Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-17-2010, 07:13 AM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
triple axle sway control?
Greetings.
I have had my 1991 34' AS out 1X on a short 250M round trip and had a great time with no problems. It came with a reese WD hitch w/ friction sway control. The PO told me that since I had a triple axel AS the sway contol was unnecessary. Now, I have read several posts about needing double cam, Hensley, or PropPride type hitches. Does the triple axel feature of my AS negate having these more sophisticated (expensive) alternatives?
tvanwave is offline   Reply With Quote
Old 07-17-2010, 07:39 AM   #2
Originally Posted by tvanwave View Post
Greetings.
To a minor degree, yes.
To a major significant degree, no.
A torsion type sway control is always the best, such as the Reese dual cam, since it knows when the trailer is in a straight line.
Friction type sway controls, offer resistance, period. That type has no idea if the trailer is in a turn or going straight down the road.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-17-2010, 11:31 AM   #3
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Thanks Andy. It was one of your posts that raised the issue in my mind. Is the reese dual cam better for my rig then than the PP3 or Hensley?
Tim
Old 07-17-2010, 11:50 AM   #4
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Another question - if the reese dual cam is a good solution can I just purchase the dual cam sway parts and use the rest of the reese set I have? Its a 800/10,000 square bar Reese w/ a V5 rating
Tim
Old 07-17-2010, 12:02 PM   #5
Tim
Tim.
Yes, and that will save some money as well.
Please make a post after the fact, so that others can learn from your experiences.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-17-2010, 12:12 PM   #6
2000 34' Limited S/O
Greensboro , North Carolina
I've had the Reese and now have a Hensley. The difference is amazing. Would never go back.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 07-17-2010, 12:22 PM   #7
ProPride Industries, Inc.
Sean Woodruff's Avatar
Holly , MI
Tim
Tim.
I'd like to hear something other than anecdotal evidence. Would you care to elaborate, Andy? While the dual-cam is the best product they make it is in NO WAY (other than price) better than a Hensley or ProPride hitch. It may be good enough for some but the stability of towing a 34' Airstream cannot be made any better than a PROJECTED PIVOT POINT vs. 10,000# pivoting at a distance behind the rear axle and inducing a steering torque into the tow vehicle. It just doesn't make any sense, from an engineering standpoint, if you understand the loads in towing. By the way, I'm OPEN for ANY logical statement and proof, as to why it is "better", you may wish to offer.
And, don't think of this as me arguing the point. I'm just pointing it out for the OP who should understand the total picture before someone throws out that the Reese Dual-Cam is "better."
Do you think maybe people here that have used BOTH the dual-cam AND an Arrow or ProPride 3P can provide a more complete answer?
ProPride Hitch
"The Most Advanced Generation in Trailer Sway Elimination"
Holly, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
TRIPLE AXLE 1988/89 5th WHEEL jimmini All Squarestream Trailers 15 08-09-2011 09:39 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Triple Axle Issue J&C Axles 19 04-16-2007 02:12 PM
34-Footer Triple Axle Questions JimGolden On The Road... 15 07-21-2006 10:40 AM
My new trailer - Argosy 35' triple axle, 5th wheel Luka All Argosy Trailers 9 10-05-2003 12:08 AM
