Old 02-24-2016, 09:36 PM   #1317
2007 22' International CCD
The unofficial pp users guide...
18-yr old daughter and 'over 21 three times and then some' self did in in a few hours with the help of a floor jack and a bottle jack to do the heavy lifting. Be sure to get the 250 foot-pound torque wrench, you will need it.
The instructions are good and fairly easy to follow. Read them first!
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 02-25-2016, 05:29 AM   #1318
2016 30' Classic
Lorton , Virginia
Nice. The head is like 100 lbs? I'd imagine that could be awkward to support while bolting it up.
Zybane is offline   Reply With Quote
Old 02-25-2016, 07:28 AM   #1319
Hence the floor jack. Once the ball is in and locked it's easier. Have grease handy as well to grease ball and bar sockets
KE4GNK/AE
Old 02-25-2016, 08:16 AM   #1320
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Carefully follow the suggestion of mounting the hitch head. It will save your back! I installed the ProPride by myself.
We found the "u" brackets on the bottom of the frame jacks were really loose on the Classic frame rails. I chatted with Sean and he made two " thick steel plates with an indent in the middle on one side to fill the gap on our Classic's A frame. A few love taps with a hammer were necessary on one side to align the indent up with the locking bolt.
We also had to modify the round rub rails on the jack stands so the propane tanks' cover box would not rub on the jacks and trim the shoulders on the flat plates of the jack stands to allow access to the battery box. These modifications were approved by Sean.
I might be able to add a few more washers to get a slight downward angle to the stinger (like my Hensley Arrow stinger was slightly bent by CanAm for the Mercedes to help preload the WD arms with less cranking).
Name:	Curb side 1-Quick Preset_1841x900.jpg
ID:	257832   Click image for larger version
Name:	Curb side 2-Quick Preset_1472x900.jpg
Name:	Curb side 3-Quick Preset_900x1535.jpg
ID:	257834   Click image for larger version
Name:	Street side 1 -Quick Preset_1972x900.jpg
Name:	Street side 2-Quick Preset_900x1161.jpg
ID:	257836   Click image for larger version
Name:	Hitch head 1-Quick Preset_990x899.jpg
Name:	Hitch head 2-Quick Preset_899x968.jpg
Old 02-25-2016, 11:14 AM   #1321
2016 30' Classic
Erie , Colorado
If you follow Sean's instructions EXACTLY you won't need a floor jack to mount the head. Stinger gets built, put in the TV receiver. Slide the head on the Stinger and then back into the trailer and lower tongue on the Head ball. Piece o'cake.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 02-25-2016, 10:02 PM   #1322
2016 30' Classic
Lorton , Virginia
Very helpful guys!
I emailed Sean to see if he can include these 1/4" spacers.
So far the tools required for the install I gather:
1. Full socket/wrench set.
2. Heavy duty torque wrench (250 lb ft)? And/or breaker bar.
3. Hammer.
4. Possibly floor jack.
5. Dremel to possibly trim some edges.
6. Do I need to drill anything, and if so, what size drill bits?
7. Wheel bearing grease.
EDIT: Sean just emailed me and said the metal plate spacers are now included with all 3P's. He also said there is no need to trim any metal, just to move the jacks back.
Old 02-25-2016, 10:07 PM   #1323
No drilling needed as I remember just jumping on wrenches. A piece of cardboard to lie on helps
KE4GNK/AE
Old 02-26-2016, 06:42 AM   #1324
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You "can" lift the "ProPride" head by raising trailer bow then using ramp to set the head higher, then lower the bow onto the "head", latch up then Raise bow.
Of you have a "creeper" or furniture dolly, you can move to place the head more precisely and repeat she steps above.
To tighten the hitch stinger, tighten until as tight as possible. Then take to a big truck shop and ask them to properly tighten... The boss will probably help to do it cheaply... Of course, having your own impact capable of proper torque is not a bad idea in case you need to loosen and refine adjustment in the future.
You can set the angle using proper washer stack enabling good "preload" of the weight bars.
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-26-2016, 07:46 AM   #1325
switz's Avatar
2014 31' Classic
Images: 8
We had to have the jack stands as far forward as the instructions allowed for the future battery box that was to be made to go against the front skin of the trailer for the four Lifeline 6ct batteries. It was all a very tight fit on the "A:" frame.
Old 02-27-2016, 01:54 PM   #1326
2016 30' Classic
Erie , Colorado
Anyone looking for a used ProPride, rarest item in the galaxy, see this ad on the forums/classifieds.
http://www.airforums.com/forums/f534...ch-147265.html
Gary
2015 Classic
ProPride
NVPN
Old 02-27-2016, 02:33 PM   #1327
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Greased the ball on ours today. Of course the dealer who assembled it, never did......
DoublTrouble is offline   Reply With Quote
Old 02-27-2016, 02:56 PM   #1328
Now you see one of the many reasons I do my own maintenance and installs wherever possible.....
KE4GNK/AE
Old 02-27-2016, 07:26 PM   #1329
2016 30' Classic
Lorton , Virginia
That's why you install stuff yourself to know it's done right. The American service industry has gone to hell in a hand-basket. No one gives two craps about your equipment or doing a proper job.
Old 04-03-2016, 02:06 PM   #1330
Redmond , Washington
I'm doing my routine maintenance in my hitch. This time, however, I removed the weight distribution bars. It's amazing how much force this little retainer disks have to withstand. They take some beating...
chracatoa is offline   Reply With Quote
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 10:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
