Old 06-12-2006, 11:49 AM   #1
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Tongue Weight and Stability
I recently made an interesting discovery. My fridge died while dry camping so I bought a 100 qt. ice chest, some ice, and continued my trip. While underway I strapped the ice chest to my couch as far forward as I could. I noted to myself that my trailer was especially well behaved on the interstate, barely reacting to passing trucks and cross-winds.
When I reached Phoenix we unloaded the trailer and towed it to Oasis RV in Tucson to get the fridge fixed (more on that in another post). During the trip on I-10 from Phoenix to Tucson I noticed that my trailer was up to it's old tricks of reacting to passing trucks.
My conclusion is that the 100 lb. reduction in tongue weight (the full ice chest weighed at least that much) was to blame. I plan an experiment when I retrieve my trailer on Friday to confirm my theory. I'll report back with the results.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 06-12-2006, 01:13 PM   #2
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
this is what's known as weight distribution...
Steve,
I don't know what type hitch you're using but if it has weight distribution adjustments you should try to recreate the 100lb. cooler effect. Sounds like you need more weight toward the tongue (but I'm no genius at this).
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-12-2006, 02:17 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I think Silverback nailed it.
When I traded my 2003 Z71 Suburban for the Chevy 2500 HD, I kept the same 1000# hitch setup. Then I read a post by Inland Andy on these forums that stated you need lighter equalizer bars as you move to a Heavy Duty suspension.
Later, Nick Crowhurst, also on these forums, provided an excellent analysis along with precise formula for computing hitch requirements. As as consequence, I now use 750# bars.
Perhaps your "Igloo Experience" is telling you your bars are too heavy or too torqued to allow you to keep enough weight on the hitch.
P.S. What happened at the Oasis? Inquiring minds want to know.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 06-12-2006, 03:47 PM   #4
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
New to towing. In fact this weekend was the first real trip with the trailer. Besides new trailer brakes I also changed from an EA-Z-Lift hitch to a Reese trunion type. The trailer towed noticably better and I attribute this mostly to now having an adjustable height ball set to the correct height. The EA-Z-Lift was fixed and ~4" lower than the 19-1/2" specified.
I've never used the Reese set-up before and it always seemed undoly complex. I mean, what's with this adjusting the hitch angle stuff? OK, so as I understand it what this does is allow some "fine tuning" of the tension on the equalizer bars. I set the angle by installing the recommended seven washers (spacers) and the trunion bars snapped into place with one more than the required minimum number of links. I measured wheel well openings on the TV and it appears they are 1" less than without the trailer all the way around. What's more the trailer now appears perfectly level when hooked up. According to Reese there should be about 1" more sag in the rear than the front which would lead me believe I have too much tension on the bars. However, leveling the TV seems to work and again, according to Reese as long as there's not more compression on the front I should be OK. FYI the TV is AWD so losing traction in the rear isn't an issue. I'm wondering though if I should remove a few washers (i.e. make the hitch a little closer to level) to reduce the tension on the trunion bars and bias the weight a little more over the rear wheels.
Anyone have a good tip on where to find a scale that will weigh each axle of the rig to see exactly what the distribution is?
bhayden is offline   Reply With Quote
Old 06-12-2006, 04:26 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Silvertwinkie was up at Moraine View and told me the exact same story. He also has a 2500 Suburban and recently changed out his bars to lighter bars. He said it made a big difference in towing stability.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-12-2006, 10:43 PM   #6
1997 30' Excella
Waddell , Arizona
Images: 13
Jack
The service manager at Oasis knew what year my trailer was without asking. He told me that in 99 or 2000 Airstream moved the axles back 2 inches (on the 30' dinette models) in order to increase tongue weight and improve stability. He also stated that my trailer was very particular with regards to hitch settup and being absolutely level when hitched.
I suspect that I'm running too heavy a springbar with my hitch. I have an EazLift with 1,000 lbs bars. Viewed from the side it appears to be every so slightly nose up. My plan is to replace my EazLift with a Reese Straight-Line (Dual-Cam) with 800 lbs bars and a shank which will allow for a slightly lower ball height.
In order to comfirm my earlier experience I plan to fill my cooler with 100 lbs of weight and take it with me when I pick up my trailer on Friday.
Steve Heywood
Waddell, AZ
Old 06-12-2006, 10:47 PM   #7
1997 30' Excella
Waddell , Arizona
Images: 13
Oasis is a great dealership. A bit "old-fashioned" and kind of dumpy looking, but that's OK. The service department so far has proven to be first rate and the service manager is very knowledgable.
I'll take that over "flash" and a bunch of airheads any day.
Steve Heywood
Waddell, AZ
Old 06-13-2006, 12:20 AM   #8
1960 24' Tradewind
santa barbara , California
Hello bhayden,
The deal with the hitch head angle is that when setting up the bars ,they should have some amount of curvature to them in the fully loaded position.
IF they pull up too far ,you can angle the hitch head down so the bars take a curvature in the loaded position .The bars should angle down when not sinched up in place ,in other words they should not be level or parallell to the tongue .The angle depends on the rating of the bars and the tow vehical you have ,heavy duty 3/4 ton truck ,lighter bars ,1/2 ton or car heavier bars.The angle should not be excessive.thats how the WD hitches load the frames of the tv and trailer thru those bars.
