07-18-2015, 08:52 PM
#1221
2015 27' FB International
Howard
, Ohio
Originally Posted by SteveSueMac
Sure thing. I'm just amazed I can find nothing on the jacks themselves! Even the BAL site itself has no information. Just weird!
You might want to call Sean. I don't know how hooking up your WD chains from another hitch might/might not work...
Even if the entire jack is toast, I bet Sean could ship one to you...
Good luck!
Couple of updates. I did speak with Sean and he will send a replacement jack at the end of the month. All his inventory is "on the way out" on hitches. He gave some advice on disassembly which I may try this week if I have time. He suggested inspecting the threaded rod that runs up the center of the jack and cleaning it up if there is some thread damage.
SteveSueMack, BAL has a tongue jack that has the same silver cover and a side manual handle. Sean probably has a version made without the foot would be my guess.
07-19-2015, 10:28 AM
#1222
Redmond
I'm not near my trailer and don't recall where the pin was located but your description sounds right to me. I was at a rally and snapped it with my drill. Bruce helped identify the broken part and told me how to find a replacement at the local hardware store. Then he told me to never use that tool on those jacks again and I said "yes sir"
Interesting, I think we can use drills. If you look at the video #6 on the ProPride site they use a drill. I always use a drill though I move the tongue up to make it easier. If I can't do that (sometimes the WD bars are in the way) I use the drill until it stops and then the wrench.
07-19-2015, 11:04 AM
#1223
Port Orchard
I do not, nor will I, use a drill. However, I think the proper thing to do is use a drill that will stall before reaching the breaking point of the pin.
It would seem to me to be a good idea if those who use drills post the specs of their drill and whether or not they have broken the pin yet.
Ken
07-19-2015, 11:08 AM
#1224
2020 Classic 33
Box Elder
, South Dakota
I use a 20V Porter Cable. Torque setting at max. Low speed setting. Two PP's and have not broken a pin. However I did break a pin using the 20V Porter Cable Impact Wrench from the set. Don't use an impact wrench. Pin is easy to replace.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
07-19-2015, 11:28 AM
#1225
Longport
, New Jersey
Maintenance recommendations seem to only be tending to the grease zerks on the bars when they become noisy during turns. is there anything else I should be doing?
This thread is so long - I apologize if the information has already been laid out. I just can't seem to search efficiently on my iPhone.
07-19-2015, 12:08 PM
#1226
2012 25' FB International
Trent Woods
, North Carolina
I use a B&D 12v drill, max torque and it stalls about 1/2" before the jack is set right, so I use the supplied wrench for the last bit. Never had a problem with that approach.
As for lube, I have only lubed the zircs(zerks?) and the ball. Do I need to do something with the jacks?
Larry
07-19-2015, 12:51 PM
#1227
Redmond
I have a RYOBI drill 18v P202. I use set 21 (heavy drilling) and low speed (1) - since low has more power and torque.
07-19-2015, 03:04 PM
#1228
1999 34' Excella
Hillsboro
Rigid impact/drill set to high torque, non-impact, low gear. Tongue jack holding load.
Peace and Blessings..
Channing
WBCCI# 30676
07-19-2015, 03:29 PM
#1229
2012 27' Flying Cloud
W
, New England
Sorry - I should have said 18v Impact wrench - not electric drill. Don't use those :-)
07-19-2015, 03:45 PM
#1230
2007 27' Classic FB
Fredericksburg
I use a DeWalt 18v, sometimes on high speed sometimes on low speed. I always raise the front end with the power jack to take the strain off the hitch jacks when raising them. I have never broken a pin, about 20,000 miles of towing but I stopped a few times along the way.
The Tex-i-can is Ready to Camp
07-20-2015, 04:20 AM
#1231
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
Ditto on using the drill (18 volt craftsman) with the jack raised and then finishing with the wrench. No problems. Routine maintenance with hand grease gun on three zerks. I would not wait until I heard noise to use the grease gun.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
07-20-2015, 06:23 AM
#1232
2012 25' Flying Cloud
Battle Lake
I like to use the stabilizer speed wrench supplied with the Airstream for the ProPride screw jacks, and a compact electric drill for the stabilizers. Snug all of them with the ProPride-supplied ratcheting wrench.
Doug and Cheryl
07-20-2015, 09:26 AM
#1233
2017 25' International
Carlsbad
I did use Ryobi drill a few times. I found the process to be noisy. Now use stabilizer speed wrench which is much more peaceful. I do not use the Propride wrench anymore after smashing my pinky finger, losing nail and a pretty sore week.
07-22-2015, 10:06 AM
#1234
Redmond
>>ron<<
Wait, three zerks?
07-23-2015, 04:13 AM
#1235
2011 30' Classic
1993 32' Excella
Largo
I have an additional zerk fitting on the top of the ball for lubrication.
>>ron<<
07-23-2015, 05:23 AM
#1236
W
, New England
>>ron<<
Did you add that yourself? I didn't know it could come from the factory that way...
07-23-2015, 07:00 AM
#1237
2011 30' Classic
1993 32' Excella
Largo
Steve,
Before installing the PP I drilled and tapped the very top of the hitch to receive the zerk. I'll take a picture later today and post it.
>>ron<<
07-23-2015, 08:34 AM
#1238
2020 Classic 33
Box Elder
, South Dakota
Since the ball doesn't move/rotate like a standard hitch I simply use a floor jack to drop the head once a year and put some Reese ball grease on it. Old grease usually still looks like new.
Gary
NØVPN
07-23-2015, 09:13 AM
#1239
Oswego
X2....takes maybe 15 minutes.
-Rich-
07-23-2015, 04:44 PM
#1240
Carlsbad
Ok. I'm lost because dealer installed. I need to study manual...
