Old 09-08-2011, 08:09 PM   #1
1989 35' Argosy 5th Wheel
houston , Texas
Towing a Jeep behind AS fifth wheel?
What are yalls opinion on towing a jeep behind an AS fifth wheel. What does AS
recommend? Im looking into "stiffening up the rear bumper...maybe welding in 3/16 square tubing @ 6' in front of the existing bumper and then tying in with shorter sections of square tubing @ 5". A hitch was welded on by a prior owner but I think i might grind these welds out and weld myself.
Any thoughts??
jcm83houtx is offline   Reply With Quote
Old 09-08-2011, 10:42 PM   #2
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
What are you towing with? Will you have a brake buddy for the jeep? How will you determine if something is going wrong with your hitch setup way back there as you motor down the freeway? Is it legal in the states that you will travel?
Its all tug weight and no tongue weight but it will add considerable stress to the frame of your airstream.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 09-09-2011, 11:41 AM   #3
houston , Texas
my 07 chevy duramax is plenty capable. Im more worried about the existing bumper even though like you say its only tug weight. Do you think a brake buddy is necessary Vinnie?
I wonder if I could rig up a camera to my existing navigation unit on my truck...
lol that would be bada$$
Old 09-09-2011, 12:22 PM   #4
DKB_SATX's Avatar
Alamo Heights , Texas
I think in most states, braking control with a breakaway for the Jeep would be legally required.
— David
Old 09-09-2011, 12:36 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The last I checked, double towing is allowed in Texas and more than half of the other states. Texas requires brakes on anything 4500# or more. Many other states require them at 3000#.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 09-09-2011, 01:03 PM   #6
SteveH's Avatar
Common Sense , Texas
I know also all the light laws are applicable, and there is a 65' (I believe ) maximum combined length.
I've done it in the past towing a 24' Argosy, and a 17' boat with a 3/4 ton Chevy truck. However, I did not like it, it was very hard to hold steady, and I would not do it again.
Regards,
Steve
Old 09-09-2011, 01:57 PM   #7
houston , Texas
my jeep weighs about 4k. I think it would be much more stable compared to a bumper pull... reason i got a fifth wheel.
xtra safety devices cant hurt though right
Old 09-09-2011, 02:42 PM   #8
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
An AS 5th wheel??? where have I been?
B25guy is offline   Reply With Quote
Old 09-09-2011, 02:44 PM   #9
SteveH's Avatar
I believe it was an Argosy (by Airstream) back in the late 80's, early 90's.
Regards,
Steve
Old 09-09-2011, 02:52 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Fred's Airstream Archives - 1996 Airstream Integrity 5th Wheel Travel trailer (A)
Vaughan
Old 09-09-2011, 03:05 PM   #11
SteveH's Avatar
Well, I was wrong on that one. Looks like it was part of the "Squarestream" effort.
Regards,
Steve
Old 09-09-2011, 03:08 PM   #12
1983 34' Excella
1967 24' Tradewind
Images: 32
They did Argys too.
Both definitely in the Square look.
Vaughan
Old 09-09-2011, 04:09 PM   #13
1969 27' Overlander
Kimmell , Indiana
I would be concerned .. The side to side pressure exerted by a tow bar is quite a bit more than that of a regular trailer hitch. It is enough to actually slide the front tires of the towed Jeep sideways because the tires cannot track perfectly.
Hoosierdaddy is offline   Reply With Quote
Old 09-09-2011, 04:23 PM   #14
1972 21' Globetrotter
nc , North Carolina
there was a guy that was camped next to us last year in a campground in nc. he said he was a full timer. anyway he towed a 5th wheel with a jeep towed on the back of the trailer. he said he had to take it back to the factory for them to rebuild the whole rear inside the 5th wheel. everything was comeing apart. i told him that was because the jeep on the rear bumper would not let the rear of the trailer bounce like it should and it was takeing a pounding . read up on hitch carriers for scooters and motor cycles and it will warn you about that, same is true on towing behind a trailer. it don't matter what your towing with.
rock60 is offline   Reply With Quote
Old 09-09-2011, 04:59 PM   #15
Retired.
. , At Large
Any thoughts??
Since you asked my thoughts:
1) I think you'll be making a mistake.
2) The dealership I work for will be happy to perform the repairs that will be required after you do this. They will no doubt be expensive.
3) There will be no warranty on those repairs.
Old 09-11-2011, 11:53 AM   #16
houston , Texas
overlander, what would you do to reinforce the frame.
angle in the corners?..crossbracing?..flat bar along the sides of the frame?
What would you do?
btw, I weld high pressure vessels at oil refineries for a living.
NEW: 5th Wheel Airstream Airtrekker Boondocking 43 05-30-2020 09:11 AM
Towing with a TDI VW Jetta PA BAMBI II Tow Vehicles 102 07-21-2011 09:27 AM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
