Old 05-31-2016, 10:45 AM   #15
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I use this method: Use your biggest wrenches and tighten as much as you can with the strength you've got. Which will probably turn out to be somewhat less than what is called for in the specifications.
Lynn
WBCCI 21043
Old 05-31-2016, 11:48 AM   #16
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Husky firm confirms me that is 260lbs.ft
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 06-01-2016, 06:34 AM   #17
K3ors's Avatar
2005 19' Safari
Jackson , Tennessee
Torque umph
Thanks for the Armstrong Torque comments. That's what I've used for years ---- so far so good :-)
K3ors is offline   Reply With Quote
Old 06-01-2016, 08:09 AM   #18
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
This is slightly off topic but still related.
I carry a 3/4" drive hitch ball socket and a 40" 3/4" breaker bar.
At any AS rally or such I've shared this combo with any one interested in checking the hitch ball nut that has been tightened by some oh yeah that's tight method. Lost count of the number of loose ones, found a couple that were tight and replaced 3 hitch balls that showed damaged threads or shanks from being loose and banging around. Latest ones this past weekend a loose one for a newbie including loose shank bolts and a lets throw that hitch ball away from a veteran tower.
The loosest one could be snugged with channel lock pliers by the owner before I came back with correct socket.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-07-2016, 02:37 AM   #19
GaŽl's Avatar
1960 26' Overlander
Images: 8
Hello,
I've change my ball mount
1960 Overlander
Old 06-07-2016, 03:44 AM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Did you tighten the ball? Torque is on the order of 400 foot pounds.
Originally Posted by GaŽl View Post
Hello,
Old 06-07-2016, 06:08 AM   #21
GaŽl's Avatar
1960 26' Overlander
Images: 8
I didn't touch the ball, only 2 screws.
When I received the ball mount, the ball was already on place, it seems tight correctly but I haven't check it.
1960 Overlander
Old 06-07-2016, 06:50 AM   #22
2016 25' Flying Cloud
Holly Springs , Mississippi
Actually, for the 1-1/4" shank tow balls, the torque is 450 lbs. ft. (according to Curt).
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 06-07-2016, 06:58 AM   #23
GaŽl's Avatar
1960 26' Overlander
Images: 8
I've already tow a caravan with this ball mount without check the tighting of the ball.
I hope it's ok ! I'll check often...
1960 Overlander
Old 06-07-2016, 01:36 PM   #24
GCinSC2's Avatar
Looks like you have more than enough of a torque wrench, good job.
It's not an accurate check but it quickly shows an incompletely tightened ball is to look at the lock washer. ANY gap above or below is immediately suspect.
S/OS #001
Old 06-07-2016, 01:53 PM   #25
GaŽl's Avatar
1960 26' Overlander
Images: 8
The lock washer is perfect, no gap.
I'll make a mark on the nut and on the screw
1960 Overlander
Old 06-07-2016, 01:59 PM   #26
GaŽl's Avatar
1960 26' Overlander
Images: 8
Lynn
Lynn,
Sorry, I haven't seen your message before now...
Thank you for your advize but I'm afraid to loose my ball mount during the towing...
grrrrrr... it should be a nightmare
And a colleague lent me its torque wrench
1960 Overlander
Old 06-08-2016, 07:17 AM   #27
GaŽl's Avatar
1960 26' Overlander
Images: 8
1960 Overlander
Old 06-08-2016, 09:46 AM   #28
GCinSC2's Avatar
Gael,
The torque wrench is the final tool, you have a very capable one by the pic.
The gap inspection is just that a quick look that doesn't replace checking with correct tools but it quickly proves it needs attention. Often dramatically. I have used dollar bills to show to the non mechanically inclined.
Did you see your selfie in the chrome?
Nicely done.
Gary
S/OS #001
Lug Nuts on a new Airstream & Tightening J5MM 2011 - 2015 International 15 05-30-2016 06:30 PM
Wall removal or tightening advice rodsterinfl Cabinets, Counter Tops & Furnishings 0 03-29-2013 08:21 AM
Antenna tightening RosiesGuy1 Audio, Video & TV 0 03-03-2011 04:56 PM
Tightening hitch ball on Equalizer ESCAPE POD Hitches, Couplers & Balls 20 03-14-2008 08:32 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
