Old 03-17-2014, 09:09 AM   #799
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Moving more weight to the front axle of the truck through the WD system will also move weight to the TT axles. I am not sure how much weight will move. But it would worth a trip to the scales to find the best option to give you some payload capacity.
Your trailer axles are probably 3500# axles. I believe your trailer has a gross rating of 7300#.
Do you have any items packed in front of the trailer axles that could be moved back to reduce tongue weight?
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-17-2014, 09:45 AM   #800
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Ghaynes,
Thanks for the spreadsheet. I printed it so I could mark on it and study the numbers.
A couple of questions:
1. when you weighed the truck alone, did you have the PP stinger in the receiver?
2. what is the front axle weight restoration specification on your truck. You are at ~50% as is.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 03-17-2014, 10:59 AM   #801
2016 30' Classic
Erie , Colorado
Alan
1. PP stinger was in the truck.
2. It is 50%. Front axle truck only, 3440. Hooked up with no WD tension, 2960. 50% of the delta is 240# so target would be 3200#. Actual with jacks at 7 inches is 3240#.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-17-2014, 11:03 AM   #802
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
So-
Cat scales indicates in 20# increments-
I reckon that's close enough for gubment work!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-17-2014, 11:03 AM   #803
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
As you raise the jacks you also put some weight on the trailer axle. I don't know how much more you'd get with one more inch - maybe 60-80#? With the 1400# bars you should be able to move more if you like.
Other than wife and dog, what else are you missing to be "fully loaded" for camping? You may also have too much stuff in your trailer or truck - less is usually more.
Last, you may have some items in your trailer that you could move further away from your truck (behind the axle) to lighten the tongue a bit.
Thanks for the pic of the spreadsheet. Ron is a bit of a genius in my view - he was VERY helpful as I was working through my numbers.
SteveSueMac is online now   Reply With Quote
Old 03-17-2014, 11:12 AM   #804
2016 30' Classic
Erie , Colorado
Steve
Only items in the trailer were misc tools in the front storage area, dump tools and hoses in the back compartment. Partial fill on Propane (45# vs full 60#). Truck bed empty. Just me and a full tank of gas.
I can see the transfer to the trailer going from 7 inches down to 5 inches.
The advertised tongue weight from AS is 830# and with about 200# of PP hitch the 1080 calculated tongue weight seems to be on target.
Gary
2015 Classic
ProPride
NVPN
Old 03-17-2014, 12:37 PM   #805
Alphonse's Avatar
Lower Alabama , USA
Originally Posted by ghaynes755 View Post
Alan
So here are my observations:
1. the tongue weight is 1080 plus the weight of the stinger. Unfortunately the stinger counts too and the way you captured the weight, it was left out. So depending on the tongue weight capacity spec. for your hitch, you may be over by a significant percentage.
2. Back to your original question - yes, you are pretty much limited out on the trucks rear axle (therefore cargo capacity) and you will need to be careful about carrying too much additional weight as cargo in the truck.
Both of these are the dilemma of the 1/2 ton truck unless you are comfortable in exceeding the specs.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 03-17-2014, 07:23 PM   #806
W , New England
My take away is that my 2014 GMC Sierra 1500 is maxed out, both with weight and axle limits. Weights were with full fuel, full fresh water, waste tanks empty, some but not all of our gear in the trailer and the truck bed empty. Wife and dog were not included.
Well, I think your take away is correct (and I realize some would say there's probably more headroom there than GM gives in published numbers). But you're already at GVWR for your truck and you're not yet fully loaded for camping.
You could try 8" on the jacks and while that might move some weight to the trailer, it doesn't appear to be enough to compensate for loading up for camping.
You're not so far over - but where do you draw the line? 1 pound? 10? 100? 1000?
This is a tough one. For me (an admitted rule-abider when it comes to towing), I'd consider a different tow vehicle. Other here will think I'm crazy (and probably not only for that opinion :-/
I would recommend a PM to Ron G at this point. He found some stuff in my numbers I didn't see first time around (including a spot on guess at my (personal) weight based on my tickets - yikes! ).
Good luck!
Old 03-17-2014, 08:17 PM   #807
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Another perspective.
Gary,
Here is my perspective, which I expect many to to disagree with.
Although all of this number crunching and scale munching is very interesting to see the effects of various changes and adjustments, if the end result is to convince you need a new tow vehicle, that would to me be a sad thing. I see absolutely no reason that a modern 1/2 ton truck should not safely tow a 25 foot airstream with a ProPride hitch.
If I were you (and I recognize we are all different) I would call this a worthwhile experience and proceed with adjusting the hitch so that the truck and trailer both ride in a level manner. Then take it out and enjoy it. There is so much controversy these day about what all these various ratings really mean that actual experience would be of more value. I also would suggest that you start another thread and solicit others experiences with a 25 foot Airsteam and 1/2 ton truck. There are probably a lot of people who have useful opinions who don't follow this thread.
If you would like someone else to look at your set up feel free to send me a PM, I'm not that far away.
Ken
Old 03-17-2014, 08:24 PM   #808
W , New England
Actually Ken - it's hard to disagree with your view as well. I feel stooopoopid recommending a rethink on that truck. It makes no sense except that the GVWR is exceeded and not yet fully loaded for camping.
It doesn't add up. But if those are the numbers, my bias is to live within them. Everyone's mileage can vary...
Old 03-17-2014, 10:19 PM   #809
2016 30' Classic
Erie , Colorado
Ken the towing and handling is fine. While the hills of Pennsylvania aren't the Rockies it stayed at 60 most of the time. Found that 60mph was better speed than 65, about 15% increase in MPG. So I am surprised that I ran out of weight. Interesting that I did a CAT ticket after I bought it. Weights Fr/Rear were 3460/2520. Those numbers also line up with the PP setup taking into account adding 1200# on the rear.
Gary
2015 Classic
ProPride
NVPN
Old 03-17-2014, 10:41 PM   #810
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I agree with Ken. We tow the same Airstream as Gary using a 1500 Ram and ProPride hitch.
Some questions looking for a clue to the problem. Are you sure you have 1400# w.d. bars? What is the wheelbase of the truck? Has the truck had any suspension or wheel/tire modifications? Are the headlights aimed properly at night with the Airstream in tow? Is the trailer level and the truck near level with w.d applied? Are the w.d bars level or high or low at the back with w.d. applied? Is the truck hitch receiver flexing when you tighten the bars? Would you have a photo of them hooked up?
Doug and Cheryl
Old 03-17-2014, 10:42 PM   #811
Ag&Au's Avatar
I don't know anything about CAT scales, but I wonder if there is any question about accuracy when used below the range they are optimized for.
Ken
Old 03-17-2014, 10:56 PM   #812
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Frankly, if it was my unit and it drives good and stable, and your tires are rated for their load I would never think about the ratings again.
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 10:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
