Old 08-18-2013, 08:33 PM   #715
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by Alphonse View Post
Okay, where are you? A beautiful setting and i see water in the background.
North Abutment campground Grenada Lake MS.
We will be there next weekend, too.
Labor Day weekend we will be at George Payne Cossar State Park Yocona Ridge campground. It is just as beautiful as Grenada. There is a hayride every Saturday night and there is a herd of tame deer in the park.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-18-2013, 08:37 PM   #716
m.hony's Avatar
2013 30' Classic
Originally Posted by Zackybilly1 View Post
Alphonse,
I knew you would pickup on that comment! I'm going to do some CanOpener research...sounds like a good time and a chance to visit with other Streamers.
Z
That will be the only time I've camped with more than one other Airstream in the park.
It will be our first Airstream only rally.
An entire campground full of shiny silver trailers- awesome.
TAC #MS-10
Airforums #70955
Old 08-19-2013, 11:13 AM   #717
Zackybilly1's Avatar
2012 28' International
2009 34' Panamerica
Poplarville , Mississippi
I'm booked...Loop 101. Looks like it is filling up rather fast.
Z
Zackybilly1 is offline   Reply With Quote
Old 08-19-2013, 12:15 PM   #718
2009 34' Panamerica
Originally Posted by lsbrodsky View Post
Hey guys,
I am subscribed to this thread to learn about pp issues. Could you take Canopener and other stuff to a new thread,please.
Larry
If it is something that has not been covered in the past 700+ posts, is there a specific question you have that we can help with to get the thread back on track?
Z
Old 08-19-2013, 12:41 PM   #719
m.hony's Avatar
2013 30' Classic
It's related-
I was talking about purchasing a hitch from Z on the way to Canopener.
See- related...
TAC #MS-10
Airforums #70955
Old 08-19-2013, 01:23 PM   #720
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
No, but I learned a lot from this thread before I bought my 3P, not so much about where you are camping. I am not having any problems using mine and I do want to stay connected with any breaking news about issues.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-19-2013, 01:39 PM   #721
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Good thread on the ProPride and a major reason for buying mine as well. Staying on topic is helpful.
doug
Old 08-19-2013, 01:52 PM   #722
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
doug
Agree, X3
Bud
Ridgerunner3 is offline   Reply With Quote
Old 08-19-2013, 08:06 PM   #723
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by SteveSueMac View Post
Here's a PP question - I believe that the tilt of the head is set from unhitching when you get the WD bars lose enough to kick (no more, no less). And that should be the angle (tilt) you come in on when you hitch up next time. Why does that angle sometime change between hitching? Good news is the answer is to just adjust the WD jacks and the head sort if slips right on to the stinger. But how does this change after a week of just sitting in storage?
I suspect trailer load/unloading, surface it rests on, someone bumping the trailer tongue jack up or down.. Or the gravitational thingamajalopy...
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-22-2013, 04:03 PM   #724
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
got mine installed..
I ordered my ProPride earlier this summer and it did not get to me in time for my big 5,300 mile trip so it had to wait until I got home to install. It took about 5 weeks to get to me but it was packed real nice, no scratches etc.
I have a 05 Safari 30 towed with a 2500 Suburban now, however i have a GL 350 that I am going to eventually enact for towing duties. I took the opportunity to strip everything down on the tongue and repaint it except i need to get some short set screws or short bolts to put in the two Reese bracket holes.
Install went good, about 2 hrs. I went with the 1400lb bars per Seans suggestion. I went to the scales today and i just guessed at the bar preload at 5" of jack lift. Looks like from the scales i could add some tension. First impressions were sketchy as i did not have enough boost on my brakes and the hitch head did a violent swing to one side on a hard test brake. I bumped up the brake power and went to Boost 2 (Prodigy) and it seems better but i need to really romp on the brakes once and see what it does. I went back through and checked my fasteners after about a 40 mile test run and the crossover bar that keeps the yoke centered on the tongue had slid a bit. I really cranked on it. Highway performance is as advertised, awesome on the lack of sway. Has a different feel in cornering that will take some getting used to.
Picked up some 5/16" high tensile chain to extend the breakaways also as they are just a little tight if i go under the sway bars.
Looking forward to a longer run to test it.
SafariSS is offline   Reply With Quote
Old 08-22-2013, 04:38 PM   #725
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
You need enough chain to cross the chains under the hitch. State law.
Also, crossing the chains keeps the outer chain from getting too tight when you turn sharply.
John W. Irwin
WBCCI #9632
Old 08-22-2013, 04:51 PM   #726
2002 25' Safari
Images: 11
X2. The chains need to go between the WD bars. Look at the install instructions.
Brakes that are out of adjustment can cause the hitch to "bump". Also I believe I have read that AS disc brakes have a slight delay as compared to magnetic brakes. I think a brake delay could cause the hitch to bump.
Bud
Old 08-22-2013, 05:14 PM   #727
Pahaska's Avatar
Hays County , Texas
I have disc brakes and have never had a bump when applying brake using a Prodigy.
John W. Irwin
WBCCI #9632
Old 08-22-2013, 05:36 PM   #728
SafariSS's Avatar
2005 30' Safari
I think I got the bump out, heading out for a 3 day run and will put it to the test.
I picked up some nice high tensile chain today and will put it on when I get back. I am not one for state laws anyway. ...those bastards just like harassing decent folks.
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 10:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
