01-05-2009, 11:01 AM
1992 34' Limited
Falls Church
, Virginia
Trailer is a bit nose high....
All -
Would like to get everyone's opinion about a situation I have with my trailer. First, the set-up:
'01 Suburban 2500 4x4 with 6L w/ aftermarket trans cooler & w/ aftermarket Class V hitch - '92 34' Limited with all the OEM toys - 12000lb Equal-I-Zer hitch.
Have towed MANY miles quite happily with this set-up. All is stable.
Noticed on the last tow, with the trailer fairly lightly loaded, that the front end was nose high by about 2 or 3 inches. By that I mean, if the nose of the trailer was dropped 2 or 3 inches, it would be level. TV is level.
Can I get a larger drop receiver to rectify the issue? Will the larger drop affect the weight that I can pull or add additional stresses I would need to consider? Or is it not anything to be concerned about? I really don't want the 3rd axle to get more stress than the other 2, possibly causing a tire issue.
What say the towing gurus????
SilverToy
01-05-2009, 11:24 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Level please..
A level coach is very important. It doesn't sound like much but even two or three inches high will transfer quite a bit of weight to the rear trailer axle. If you can't level by re-distributing the load, or changing the weight bar setting, a new drop bar is necessary and readily available.
01-05-2009, 11:32 AM
1992 34' Limited
Falls Church
, Virginia
Weight issues???
Thanks for the reply Bob!
Will there be any weight issues with a larger drop? I seem to remember that there was some talk awhile back about 'moment arm' and all that sorta stuff - would that come into play with this scenario?? Don't want to get things squirrley when they are currently fine, then again, don't want tire issues either....
Anyone else with thoughts?
Thanks!!
SilverToy
01-05-2009, 11:43 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Silver,
In my experience you should not have any problems with a new drop bar.
I had to change from a 4 to a 6 inch when I got the 06 'Burb. I did use the 4 for about 1000k and noticed the difference at the scales after weighing with the 6 installed.
Have you been to the scales? It's really important to get the set-up right with a level trailer.
01-05-2009, 11:57 AM
1977 27' Overlander
Trotwood
, Ohio
Silver TOY
I have a 1 ton as u can see by the lower left of the screen. Ball height was 22 inches or so unloaded and the trailer was not level. Level is very important that gives each axle approximately the same amount of weight.
I at first Used a BLUE OX drop of 4 inches that I got from PEOPLES in Texas.
Now I'm not suggesting U have a problem but when I changed axles last August I gained approximately 4 to 5 inches in rear Height which translated to not needing the 4" drop anymore. IT's just layin on the shop floor taking up space. IF ya need this drop SilverTOY PM me. We can work out sumpin. This drop only made 3 short trips of about 80 miles each so its like new.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
01-05-2009, 12:39 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by Mikethefixit
Silver TOY
Roger
Silver,
See I told you it was readily available.
Roger...you 'da Man!!!
Ain't the Forum GREAT!!
01-05-2009, 01:35 PM
Princeton
, New Jersey
Here is a Reese drop shank #54917 that has a 12,000 lb. rating. pulling a 34fter. Please note I have cut 2 ins. off the bottom of the shank to allow for proper chain slack.
While my TV is a Ford Excursion now I used the shank on a Sub. for years.
2004 Excursion 4x4
01-05-2009, 01:37 PM
2005 28' International CCD
Willoughby
, Ohio
Silvertoy -
If I understand correctly, the TV setup has not changed but you have noticed that the TT nose is riding higher than it has in the past.
Assuming that nothing else has changed (your load in the TT and TV is essentially the same weight and location), you may want to crawl under your TV to see if anything has broken.
You didn't change the orientation of the spring bar supports on the TT?
I would expect a LOWER nose if shocks/springs are worn/broken, not a higher one.
I believe that the Equalizer hitch can be adjusted a few inches in either direction to compensate (check your owners manual or their website), but I'd really look for the cause of the problem before applying a solution.
Best of luck and let us know what you find!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
01-05-2009, 03:49 PM
2017 27' Flying Cloud
Altoona
I seem to remember that Chevy had a problem with the factory installed receivers failing - This is a very serious problem and you should not pull your trailer until this issue is fixed. Good luck
01-05-2009, 04:06 PM
Corona
Originally Posted by SilverToy
All -
SilverToy
Your Airstream must be as level as possible, for proper towing and weight distribution.
There are 2 possibilities.
The drop shank is not low enough, making the ball too high.
The axles could be bad.
The following article will help you check out the axles.
Dura Torque Axle
