Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 09-18-2019, 02:49 PM   #1
2015 27' Flying Cloud
charlotte , North Carolina
Towing Sway Bars - necessary or overkill
When I bought a 2015 27FB Flying Cloud, the dealer sold me on a rather dramatic sway bar set up (1200 lb. weight diet w/ Dual Arm Sway $800). A few years later, after the bolts holding the bar to the A frame broke off, I stopped using the sway bars altogether. Today my Tow Vehicle is a 2018 Lincoln Navigator XL 4WD w/ Heavy Duty Trailer Tow Package listing 8,100 Max Towing capacity. The question is, under normal conditions, are anti-sway bars necessary or overkill.
svworthy is offline   Reply With Quote
Old 09-18-2019, 03:03 PM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
yes
WD and sway bars are a must
i would not tow my AS without both
they are both for your safety
waninae39 is offline   Reply With Quote
Old 09-18-2019, 03:05 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Not real sure what you are asking. Do you have a Reese Dual Cam hitch? With 1200 lb bars? Do you use the weight distribution bars? Are the WD bars what you are referring to as sway bars?
You need the WD setup to be complete and adjusted correctly. If, specifically, you have the Dual Cam setup that takes care of the sway and you probably do not need additional friction sway bars. If you do not have the Dual Cam then you probably need sway bars too. You definitely need some type of sway control.
Maybe you could post a picture of what you have?
Old 09-19-2019, 06:26 AM   #4
[ATTACH]352507 Thank you for the reply and for the questions. I'm really a novice at all this. Attached is a photo of what I have, which I believe is a dual cam hitch with 12000 # WD bars. But, it seems that the consensus is that I need sway control to tow my AS.
File Type: pdf Screen Shot 2019-09-19 at 8.15.41 AM.pdf (146.8 KB, 136 views)
Old 09-19-2019, 06:38 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Name:	Screen Shot 2019-09-19 at 8.15.41 AM.jpg
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 09-19-2019, 06:45 AM   #6
2012 28' International
Prince Edward County , Ontario
I read a posting on Airforums several years ago by Andy Thomson of Can-Am RV that anti-sway bars were not necessarily - until they were necessary. Much like seat belts on automobiles I suppose. That said, I have no experience with your particular set-up.
Cyclist is offline   Reply With Quote
Old 09-19-2019, 06:46 AM   #7
2013 20' Flying Cloud
Westerly , Rhode Island
I have the same WD hitch. The bars are used for both weight distribution and sway control. Without you have neither.
It's possible if you are not using the bars that you are overloading your rear axle's GAWR. Do you know your GAWRs and have you taken a trip to the CAT scales yet?
smithcreek is offline   Reply With Quote
Old 09-19-2019, 07:40 AM   #8
1988 25' Excella
1987 32' Excella
Why don't you just buy a new hitch and get it set up properly?
Old 09-19-2019, 08:22 AM   #9
Ol Bob's Avatar
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin , Texas
Consider this. You say a "bolt broke off and you quit using the sway bars since".
Now if you have one broken bolt how many other pieces of this hitch system may be nearly broken/damaged as well?
That said, a properly adjusted tow system transfers weight and prevents sway.
If you ever get in a accident because of your busted or improperly set up towing system be prepared for a mega lawsuit. I speak from experience.
There is no shame in changing tow systems. As waniane39 posted - it's for your safety and those of us on the road with you.
Be safe!
Ol Bob is offline   Reply With Quote
Old 09-19-2019, 08:55 AM   #10
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
Originally Posted by waninae39 View Post
yes
wd and sway bars are a must
i would not tow my as without both
x2 !!
AND for the safety of others you might affect in an accident.
mpsgolf is offline   Reply With Quote
Old 09-19-2019, 09:20 AM   #11
2019 22' Sport
San Jose , CA
I bought the sway bar kit that was available at the dealer. It was cheap and easy for them to install.
Konakcc is offline   Reply With Quote
Old 09-19-2019, 09:25 AM   #12
2019 25' International
Washington , Washington, D.C.
Bill M and O Bob - where do I find hitch specialists who can check out my system and improve it as necessary? Where do these guys live?
PatLee is offline   Reply With Quote
Old 09-19-2019, 09:29 AM   #13
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Answer - yes...
