Old 07-23-2009, 10:03 AM   #1
billiards's Avatar
rochester , Minnesota
torsion bar load levelers?
i guess thats what they are called....on my f 250 4x4, i finally have concluded that the safari 25 ft. pulls and handles better w/out the torsion bar hitch.....anyone else find that to be the case?
billiards is offline   Reply With Quote
Old 07-23-2009, 10:04 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If that is the case you don't have them installed right.....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2009, 10:18 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I agree with Jason. In all probability, you may be experiencing problems related to one of the following:
  • Hitch Height -- with a 3/4-Ton 4X 4 this is often a problem. In many instances, a special deep-drop drawbar is required to get the hitch height low enough to function properly. Airstreams handle best when they are close to being absolutely level when hitched.
  • Cam Adjustment -- with a Reese Dual Cam (if your hitch is so equipped) the adjustment of the mechanism mounted on the coach is critical to having a good towing experience -- when the coach and tow vehicle are in a straight-line, the cams must be well-seated in the cams.
  • Weight Distribution Bar Rating -- with a 3/4-ton 4 x 4, you likely need weight distribution bars with no more than a 600 pound rating.
  • Balancing Load in Coach -- often, stability issues may be related to having too much weight behind the axles. In my vintage coaches, the handling is always improved when traveling with a full (or nearly full) fresh water tanks -- in those days, the coaches were designed with this weight anticipated in the balancing and hitch weight calculations.
Goog luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-23-2009, 12:24 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Were you also using sway bars? In your case that is more important.
The F250 has pretty stiff suspension. So if the rear end only squats 2" or less you won't notice much difference in handling. What happens to the TV when a load is put on the hitch is the back goes down and the front goes up. If this results in a significant change it will adversely affect handling and towing. The WD hitch takes the weight off the rear axle of the TV and puts it on the trailer axles and the front axle of the TV also raising the rear and dropping the front of the TV restoring the proper geometry and handling. This difference may not be noticed until you find yourself in an emergency situation which will magnify any handling problems and could have some consequences.
Old 07-23-2009, 01:39 PM   #5
airperson
2006 25' Classic
Ft Worth , Texas
Overlander,I have a used hitch how do you find the Weight Distribution Bar Rating
Airperson
Airperson is offline   Reply With Quote
Old 07-23-2009, 08:05 PM   #6
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Airperson!
Airperson
Some time back, Andy from Inland RV posted the following method for determining spring bar ratings:
Measure at the top of the square bar as it enters the "trunnion."
1 inch = 550 pounds.
1 1/8 inch = 750 pounds.
1 1/4 inch = 1000 pounds.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-23-2009, 09:13 PM   #7
Catsalesman's Avatar
1998 25' Safari
Paradise , Texas
I have a 25 safari, pulling it with a 08 2500 HD 4x4 duramax and I can tell you the dist hitch makes a world of difference in the handling of the trailer. Once I got mine adjusted correctly it was like the trailer is not even back there. It tows better than any RV I have ever had.
1998 A/S - 25' Safari
2008 GMC 2500 HD 4x4 Crew Cab Diesel
http://dallasguntrader.com
Catsalesman is offline   Reply With Quote
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Blue OX hitches load levelers? Resorts Hitches, Couplers & Balls 4 07-16-2007 08:09 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Levelers and airbags CBBOB Mechanics Corner - Engines, Transmission & More... 2 09-01-2003 03:25 PM
