Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 12-26-2013, 03:48 PM   #1
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Trunnion Bars advice, please
I have a Reese dual cam hitch and ordered 800# Bars for my 93 34'. Since the website had no specs of the length, I assumed they would be the same length as my old 1000# bars.
Now I realize that the new ones are 4" longer. I can not move the brackets on the A frame back enough to use the new bars, due to the horizontal Propane bottle mounts. Would it be safe to drill new holes in the new bars and shorten them?
Also the trunnion sockets are 1" versus 3/4" on my old bars. They do fit, but I was wondering if that could be an issues(see 3rd picture)
I would appreciate some input.
ID:	202367   Click image for larger version
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 12-26-2013, 04:19 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
I would move the WD brackets behind the tank mounts and let the chains slant a little to make up the difference.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 12-26-2013, 04:40 PM   #3
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
If it were me, I would call customer service and ask the questions.
If you drill a hole further up the arm they will no longer be rated 800#. Since the length of the lever will be decreased it will take more force to bend them. Though, it probably will not be enough difference to matter.
Alan
Old 12-26-2013, 05:17 PM   #4
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Looking at the last photo, are you sure it fits??? Looks like a completely different head. You want to make sure it fits into the socket all the way.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-26-2013, 06:39 PM   #5
Airstream Driver
1994 30' Excella
Images: 49
Yes, the new ones fit, which makes me wonder if the old ones are too small and cause excessive movement.
AIR #13
Old 12-26-2013, 06:42 PM   #6
Airstream Driver
1994 30' Excella
Images: 49
Regards,
JD
Thanks for the input. I doubt there is enough clearance to move the brackets back 4". No room for the set bolt.
AIR #13
Old 12-26-2013, 06:45 PM   #7
Airstream Driver
1994 30' Excella
Images: 49
I was wondering the same about length and rating. I will try to get an answer from Reese tomorrow.
AIR #13
Old 12-26-2013, 07:04 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
looks like you have enough room to move the bracket back, it is the set screw that is the problem. Get a shorter bolt for the set screw.
Do not drill the bar. Not sure if they are tempered or not but any change in the length will change the load factor.
When you set up the hitch mark one of the bars so you will always use them on the same sides. The bars are not the same length and if changed will actually add to sway because they will not be seated directly on the saddles.
2004 Excursion 4x4
Old 12-27-2013, 06:10 AM   #9
jdalrymple's Avatar
Jay , Oklahoma
I must have deleted your PM, but I had the same problem.
The supplied bolts are long to account for a C-channel frame, and the tubing frames of our Airstreams don't need the extra length.
I simply swapped the overly long clamp bolts on the WD bracket for a couple of shorter Grade 8 hex-head bolts from a hardware store.
Regards,
JD
Jeff & Cindy
Old 12-27-2013, 05:34 PM   #10
Airstream Driver
1994 30' Excella
Images: 49
the plot thickens...
I called Reese tech support today and they told me that my Reese WD set-up is as old as the hills and replacement parts are no longer available.
And the Tech told me that the new 800# trunnion bars will not fit the sockets on my old receiver. NO way, he said.
Well, I checked again and they fit just fine (see first picture).
Can anyone guess the appr age of my receiver by the pictures? Now I think that someone before me replaced the old receiver with a newer one that does support the newer Trunnion bars??
ID:	202418   Click image for larger version
AIR #13
Old 12-27-2013, 06:36 PM   #11
"Cloudsplitter"
Thumbs up
Your bar is the same as ours except for the bracket bolted to the end,(do I see two holes thru the end of the bar?)....ours was at least 25 years old when we sold it three years ago.
ID:	202421   Click image for larger version
Old 12-28-2013, 06:48 PM   #12
Airstream Driver
1994 30' Excella
Images: 49
Got 2 grade 8 short bolts and moved the brackets back 3". Moved saddles from old bars to the new ones. All looking good, even got some bend in the Trunnion bar with 4 links. Jumping up and down on the receiver gives about an inch off movement which I didn't have before with the short and stiff 1000 # bars.
Thanks everyone for the input!
AIR #13
