Old 05-30-2016, 02:10 AM   #1
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Tightening Torque of ball mount ?
Hello,
I have to change the direction of the ball but I doní know the tightening torque of the screws
126 lbs.ft ?
Thank you !
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 05-30-2016, 02:21 AM   #2
1991 25' Excella
Stanfield , Oregon
Look it up in the onwers manual that came with the hitch. If its not available then contact husky directly.
SpletKay06 is offline   Reply With Quote
Old 05-30-2016, 02:26 AM   #3
GaŽl's Avatar
1960 26' Overlander
Images: 8
Thank you for your quickly answer but I haven't the owner manual.
I have only for the hitch, not for the ball mount.
I'm looking for to contact husky service.
1960 Overlander
Old 05-30-2016, 04:21 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Gael: I don't have a Husky, but found this site and if you scan down you will see installation instructions, my bet is the various torques will be there. http://www.huskytow.com/ Good luck
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
paiceman is online now   Reply With Quote
Old 05-30-2016, 04:33 AM   #5
Images: 59
350 Nm.
Instruction manual.
Old 05-30-2016, 05:39 AM   #6
2016 25' Flying Cloud
Holly Springs , Mississippi
On the Curt, it's 200 ft. pds. if that's of any help.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 05-30-2016, 06:16 AM   #7
GaŽl's Avatar
1960 26' Overlander
Images: 8
Thank you very much, you help is important.
As the document, you show, the indication is : 260 lbs.ft (page 5)
Is relatively the same than 35 m.kg but Bob, where have you seen 200 lbs.ft ?
Thank you
1960 Overlander
Old 05-30-2016, 04:50 PM   #8
Thank you
The Curt install instructions. Curt uses 3/4" bolts for the hitch-to-shank connection. If your bolts are also 3/4" diameter I'd think the torque would be the same, but if you have the instructions for your hitch, and it says 260 ft. lbs., that is what I would use.
2016 FC 25' FB twin
Old 05-30-2016, 05:20 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I doubt the bolt is 3/4". It may take a 3/4" wrench or perhaps a 7/8" or maybe a 15/16" wrench. Which would be 1/2", 9/16" or 5/8" bolt size respectively.
You can look the torque specs up on the Internet. Just find the correct size and grade. There is nothing special about these bolts. From the photo it looks like they are grade 8.
Old 05-30-2016, 05:29 PM   #10
Images: 59
The dirfference in torque may be due to different screw finishes.
The torque for Grade 5 plated 3/4"-10 cap screw is 200 ft-lb.
The torque for Grade 5 plain 3/4"-10 cap screw is 266 ft-lbs.
Old 05-30-2016, 05:43 PM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The bolts are 3/4", and require a 1 1/8" wrench and socket.
Old 05-30-2016, 06:15 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I stand corrected. You can still find the torque specs for the specific bolt you are using on the Internet.
Old 05-31-2016, 09:40 AM   #13
K3ors's Avatar
2005 19' Safari
Jackson , Tennessee
I guess this shows my ignorance, but I've never heard of that concern before. I've got a. 19' Bambie. The TV is a Ford F-150.
How important is that torque?
K3ors is offline   Reply With Quote
Old 05-31-2016, 10:05 AM   #14
Images: 59
In Tennessee it would be "pretty tight, but don't break it off".
Lug Nuts on a new Airstream & Tightening J5MM 2011 - 2015 International 15 05-30-2016 06:30 PM
Wall removal or tightening advice rodsterinfl Cabinets, Counter Tops & Furnishings 0 03-29-2013 08:21 AM
Antenna tightening RosiesGuy1 Audio, Video & TV 0 03-03-2011 04:56 PM
Tightening hitch ball on Equalizer ESCAPE POD Hitches, Couplers & Balls 20 03-14-2008 08:32 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
