Old 05-21-2007, 10:38 AM   #1
1980 31' Excella II
Knoxville , Tennessee
Towing Question noises from hitch
We have just recently purchased a 1980 31' Excella II. We towed it for the first time and it made all kind of noises from the hitch area. We are guessing that it was the load levelers. It was every time we went into a turn. It made popping noises. We are used to towing a pop up camper and was wondering if this is normal or is there something we are doing wrong?
kdh0519 is offline   Reply With Quote
Old 05-21-2007, 10:48 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Yep, those could be your sonic dampeners at work! That is assuming you have the dual cam anti-sway. To know if your sound is normal, we neeed to know what hitch set-up you're using.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-21-2007, 11:00 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I remember being startled by my friction anti-sway device on my first trip. Also, I use grease on my hitch ball - some folks don't.
Pat
pmclemore is offline   Reply With Quote
Old 05-21-2007, 11:09 AM   #4
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Yep, First time I towed and heard that it scared the wee outta me.
If you really want to know if you have to worry or not. Just post what type of setup you have.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 05-21-2007, 11:12 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We get squeeking and creeking noises with our Hensley hitch when turning at low speeds. Regreesing helps, but it still makes some noise.
SuEllyn & Brian McCabe
Old 05-21-2007, 11:15 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Yes, Pat, it is recommended to use grease on the hitch ball. There are a number of alternatives -- never been able to find the thread with the secret stuff to keep from marking up my pants. Even heard of somebody using wax paper.
Same question: Do you know the brand of weight distribution/anti-sway gear on your Excella? Yes, Reese dual cam makes noise on turns or backing up. Never apply grease to lessen that noise -- it's the friction that holds your trailer in line when it needs to.
5 meter Langford Nahanni
Old 05-21-2007, 11:24 AM   #7
ScottW's Avatar
Hernando , Mississippi
I've found that if you keep the windows up and the radio turned up loud, you don't hear those scary noises.....
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 05-21-2007, 11:59 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
We came off a 12 foot fiberglass Coleman pop-up also - to a 27 footer. The load levelers/anti sway creaks, groans and pops. Try to just think of it as the hitch reminding you it is doing what it's supposed to.
Old 05-21-2007, 12:03 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
*IF* its a Reese dual-cam, Reese says you can put a dab of vaseline on the saddle-cams to reduce the noise. grease is too slippery, and will reduce the effectiveness of the anti-sway effect. But apparently, vaseline isn't all that slilppery. seems odd, but if the manufacturer says its ok...
anyway, I tried it on mine, and it works great. It pretty much eliminated any noise from back there.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-21-2007, 12:34 PM   #10
Thanks Chuck. I thought I remembered their instructions said vaseline was okay but figured I needed to double check that.
Old 05-21-2007, 03:12 PM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Yea, ditto, I'm switchin' to the Vase...... Been using just an ever so slight coating of grease. Of course as most tech heads, I rarely RTFM.
Old 05-21-2007, 03:22 PM   #12
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
In addition to the Reese Dual Cam, the Equal-i-zer brand hitch that I have makes a similar noise in tight turns. It takes getting used to. I had been warned of the noise before we got our trailer so I knew to expect it...doesn't mean I didn't think I hit something with the trailer though. However, I did hit a guard rail in a tight turn with the trailer on our first camping trip and it made less noise that the hitch does!
Family of Disney Fanatics
WBCCI# 4821
Old 05-21-2007, 03:47 PM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Gee and I thought the noise was the low speed campground warning system!
Sort of like the backup warning beeps.......
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-21-2007, 03:57 PM   #14
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
When I bought our AS the dealer installed an Equalizer and the service manager told me NOT to grease it. Without grease, our AS sounded like a rusty old battleship being dragged down the road and we attracted stares from other RV'rs in the wrong sort of way. Then I actually read the Equalizer owner's manual which expressly says that grease CAN be applied without affecting performance. I now use a "white" marine grease that I buy in the boat section at Bass Pro Shops and we're nearly silent.
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Strange noises from the stereo? hshovic Audio, Video & TV 60 07-12-2009 08:45 PM
96 Blazer with factory trailer hitch - towing capacity? BlazinHaze Tow Vehicles 21 09-02-2008 09:44 PM
speaking of tranny noises... Chuck Tow Vehicles 12 05-02-2007 11:24 AM
Pintle Hitch? Do you have exp. towing a Blazer? harestream Hitches, Couplers & Balls 17 07-22-2006 06:28 PM
Not trying to be noises ,But Angel73 Insurance & Claims 0 05-28-2006 11:21 PM
