Old 03-09-2010, 04:31 PM   #1
Los Angeles , California
Tongue scale?
Does anyone have experience with this tongue scale?
Sherline Trailer Tongue Weight Scales
Regards,
Mel
______________________________
1964 Little Dipper TT by Northwest Coach (7'X13')
patis is offline   Reply With Quote
Old 03-09-2010, 04:40 PM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Yes,
I have one. It works fine. I set it on the platform of a good automotive floor jack and the top in the ball socket on the tongue. You can buy additon guages that you can swap out on the main body. I have 0-1000 and a 0-5000 Lb guages.
Ken.
Old 03-09-2010, 04:44 PM   #3
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Yup. Works great. Be sure your trailer is dead level, for an accurate read.
boondockdad is offline   Reply With Quote
Old 03-09-2010, 04:56 PM   #4
Ag&Au's Avatar
I have heard that said before. But, as I figure it, even if you are a whole ten degrees off, your result is only going to be off by 1.5%. That was done with high school trig. Anyone care to prove that wrong?
Regards,
Ken
Old 03-09-2010, 05:02 PM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Hmmm, does your equation include the axle weights (different pre - loads of the suspension) and what length the ball is to the axles?
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 03-09-2010, 05:23 PM   #6
Ag&Au's Avatar
The change in distance from the axle(s) is what causes the 1.5% Since we are measuring tongue weight I can't see in what way the preloads of the axles affect it. In the case of dual axles I would use the center of where the two tires touch the ground. It appears to me whatever the front axle contributes will be canceled by the opposite action of the rear axle.
My equation is: the new weight = level weight * Cos(angle the Front of the trailer is high).
The rules are that you can't disprove it without a better equations.
Ken
Old 03-09-2010, 05:38 PM   #7
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Changing the rules already I am talking about dual axles. When the ball is lower than level, it puts more load on the front axle which makes the tongue weight less than what it really is. if the ball is higher than level, the rear axle is putting more load on the tongue. Sorry, no equation. I think that is why it needs to be level. The more it is out of level, the more variance in tongue weight.
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 03-09-2010, 06:05 PM   #8
Ag&Au's Avatar
That makes sense, but what is interesting is that effect counteracts the change I was computing and I'm sure effects it more. The only point I am really trying to make is that I believe if the trailer measures anywhere close to level with a simple level, then the measurement is going to be close enough for government work. I should know, I worked for the government for 43 years. Maybe that explains something. At least it ought to convince anyone that it is futile to use logic with me. When I get less lazy I will make an equation to compute that effect for some typical trailer and post it back here.
Regards,
Ken
Old 03-09-2010, 06:11 PM   #9
r carl's Avatar
Lin , Ne
I think you should weigh it at the height it is when its hooked up to the tow vehicle.
r carl is online now   Reply With Quote
Old 03-09-2010, 06:21 PM   #10
Ag&Au's Avatar
In my case, I try for that to be level. And if it looks level to me, then, by gosh it is level.
Ken
scale model Airstreams thunderbird Off Topic Forum 9 08-30-2016 07:20 PM
Scale from Kitchen faucet 77Overlander Fresh Water Systems 1 11-08-2009 05:00 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Cat Scale Etiquette campadk Towing, Tow Vehicles & Hitches 15 11-24-2006 03:46 PM
HO scale Buick and Airstream! dinoburb Our Community 2 09-19-2004 07:53 PM