We run the Reese Daul Cam - love it.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 09-19-2019, 09:33 AM   #14
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
Necessary.
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2022 President, Northeast Mountaineers Airstream Club
MaineStreamer is offline   Reply With Quote
Old 09-19-2019, 11:28 AM   #15
Cedar Hill , Texas
My Uncle thought he didn't need sway control. An 18 wheeler passed him and my Uncle DIED! Yes, you must use sway control bars!!!!!!
fthopkins is offline   Reply With Quote
Old 09-19-2019, 11:37 AM   #16
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Yes, sway and WD are really a must with nearly any trailer that is required to have brakes.
Given your setup, I would wholeheartedly recommend if at all possible downgrading the bars on your setup. 2 1200lb bars is simply not going to give enough flex for a dual cam type system to function at peak performance with your setup IMHO and exp.
I read a term here once called being over hitched and the discussions seemed squarely to talk about the size of the bars and at first I thought it way off base, but I had a set of lower rated bars and gave it a shot. I found that the road manners changed for the better immediately.
With my rigs I have used as low a 600lb bars for the smaller and 800lb bars for the larger trailer, all being towed with a robust 3/4 ton truck. With a robust truck to tow, it's hard to justify the larger bars.
Think about it for a second. Your hitch weight, not being a slide out is going to be 1000lbs or south of that, making 1200lb bars overkill. If you said I have a 30-34' slide out, which is notorious for having a 1000+lb hitch weight, I'd say for sure, go for the 1200lb bars.
panamerican is offline   Reply With Quote
Old 09-19-2019, 12:46 PM   #17
2004 25' Safari
1999 27' Safari
1968 17' Caravel
Fountain Valley , California
I have or have had three Airstreams, a 17', 27' and 25'. I've always used load leveler and anti-sway on all three. Even though I had it, I did lose the 27' with swaying that resulted in the rollover and totaling of that Airstream. There were bad road conditions, but that being said, if you value your Airstream I believe you are irresponsible to not have anti-sway protection.
Not only do I use anti-sway and load levelers when towing (with my 1/2 ton Chevy pickup) I went to the high pressure tires for the pickup like those used on the 3/4 and 1-ton pickups. The resulting more rigid sidewalls definitely increased anti-sway characteristics even more.
WindyJim is offline   Reply With Quote
Old 09-19-2019, 12:51 PM   #18
Ol Bob's Avatar
1994 28' Excella
Elgin , Texas
Ask the members of your local Airstream club.
Old 09-19-2019, 01:49 PM   #19
2007 23' Safari SE
Annandale , New Jersey
Nodding my head as I read through this, some good advice here.
Interesting to see Andys name pop up as he was kind enough to assist me early on with working out a hitch for my the 2006 Land Cruiser and 23ft. He suggested the EAZ Lift and 2 anti sway bars. I oddly felt like I had to spend more money (for more safety...) but took Andys advice and glad I did. The one I bought only had one sway bar and I planned to add another, but ran out of time before my first trip. It has done a great job and yes on the Land Cruiser, did much better with the sway bar and probably would have been perfect with 2. As someone here said, you really dont need them... until you need them. I hit some high winds in October on that first trip and wished I had the second one. Since then I added a 2017 Tundra, and was much easier towing than the LC. Originally had p metrics tires and I could feel the sway when a truck passed or I passed one. Upgraded this past spring to Nokian Rokiva AT plus tires that are E rated with 10 ply. As noted by another member here, that was a big improvement in stability and little to no extra rough ride. I doubt I need the second sway bar now, but always connect the one.
Fred L is offline   Reply With Quote
Old 09-19-2019, 02:14 PM   #20
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
So the answer is yes! I almost lost it going through a mountain pass, with out sway control. A scary lesson protect your family and your investment.
bibbs is offline   Reply With Quote
Ford's electronic sway control VS Blueox sway bars Vitaver Towing, Tow Vehicles & Hitches 42 09-23-2020 10:36 AM
Sway bars necessary? gwag23018 Hitches, Couplers & Balls 23 11-25-2017 04:01 PM
Equalizer Hitch: Necessary or Overkill? TRizzuti Member Introductions 11 10-29-2014 11:53 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