Scott
scottanlily is offline   Reply With Quote
Old 06-13-2006, 08:26 AM   #9
bhayden's Avatar
1978 24' Argosy 24
After reading the instructions (gasp) and actually using the Reese hitch it's not as complex as I first thought. I understand the angle adjustment for "dialing in" the tension. It's a nice concept because right now I think I'm putting just a shade too much weight on the front but not enough to drop an entire link. The angle adjustment lets you get a "half link" adjustment. The other advantage of the Reese trunion style is you don't need as much room under the hitch to slide the bars in. They can be an issue when you're hooking/unhooking "off road".
I think the big difference with the Reese vs the EA-Z-Lift is the height adjustment. I saw an EA-Z-Lift (or Robins copy) yesterday that used an adjustable head. I guess with the adustable head you sort of need the extra bolt to snug up the installation so might as well make it adjust for angle.
I'm using 800# bars with the Argosy 24' which I think is just about right. Could probably get by with the lighter bars but the 1000# bars would definitely be too much. Don't remember what the EA-Z-Lift bars are rated at but I think they're pretty comparable.
-Bernie
Old 06-13-2006, 10:03 AM   #10
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
My sentiments exactly. I've enjoyed great service at Oasis since we found them in 1998. Jay Breshears, the Service Manager, is a veritable font of information and the keeper of the "straight scoop," as opposed to the "bum scoop" we so often receive. Rick, in the Parts Department, has always shipped any parts I need the same day I call or the very next day.
I'm glad you had a similar experience.
Ken L
1966 Tradewind 24
Old 06-13-2006, 10:22 AM   #11
1992 34' Excella
riverhead , New York
Tongue weight and stabilty
Hello Steve, I tow with an Astro van. I have a 34' excella 1000. It weighs 8700 lbs. My tongue weight is 780 lbs. I have no sway when trucks pass me at all.
We get our rig weighed at least once a year. We have each wheel of our rig weighed individually.
We use an EZ lift welded hitch head with 750 lb. weight distribution bars. If we are towing locally we do not use any anti sway bars. When we go on interstates we do, although if the pavement is wet I take off most of the friction.
If you want to learn from serious professionals about towing safely I would suggest that you contact the Recreational Vehicle Saftey Education Foundation or RVSEF and contact Andy Thompson from Can-Am-Rv in London Ontario.
We tow about 10,000 to 20,000 miles per year.
We are currently in Rapid Ciy, South Dakota and on our way to Salem Or. for the International Rally and then onto Alaska. We hope to be home in Long Island NY by early September.
You should be congratulated for being so aware of the changes in your rigs handling and wondering why the change. Most people leave it un-noticed or just buy a bigger anit-American gas guzzling truck and sacrifice handling for power. Good luck.
Joe Colao 50th Anniversary President of Metro NY WBCCI # 30916
KC2RAR
joecolao is offline   Reply With Quote
Old 06-13-2006, 10:38 AM   #12
bhayden's Avatar
1978 24' Argosy 24
Whoa, we're using a 2000 GMC Safari AWD with factory tow package and the rated max towing capacity is 5800. That happens to be exactly the GVWR of our 1978 Argosy 24. Haven't check the ball to rear axle length ratio but we exceed the TV wheelbase to trailer length guidelines by about three feet.
I'm still getting the hitch, brakes, tire pressures, etc. dialed in. On our first big trip over Washington Pass (North Cascades Hwy, 5,500' elev) I was surprised at how well the rig did. We kept the load down to a minimum so I'm guessing 600-800 pounds in the van and less than 4500# trailer weight. Haven't used the friction sway control yet and didn't need it. However, I'm guessing it would be a help in cross winds we often encounter in mtn passes and eastern Washington.
I put a synthetic blend oil in the engine which made a noticable difference and I've got a set of heavy duty KYB shocks I need to get put on. What else have you done to beef up the towing capacity of your Astro? Unloaded our ground to fender well distance is 29-1/2". It's just a shade over 28-1/2" with the trailer hitched up. Our tongue weights aren't all that different but I'm wondering how much suspension compression you experience. We're seeing about 11mph back and forth over the mountains. I'm guessing we're around 12mpg if we could ever find flat roads without winds.
-Bernie
Old 06-13-2006, 04:46 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Joe, Run this by me again, please. Even assuming you have a 3.73 axle ratio, your 2000 Astro has a tow limit of 6,100 lbs. You say your Excella weighs 8700. Call me anti-American if you wish, but I'm not sure exactly what you are advocating. Does the RVSEF really say an Astro has the power, and the wheel base to safely tow a 34' Excella.
Ken L
1966 Tradewind 24
Old 06-13-2006, 05:49 PM   #14
1997 30' Excella
Waddell , Arizona
Images: 13
Jay called me today to tell me the bad news about my 9 year old Dometic. Despite an earlier report that it seemed fine he said as soon as the outside temp topped 100 degrees my fridge went over 50 degrees inside. So when I pick up my trailer on Friday I'll have a brand new Dometic and a much lighter wallet!
Steve Heywood
Waddell, AZ
2003 30' Classic..TMV opinion???? AZstreamin Trailer Values 13 04-26-2006 09:05 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
hitch weight? Stan Z 1965 Caravel 4 03-23-2005 07:31 AM
Full timeing Airstreem T/T/ tec12 Our Community 7 11-13-2002 01:13 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
