Old 10-28-2011, 10:47 PM   #1
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Tongue weight
We are waiting on delivery of a 25FB Flying Cloud. We will be using a Chev Trailblazer as a TV. The only problem I see is in tongue weight capacity. The Trailer has a tongue weight of over 800 lbs and the Trailblazer is not rated nearly that high. We were told that a good weight distribution hitch such as a Hensley arrow would solve this problem. I realize the Trailblazer is not ideal but it is what I have and need to use right now.
Dan
danlehosky is offline   Reply With Quote
Old 10-28-2011, 11:04 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, from what I have just read, the Trailblazer with the 6.0 L V-8 engine is not rated high enough for this trailer. [6,800 lb tow rating] No hitch can change that. Before we bought our 25' Airstream, [6,300 GVWR] I had a wonderful Explorer Sport. [5,000 lb tow rating] It got replaced with a Navigator. [8,900 lb tow rating] You need a proper sized/rated tow vehicle no matter what hitch you decide to buy/use. [my opinion]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 10-28-2011, 11:54 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Tow ratings are a factory recommendation based on the vehicle equipped as sold. A set of Extra Load tires, heavier rated hitch, or transmission cooler can improve the vehicle's ability significantly. Almost surely enough to use your vehicle for the new trailer.
This must be as instructed by an Airstream towing expert, the most experienced and best is here:
Can-Am RV Centre | New and Used Travel Trailers, Motorhomes and Fifth Wheels | Towing & Hitch Specialists | Top Airstream Dealer
Andrew Thomson is the second generation owner and very generous with his help. Check out their website and email or give them a call. They will help you.
doug k
Old 10-29-2011, 05:37 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
It is not just the pulling capacity that you need but also the braking capacity. Your TV must have the brakes to stop the combination. The trailer brakes help but you need the capacity of the TV as well. The other thing is the weight of the trailer vs the TV. The trailer will start to try to throw the TV around and make it uncontrollable in an emergency situation. The car companies give a rating so that they will not be liable if you go over their ratings.
Old 10-29-2011, 06:05 AM   #5
bike_addict's Avatar
Pearland , Texas
From his other posts I don't think this is the trailblazer that he has. I believe these numbers are from the older model that is now the Tahoe. I believe he has the newer version which is a mid-size SUV with much smaller numbers.
- Ronnie
bike_addict is offline   Reply With Quote
Old 10-29-2011, 09:28 AM   #6
TahoeStream'n
subfan1's Avatar
2019 23' International
La Habra , California
If memory serves me, the Trailblazer is not made anymore. When it was made it had an in line 5 cyclinder engine and towards the end of production GM shoe horned a small V-8. It was also a short and long version. This was a midsize SUV andthe Tahoe mentioned above was also made however that is a full size SUV, which is still being produced.
Its a small SUV but, the Can Am people say a mini van can tow a 30 footer so...Good luck.
subfan1 is offline   Reply With Quote
Old 10-29-2011, 04:13 PM   #7
dznf0g's Avatar
Oswego , Illinois
Trailblazer never had a 5 cylinder. Only the mid-pickups had the 5 (or a 4). All Trailblazers had the inline 6 until the 5.3 became available.
-Rich-
Old 10-29-2011, 04:16 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Life will be easier by keeping to one thread, versus several:
Trailblazer Towing
overloading, tongue weight
25FB flying Cloud tongue weight danlehosky Tow Vehicles 2 10-27-2011 09:36 PM
Lightest weight usable oven/stove? HHaase Stoves, Ovens & Microwaves 4 10-02-2011 10:56 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
Too much tongue weight for hitch? 78 Tradewind 25ft ashe Hitches, Couplers & Balls 2 01-04-2009 02:54 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
