Now that would provide some useful and objective data, rather than just how many teacups fell of the counter top.
Someone (can't recall who) had one and started to do a 'before and after' as part of an axle replacement. Wish I could find that thread...
How about this? Epiphany Gets new Axles
The chart is in post #167. I have noticed that the new suspension works better when the trailer is loaded. No real improvement from the old setup when it's empty.
Add a full tank of water and some stuff and the suspension flexes as it should.
__________________ Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie - 'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
Andy & Roger; Thanks to both of you guys, I'm still wondering witch bars, 1000 or 600 to use. Roger--do you get any flex with your 1000# bars pulling the 34ft limited? I want to believe Andy has the right idea, but the 600#s sure do look light. My 3/4 ford van is a R/V van and sprung heavy due it's equipment inside. I've pulled a 29ft a/s with it and have enough motor, 5.4, and 373 gears. Just want to get the hitch system RIGHT !!!! Woooo is me. What to do. Anyway thanks for this forum. lots of info to help us newbee get into the data and try to become better R/Vers. Thanks Bud
Airhouse
I had a hitch that came with my AS, it was a Reese with 1000 lb bars. As you can see (lower left) I have a heavy truck. When the wife and I brought the AS home we didn't have our hitch. I have towed I think about every size trailer for 12 ft to 53ft and 45 yrs over the road in a big rig. I wasn't scared of NUFFIN. But the rebound of those 1000 lb bars liked too wrecked us. Whats worse I hadnt payed for it(the AS). PO insisted we take it home. That was the last trip for the 1000's. My hitch of choise is an old Reese Straightline,with 600 lb bars and 6 links in the chains under stress.
We get a Lincoln ride out of that big O-4door crewcab and we enjoy the ride. I have experimented with different chain settings but always come back to the 6 links under stress . I have a radio cabinet inside the door that I leave cd's on top of and in 400 miles they are still there.
Oh bye the way I sold the hitch with the 1000 lbs bars, the guys says its perfect on a box-car trailer.
Good luck with your search.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER KA8LMQ AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit Thanks Roger, for your input. It is now the final word reguired to make a believer in that what Andy,the Guru, has been trying to drum into us that you don't need to make an solid IRON-BAR connection between TT & TV. I got it!!! It's got to flex so you can control it, not have it control you. I'm convinced that with my stiff sprung TV with a long wheelbase the 600#s will work great. Glad I went ahead and bought them to use as it will make that 2000 mile trip better and safer. Again I must thank You, Andy, and all the other inputs that make this Forums a great place to find info needed to share our experiences. It's the best.
When you return from your trip, make a post here and let others know the results you experienced.
Now how in the world, could I know that you removed the overload springs.
I didn't get decent weight transfer on mine for what I think are several reasons, the thick overload springs on my 3/4T Dodge among them. My thought has been to remove that spring from the pack (and maybe a spacer or two), re-align the front end and add a Timbren Aeon hollow rubber overload spring (replaces the bump stop) for those times I am not towing a travel trailer and need the OEM capacity.
That, along with an aftermarket anti-roll bar (and maybe fabbing a panhard rod) would make for a better-riding, more stable rear platform that would allow proper weight transfer.
Experimentation can get addictive . . like MarkDoane talking about using panhard rods on a beam axled trailer, hmmmmm.
2004.0 DODGE 2500 Cummins 305/555; 6-manual, 7,400-lbs; 19 mpg city; 22-25 hwy; 13-15 towing. All miles at 1,700-1,900 rpm.
Sold: 1983 Silver Streak3411 Supreme; 6,860# (8,000 GVWR)
Classified section, vintage kin http://www.airstreamclassifieds.com/...p?product=6935
You might consult a local spring shop. Tell them your springs are too stiff and what you want to accomplish. They have probably run into this problem before and know just how to solve it.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Andy, You may not be getting quite the response you expected but I for one am glad as you have gotten folks to at least to look and try to understand their setup. Thank-you.
Rednax,
Your trailer should not have enough hitch weight to engage your overload spring unless your packing the bed w/ alot of stuff. I have timbrens installed on my 2500 dodge for another appl. besides the A/S. They work but once your riding on them, it is like riding on the bump stops. They are awfully stiff. The company is however, very nice and accommadating to work with.
