Old 12-09-2012, 06:20 PM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Torsion Bars - Do You Lubricate Them
Am I supposed to be lubricating the torsion bars where they insert insert into the hole? It appears in the photos that our torsion bars are experiencing a lot of friction.
If they are indeed supposed to be lubricated, can I use the same lubricant that I use for the hitch/ball?
ID:	174280   Click image for larger version
Name:	Torsion Bar Hole.jpg
Frank&Mike is offline   Reply With Quote
Old 12-09-2012, 06:23 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A finger full of wheel bearing grease will help control the wear you are seeing.
Old 12-09-2012, 06:31 PM   #3
1974 Argosy 20
Kooskia , Idaho
When I used that type of hitch, I always used a bit of white grease to lube the ball and the contact locations where you see the wear points. I used Reese "on the ball" lube, but anything is better than nothing.
Old 12-09-2012, 06:34 PM   #4
Frank&Mike's Avatar
Georgetown , Texas
Thank you both for your replies. I appreciate it. Looks like I better start lubricating them.
Old 12-09-2012, 07:42 PM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I keep a spray can of white lithium grease in the back of the truck and give both the ball and the spring bars a quick spray when hooking up. White lithium grease is used on farm quipment and on motorcycle chains because it doesn't collect dirt and grit. It quickly gets a dry film on the surface but retains the lubricating quality. I buy it at Tractor Supply here in Dripping Springs.
John W. Irwin
WBCCI #9632
Old 12-09-2012, 08:28 PM   #6
Frank&Mike's Avatar
Georgetown , Texas
Thanks John. I think that's the same product I'm using on the garage doors. I make a mess with what I have right now for the ball and I can't tell you how many pair of jeans and shorts I have with a stain on the legs. Lithium grease sounds like the best solution for me.
Old 12-10-2012, 10:17 AM   #7
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Best stuff I've found is Yamalube -- available on line.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
