Old 06-12-2009, 08:29 PM   #1
pauly g's Avatar
1960 22' Safari
Oceanside , California
Trunnion bar dimensions and angle
I pull a 1960 22' Safari with a 2004 4WD Tundra. I just bought a used set of Reese 500# trunnion type WD bars to replace the (too stiff) 1000# set I have been using. Now I see that the 500# bars are shorter (28" vs 30") and the forged heads seem to have more angle, so that the bars hang very low at the back ends. I'm not sure if I can tilt the hitch head enough to get the bars relatively level.
Do the trunnion heads come in several different angles? Is there such a thing as 500# bars that are 30" long? Moving the brackets on the tongue would cause them to interfere with the LP tanks and battery. The bars I have mentioned are the older type, without the bend near the small end.
pauly g is offline   Reply With Quote
Old 06-12-2009, 08:31 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
could you get shorter bolts fro the brackets so they don't hit the LP tanks?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-12-2009, 08:38 PM   #3
There is only one trunnion for each of the 3 bar ratings.
You can tilt the ball mount to make angle changes.
The chain, from the bars, must be absolutely vertical.
However, if you add the straight line sway control then the chain angle is not important. That would solve your problem with the hitch.
Old 06-14-2009, 08:10 PM   #4
pauly g's Avatar
1960 22' Safari
I took the time to move the brackets on the tongue by modifying the battery mount. Now the 500# bars fit just fine, and the ride is much softer than before.
Where to buy or exchange trunnion bars? nunya001 Hitches, Couplers & Balls 9 05-24-2009 09:16 AM
Trunnion style vs Round bar WD Hitch ? Davis Hitches, Couplers & Balls 7 03-29-2008 03:01 PM
Reese round bar or trunnion? erock53 Hitches, Couplers & Balls 21 05-09-2007 10:28 PM
Which is worse when towing, trailer angle UP or trailer angle DOWN? Streamer1 Towing, Tow Vehicles & Hitches 33 09-19-2006 08:43 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
