Old 02-29-2008, 12:36 PM   #15
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Of course, the view is too far to tell - but is the trailer level when hooked up?
Pat
pmclemore is offline   Reply With Quote
Old 02-29-2008, 12:50 PM   #16
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Airstream for years made the frames for the 34' models with front kitchens and mid-kitchens the same even though the front weights were different. They finally moved the axles when they discontinued the front kitchen 34' models.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 02-29-2008, 08:01 PM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by lakelady
The second is the new to us 34 taken at Hillsborough River State Park in Florida.. taken a couple days ago.
Are you still in this area? If so, I am about 15 miles from there, and would be happy to go over it with you this Sunday (day after tomorrow).
Old 03-01-2008, 05:12 AM   #18
englewood , Florida
I appreciate the offer, but no we aren't. We're back in Englewood. Thanks so much!
lakelady is offline   Reply With Quote
Old 03-01-2008, 05:30 AM   #19
Well Preserved
1993 21' Sovereign
All right, but if you still have problems, and are in the area, I'd be happy to take a look with y'all.
From the picture you posted, it looks like the back of the van is a bit lower than it should be. Maybe you can try taking up one more link in the chains on the WD hitch, and see if it helps. I had what I thought was a pretty good setup, but I had some sway problems which were corrected that easily.
Old 03-19-2008, 04:50 PM   #20
JHD
1990 34' Excella
Woodburn , Oregon
Thanks for all the replies.. He's working on several of the suggestions and info gathering.
Our hitch is new... a Reese with the sway bars. Probably should have invested that $$ in a Hensley but this is water under/over the dam now.
The unit has basic supplies in it for a weekend. There's nothing on the back end like storage or a bike rack etc.
AS's book has a method to figure the tongue weight w/o finding a CAT scale. He just tried it and it came out just under 900 which the AS book says it should be. Could they be wrong?
SilverToy here's some pics if I can get them in here...
The first one is our old 32 at Lake Allatoona north of Georgia..taken April 07 when the lake had some water.
The picture of your 34' tells a lot. The nose of the trailer is too high, and the front end of your van is up in the air. You don't have your hitch set up properly.
And you don't need a Hensley hitch to tow a 34' Airstream. My 34' Excella tows like it is part of the truck all the time. Granted, I am towing with a Diesel F-250 Ford, but your 3/4 ton chevy van should be more than up to the task.
My previous RV was a SOB aluminum trailer (streamline) and it was 24' long. It towed quite nicely, but it never towed like the 34' Airstream. That trailer is just about the best trailer I have ever hitched up to a truck.
Seriously, look at your picture again, the nose of your van is airborne. That translates to reduced tire contact, and that decreases control of your tow vehicle, which leads to sway.
-JHD
JHD is offline   Reply With Quote
Old 03-19-2008, 06:01 PM   #21
2000 34' Limited S/O
Jamestown , North Carolina
Towing a 34'
I had a Lincoln Navigator when I bought my 87 34' and towing was a nightmare. I bought a Dodge Cummins 3500 and it's a piece of cake. I wouldn't have any other length now.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 03-21-2008, 07:13 PM   #22
1984 31' Excella
Norfolk , Virginia
Images: 11
34 footer
Lakelady
I tow a 31 foot 84 Excella with a 1 ton GMC 12 passenger van.
I was also experiencing problems with stability.
I adjusted the distribution bars until the two vehicle squated evenly and the trailer was level.
Then I went to a CAT scale.
Every thing was way off.
NOTE: If you are going to add weight to the tongue, do it first.
I adjusted the ball height and distribution bars over the course of an afternoon until I had equal weight on all four axles (two axles on the van, two axles on the trailer).
I now have between 3100 and 3200 lbs on each axle. The trailer isn't quite level but what a difference in handeling, stability and stopping.
After you get the weights balanced between the axles then you have to adjust the dual cam set up in accordance with the instruction manual. I have the older dual cam and all I did was loosen the u-bolts and the arms jumped home all by themselves. The dual cam high performance you have to adjust.
Go to this web address.
TCT Photo Gallery - pic_393
In the large picture in the background is my red and white GMC van and my trailer. It does not look level, however the weights on the axles are as equal as I could get them and the unit handles great.
Its the weight distribution on the axles not the appearance that stabilizes the rig.
Hi tarheel (Rick) Don't forget to bring the wheel locks to Williamsburg please.
Beginner
Beginner is offline   Reply With Quote
1989 Airstream Excella 29 Travel Trailer Hensley Hitch eBay Watch Airstreams on eBay 0 01-30-2011 04:50 PM
'89 Excella, Mystery wire bundle, hitch area, photos cjack99 1987 - 1989 Excella 3 01-27-2011 04:03 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 07:22 AM
