:00 PM   #4
1976 31' Sovereign
Oswego , Illinois
Did Reese replace head as they were aware of prob. and modified? Liability issue I had failure in 1968, destroyed 30 ft AS. They discovered design factor and paid for AS. no hassle I was very happy with Reeses handling of this matter. I use the old style dual cam will not replace with any other brand of hitch also I like old style much simpler, U hanger w chains to snap ups & bars w ends bolted on not bent as new bars are
Old 02-03-2013, 02:02 PM   #5
dznf0g's Avatar
Oswego , Illinois
Ditto what Barts said. I had also heard that the heads were beefed up in that area....but I don't know when.
-Rich-
Old 02-03-2013, 04:10 PM   #6
1981 31' Excella II
New Market , Alabama
1200# is about a factor of two too much stiffness on those bars. I expect that would hold up the whole back end of a front wheel drive car. If your driveway has a real steep bend in it, I would consider taking the bars off or loosening them as much as possible till you get it level. I expect that even a new hitch might break under those conditions. You are also putting alot of stress on the frame of your trailer and this could lead to front end separtion.
Perry
Old 02-04-2013, 04:07 PM   #7
2003 25' Safari
Riverside , California
Perry
I don't understand that logic??the trunion should be able to withstand at least it's rated load. If it takes the 1200lb spring bars regardless of tw
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 02-04-2013, 05:08 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I wish Andrew from CanAm or Andy from Inland RV would weigh in on this, as they have seen Airstream and w.d. damage from too-heavy bars.
Recalling their past comments, I think if the driveway angle is too steep and the w.d. bars too stiff, there is a risk of bending the A-frame of the trailer, as well as breaking of the w.d. head.
Disconnecting the bars when backing into the driveway may work well, but it is also important to select appropriate w.d. bars for your particular trailer/truck combination. That's where a call to the "Andys" can help you.
doug k
Old 02-04-2013, 06:19 PM   #9
1981 31' Excella II
1200 lb bars are very stiff. 1200lb is the nominal load when the trailer and tow vehicle are level. Now when the angle is increased like when you go up a drive way the force on the bars can go way up. Also if the bars are too tight the likelyhood of breaking something goes way up. I don't know of many trailers that have a 1200lb tongue weight. I don't see a good side to 1200lb bars on anything that Airstream makes. Maybe if you are hauling 15000lb of wet sand in a dump trailer with an F-150 they might be of use.
Perry
Old 02-04-2013, 06:31 PM   #10
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
A large northeastern Airstream dealership sold the PO of my 27FB Safari SE 1200 pound Reese bars with a Reese hitch. Prior to buying used I was negotiating with the same dealership for a new trailer (27FB) and the salesperson was specifying 1200 pound bars. I read the Forums for a year before buying so I knew 1200 pound bars were not correct. I purchased 800 pound bars for the trailer prior to picking it up from the PO and I've been happy so far. Like others I suggest you consider the 600 to 800 pound range.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 02-04-2013, 06:37 PM   #11
dznf0g's Avatar
Oswego , Illinois
Regardless, nhrocks, of the bar argument, I do believe there was a known issue with the amount of material in that area. Call Reese and see what they may do for you.
-Rich-
Old 02-04-2013, 07:49 PM   #12
2008 25' Safari
Reese acknowledged that the heads had failed in the past and that the new heads were beefed up. I was not the original purchaser and they would not replace it and will only sell to dealers.
A new one is on the way from e-trailer.
The 1200# bars are rated for use with tongue weights from 600#-1200# max.
The 800# bars are rated 400-800#, which I could exceed when loaded since it has a published empty hitch weight of 720#.
The PO purchased the AS and hitch from the well known NJ dealer that has sold and set up many units.
Old 02-04-2013, 08:07 PM   #13
dznf0g's Avatar
Oswego , Illinois
When I was using my Reese Dual Cam, I used 800# bars with my 30'er with 900 - 1000#s actual tongue weight. I felt this was just right. I do believe you should use one weight step below your actual tongue weight. Understand the bar rating is not a maximum rating, like a truck axle or tire. It is a guide to flexibility. It has been debated over and over here on this forum (and others as well). You can use the Google search function in the blue bar at the top of the page and get some pretty good numerical analyses as well as many well respected opinions.
-Rich-
Old 02-04-2013, 08:30 PM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Andy at CanAm recommended the 800 bars for the Hensley Arrow for my trailer which now has a 1,200 pound tongue weight, up from the published 833 pounds as an empty new trailer.
