Old 06-21-2014, 08:18 AM   #1
2007 25' Safari FB SE
Marblehead , Massachusetts
Tow bar and hitch for 2011 GMC 2500 HD Duramax
Just purchased a 2007 AS 25' Safari LS SE and need to pick it up. Can someone recommend a tow bar and hitch system for this combination? Thanks.
chcampbell is offline   Reply With Quote
Old 06-21-2014, 08:30 AM   #2
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Reese Dual Cam, #600 sway bars--cost $650-800 installed.
Luigi123 is offline   Reply With Quote
Old 06-21-2014, 08:42 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The factory literature for 2007 shows a 750 pound tongue weight for the 25' Safari SS and 860 pounds for the 25' Safari. Based upon my experience, those numbers can be low.
A Shureline scale can get you the "actual" tongue weight to help select the weight rating of the leverage bars in a weight distribution hitch. You may find that the 800 pound bars are more appropriate and if the weight is over 900 pounds, consider the 1,000 pound bars.
The other part of the equation is the stiffness of the GMC rear springs.
See if the selling dealer will allow you to swap out the bars if the first choice is inappropriate.
Old 06-21-2014, 12:13 PM   #4
dznf0g's Avatar
Oswego , Illinois
I've driven several 2500s with my 30'er. (950 TW). Luigi has it right with my first choice for an entry level setup. If your actual TW is over 800lbs, I'd opt for 800 pound bars, but no heavier. I had 800s and they are perfect.
Of course, after I found a used Hensley, I only keep my Reese for a backup. If buying a new PPP hitch, I'd go Propride. I first had an Equalizer......didn't like it at all.
Welcome to the Forum, BTW.
-Rich-
Time to update/upgrade the GMC '99 Suburban 2500 receiver hitch & wiring truxpin Hitches, Couplers & Balls 3 09-09-2012 10:30 AM
Hitch help for '99 GMC Suburban 2500 truxpin Towing, Tow Vehicles & Hitches 6 08-30-2012 09:36 AM
Chevy/GMC Duramax SteveH Tow Vehicles 213 01-19-2012 07:00 AM
