Old 03-12-2008, 02:07 PM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Tightening hitch ball on Equalizer
The AS dealer prepared our Equalizer hitch (which I had to reverse to fit the lower receiver of our Dakota), and secured the hitch ball as part of the assembly. I've begun to notice that the hitch ball has loosened slightly, and I want to tighten the nut, which is recessed on the underside of the hitch, making it inaccessible to a closed or open end wrench. Is there such a thing as a socket that can fit the approx. 2" diameter hitch ball nut?
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 03-12-2008, 02:13 PM   #2
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Yes there is:
Equal-i-zer Hitch Store: 1 7/8" Thin walled socket
and it cost $74.00!
I have one and have yet to use it. Oh, it takes an extra large socket wrench, too. I think it takes a 5/8" shank?
Family of Disney Fanatics
WBCCI# 4821
Old 03-12-2008, 02:56 PM   #3
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
There is most likely a lock washer on the ball shank before the nut. A Pipe Wrench or large adjustable wrench will work on the ball if there are flat spots on the bottom of the ball.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 03-12-2008, 02:58 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Not many people have these. I usually run up to the dealership every year and have them make sure it is tight. I think my dealer ground down a socket to fit in the tight clearance.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-12-2008, 03:18 PM   #5
Tom O
Toldfield's Avatar
1966 17' Caravel
Altadena , California
Gosh, they are a little pricey. Any competent tool store should have a thin walled impact socket in the proper size. Not being a fan of Harbor Freight Tools I would look at Sears if you don't have a good parts store nearby.
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
CA-7
Toldfield is offline   Reply With Quote
Old 03-12-2008, 03:31 PM   #6
2006 30' Safari
Orlando , Florida
BTW, the socket requires a 3/4" drive...my bad.
WBCCI# 4821
Old 03-12-2008, 03:35 PM   #7
I found that a 1 13/16 socket from Sears worked ($24). It did require some grinding on the hitch and socket to make it work, and it is still a tight squeeze. The 3/4 inch breaker bar or ratchet is not cheap either. If you are close to the dealer, let them do it for you.
bensonortho is offline   Reply With Quote
Old 03-12-2008, 03:50 PM   #8
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Remember, always tighten enough to make the balls sweat!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 03-13-2008, 01:17 PM   #9
Airstreamer67's Avatar
Although my application is not the same, what I do to tighten the ball when I can't get a socket or wrench on the nut is to jam a screwdriver between the nut and the hitch wall where it's too tight to get a socket in. Then, I use either a large fixed wrench or crescent if there are flats on the base of the ball, or a pipe wrench on the round base of the ball, and it tighten that way. It's a reverse of what's usually done, but a boy's gotta do what a boy's gotta do. Like asking directions, I just hate to go to someone else to tighten that thing.
Airstreamer67 is offline   Reply With Quote
Old 03-13-2008, 02:21 PM   #10
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
No room for any kind of socket or wrench on mine. I do what Airstreamer67 does.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-13-2008, 04:09 PM   #11
ESCAPE POD's Avatar
2007 19' Safari SE
Great solution!
Many thanks, Airstreamer '67 and Dave! A pipe wrench on the hitch ball just never entered my noggin. I'm picking up our Bambi tomorrow from the A/S maintenance guy (Rod, at C & G Trailer in Bellflower, CA); he also said he could tighten the ball when I show up. But I'm definitely going to get a decent pipe wrench anyway. Do either of you use any tape to protect the neck of the ball?
-Jerry
Jerry & Susan
Old 03-13-2008, 04:33 PM   #12
Fyrzowt's Avatar
Images: 8
I was able to keep the pipe wrench teeth down on the bottom flange. You don't want to chew up the ball or neck.
It may be worth while to watch Rod and see how he does it.
AIR #15800
2000 Safari SS 25'
Old 03-13-2008, 05:56 PM   #13
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
I let the local dealer tighten mine. The RV Tech did it quickly using an impact wrench. I believe it was 430 lbs of torque. Dealer didn't charge me either.
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 03-13-2008, 06:26 PM   #14
Old_Town's Avatar
North East , Texas
Sears Has the socket!
This is the socket I used. My Equalizer is a 2006 vintage. I can't speak for the older ones. The Craftsman socket in the link below fit and worked perfectly. I borrowed, from a friend a Proto 3/4" drive torque wrench for the job. I noticed that my local Tractor Supply had the socket for $19. I prefer the Craftsman.
Craftsman 1-7/8 in. Socket, 12 pt. - Model 47787 at Sears.com
Regards,
Ty
Old_Town is offline   Reply With Quote
equalizer hitch chaunceyboy Hitches, Couplers & Balls 9 06-14-2007 01:02 PM
How Big a Hitch Equalizer??? Sundance Hitches, Couplers & Balls 17 04-28-2007 10:12 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Equalizer hitch rambling... BillTex Hitches, Couplers & Balls 77 08-09-2006 09:33 AM
Need used equalizer hitch lebolewis Hitches, Couplers & Balls 5 05-22-2006 09:41 AM
